Results 1 to 25 of 58
Thread: Finally built one
Threaded View
    May 2005
    Oslo, Norway
    Cool Finally built one
    I finally got all my parts and started assembling them this weekend. This is my first 'real' unit, I built one before, but that was more like an experimental thing, i used almost only used parts (used captube, used pipes, even used filter ) and it had 1/4" pipe for suction.. The evap was bad too.
    But here it is
    -Used Mitsubishu R22 rotary that came with a 25MF run cap, i really got no idea on how powerfull it is, but it weighs 16kg, and is about 24cm high
    -1/4" discharge with some coils as a vibration silencer.
    -Used condenser. Don't know the Kw rating, but it's about 19x25cm and three rows.
    -3.2m .031" captube. I might want to shorten it later.
    -Cap-in-cap evap with 3mm base.
    -60cm 1/2" braided stainless steel hose for suction. Then 1/2" copper tubing. I guess 3/8" would work as good, reason i use 1/2" copper and not 3/8" is because BES sent me wrong size (LOL), and of course i don't ship it back to the UK .
    The unit is charged with R290 at the moment, but i will probably regas it to either a R290+R410A mix, or R404A. Depends on what i can get.
    Some pics
    Parts:
    Compressor:
    Pics of the unit:
    Attached Images Attached Images
