XtremeSystems Forums
Reply
Old 04-24-2009, 01:27 PM   #1
breathemetal
breathemetal's Avatar
Send a message via AIM to breathemetal
best i7 block?
ive seen a lot of new i7 blocks come out so whats the best? still the gtz?
breathemetal is offline   Reply With Quote
Old 04-24-2009, 01:31 PM   #2
clone38
clone38's Avatar
Heatkiller
__________________
EVGA 4 Way- 920 DO- Corsair 6GB GT 2000MHz
Crucial 64GB SSD- Corsiar HX 850- Megahalems
XFX 5870 CF-X-Fi Titanium - Fatal1ty Professional
clone38 is offline   Reply With Quote
Old 04-24-2009, 01:35 PM   #3
Freonor
is the backplate needed? http://www.sidewindercomputers.com/hk1366plate.html
__________________
CoolerMaster HAF 932
i7 920 @ 3.8 vCore:1.3V
GA-X58-UD3R
6GB Dominator (8-8-8-24 @ 1600 @ 1.66V)
Sapphire OC 4890
Corsair HX620
2xVertex 30GB
WC: MCres-MCP655-MCR320-MCR220-EK Supreme LT-EK FC 4890 LT
Freonor is offline   Reply With Quote
Old 04-24-2009, 01:35 PM   #4
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
Either the Heatkiller 3.0 or the EK supreme LT
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 04-24-2009, 01:39 PM   #5
DdotRoq
I am Xtreme
DdotRoq's Avatar
I've heard a few horror stories about the Heatkiller, I'd say GTZ and <S>Taco</S> EK Supreme LT.
Yes the backplate is needed... you need to screw your block into something.
__________________
Will an XS Member be so kind and "gift" me their unused disregarded Intel i7 Extreme Edition "Sticker"? PM Me
Lian-Li Armorsuit PC-P80
Asus P6T Deluxe w/ OC Palm| TFC X-Changer 360 x2
Intel i7 965 Extreme Edition | Swiftech Apogee GTZ
Asus GTX 295 x 2 (Quad-SLi) | Koolance VID-NX295 x 2
Velociraptor 300GB | Swiftech MCP655 Pump x 2
G.SKILL PI Black 6GB | EK 250ml Reservoir
Tygon 7/16 Tubing | Enermax Revolution 85+ 1050w Fully Sleeved
DdotRoq is offline   Reply With Quote
Old 04-24-2009, 01:45 PM   #6
HESmelaugh
HESmelaugh's Avatar
What horror stories have you heard about the HK 3.0?
I agree that HK 3.0 and Supreme LT are very good choices. Also very much worth considering: Enzotech Sapphire Rev. A.
HESmelaugh is offline   Reply With Quote
Old 04-24-2009, 01:58 PM   #7
century child
century child's Avatar
I would also like to hear about these horror stories. Please elaborate.
century child is offline   Reply With Quote
Old 04-24-2009, 02:04 PM   #8
IanY
I am Xtreme
Haven't we been down this road before? They are all good. They are also all horrible.
When in doubt, buy ThermalTake!
IanY is offline   Reply With Quote
Old 04-24-2009, 03:16 PM   #9
RAYTTK
RAYTTK's Avatar
D-Tek Fuzion V2 works well for me with the new 1366 pro mount its really easy to fit, Un fit, Fit and unfit etc. Fans are all near silent BTW
__________________
X58 Bloodrage P07
920 DO Batch 3850A795 @ 4.2, HeatKiller 3
3 X 2 GB OCZ REAPER 1866 @ 1600mhz, 7's, 16,1T
BFG 280 GTX H2OC
2 Intel G2 80GB Raid O, WD Caviar Black, 750GB
Samsung 1TB F3, Silverstone DA750 watt PSU
Thermochill PA120.3, TFC 120 with 1850 Gentle Typhoons push pull, Sunbeam Extreme
Laing DDC-Pump 12V Ultra(18w) with XSPC Res top. Lian Li V1000
RAYTTK is offline   Reply With Quote
Old 04-24-2009, 03:24 PM   #10
kpablo
kpablo's Avatar
Also i am curious about that story... i visit most of the renowned WC forums and i did not read anything about it... only pure loves...
And no, backplate is not needed to mount HK block, it's sell separately.
