I've posted this project in a couple of other places and thought i'd post it here aswell for your parousal,the build consists of a Lian Li G70,powder coated white outside,black inside with the roof cut out to house a PA120.3 and the floor cut out to house a PA120.2,window cut out and a few cable management holes.The hardware going inside will be:
Asus P6T Deluxe
Core i7 920
6Gb DDR3 Corsair Dominator 1600MHz
GTX 280
Antec Quattro 1000W PSU
1TB Samsung Spinpoint F1
500Gb Samsung Spinpoint F1
Cooling:
PA120.3
PA120.2
DDC-1T Pro/XSPC Top
DDC-1T Ultra/XSPC Top
2 x Bitspower 5.25 White bay res's
XSPC Delta V3 CPU Block
MIPS Mosfet and dual N/B-S/B Block
Danger Den White UV 3/8"IDx5/8"OD Hose
White Enermax Cluster Fans
Anyway here's the case
Cutouts for the PA120.2 and cable management holes
PA120.3 tapped for M4 bolts and test fitted
Fans and PA fixed to case top
Top fitted back on case
Fitted the fans and fittings to the PA going in the bottom
Rad and fans fitted
Here's the res's i'm using
Got the tops on the pumps,braided and fitted
And the Res's
I'll update this over the next couple of days untill I get up to where i'm at now.
