A few observations suggest that AMD's Llano could do AVX instructions.
1) A reasonably large new block next to the FP register file.
2) Something what could be a new 3-way extra decoding stage in front of the FP units.
3) The large increase in size of the reorder buffer (3x24 to 3x32 or 3x36)
-It would be faster even if it's still using 128 bit hardware for the 256 bit
operations since typically many time slots are unused in FP units.
-The AVX performance would be ultimately limited by the cache bandwidth
to/from the SSE/AVX units (32 byte/cycle versus 48 byte/cycle for Sandy
Bridge)
-The 256 bit operations would be split into independent 128 bit operations
which would explain the increase in size of the reorder buffer.
-The size of the 3-way decode pack stage in front of the Integer units
has also increased also suggesting that something is added to the
decoding units (cache access for 2x128 bit words?)
Some extra points:
The second level TLB units for the data cache have been doubled from
512 entries to 1024 entries.
There is extra integer logic. A good guess would be a faster version
of the Integer divider. One that can produce multiple result bits/cycle
like the ones in the Core2 and Nehalem architecture.
Regards, Hans