__________________
i7 950 | EVGA X58 Classified E759 | Dominator GT 2000 CL8 | HD5870 CrossfireX | Corsair X64 | HX1000 | Lian Li A77B
Heatkiller 3.0 Cu | Black Ice SR1 360 + 3x Delta 120mm | DDC 3.25 + EK DDC X-Top v2 | EK Res 150 | Bitspower Fittings
i7 860 | CM Hyper 212+ | P7P55D Pro | Blade 2000 CL9 | HD3870 512MB | HDD 150Gb, 320Gb | HX1000 | Matrix Vx
Samsung S2333SW | Samsung P2350N | G15 | DeathAdder | MX518
kpablo is offline   Reply With Quote
Old 04-24-2009, 03:27 PM   #11
vilacr
I am Xtreme
EK supreme with backplate
__________________
i7 920 oc'd 4.25ghz
Asus P6T mobo
12 gig Patriot ddr3 1333 oc'd 1611 ghz
EVGA GTX 260 x2 sli
EK Supreme cpu block
MCP655 pump
TC 120.3 rad
Swiftech MCR-220
Swiftech micro res 2
MM U2-UFO CYO
PCP Cooling 750W Silencer
Windows 7 RC
vilacr is offline   Reply With Quote
Old 04-24-2009, 03:52 PM   #12
Stealth42o
Stealth42o's Avatar
The benchmarks I have seen has the 350 on top (Single loop). Heatkiller / EK LT (multi loop)
Stealth42o is offline   Reply With Quote
Old 04-24-2009, 03:58 PM   #13
Hybridchemistry
Hybridchemistry's Avatar
I definitely like the look of the HeatKiller, but I'm going to be using a GTZ on my SunTzu build. Hopefully I'll have temps tonight
Hybridchemistry is offline   Reply With Quote
Old 04-24-2009, 04:07 PM   #14
SNiiPE_DoGG
eh, the 350 is a really great block, but its SO restrictive, you cant even put in a chipset or pwm realistically
__________________
Old 04-24-2009, 04:12 PM   #15
Hondacity
where did you get that info about the gtz being the best? the gtz sucks...
the ek supreme beats the gtz in martins review...skinne's review will show that too..and Hesmelaughs review shows the gtz trails the supreme...even i tested it...
read the reviews...
some are in the stickies and some aren't stickied good luck finding them. or i hope someone links it.
if you want the best for the i7, read the reviews. oh yeah read gabe's review, alot like that review
__________________
Hondacity is online now   Reply With Quote
Old 04-24-2009, 04:32 PM   #16
hlonipha
hlonipha's Avatar
[quote=RAYTTK;3752520]D-Tek Fuzion V2 works well for me with the new 1366 pro mount its really easy to fit, Un fit, Fit and unfit etc. Fans are all near silent BTW
those are not good temps at all my friend. Mine are 10c higher at full load with 1.39v volts. looking that you are using only 1.26v and not at full load... My iddle temps are 34c-36c again using 1.39v.
You should not be bragging about your setup or reccomending it at all. Kind of missleading.
[IMG][/IMG]
__________________
EVGA Classified 760 S610
W352O 21X211 HT Enable @ 1.42V 3850A823
CORSAIR DOMINATORS GT @ 7-8-7-20 1T
PCP&C SILENCER® 910
2x EVGA GTX 295 Quad SLI
X-Fi Fatal1ty Titanium PCI-E
1 x WD VELOCIRAPTOR 300
Seagate 1TB
CM HAF 932
HK 3.0/MCP655/FESER X360/Microres V2
Windows 7 64bit
Dell 3008WFP 30"
hlonipha is offline   Reply With Quote
Old 04-24-2009, 04:54 PM   #17
kpablo
kpablo's Avatar
You have HT off... better temp in Full because of HT disabled... Try with HT enabled and you'll see your temps jump.
Oh, and what's your room temperature?
__________________
Old 04-24-2009, 05:36 PM   #18
Linus@ncix
Linus@ncix's Avatar
The other poster also explicitly said his fans are running near silent.
There's no magic sauce that makes a water cooling loop perform well if you've got weak fans on your radiator. Everyone water cools for different reasons. Personally I water cool for silence and my temps are not very good, but they're a heck of a lot better than if I was running ~800RPM fans on air.
He's happy with his results so I don't really see the problem.
__________________
Please note: I am not here to provide any kind of official NCIX support on these forums.
For faster (and official) service please contact me at Linus@ncix.com, or please contact our customer care team at wvvw.NCIX.com (Canada) or wvvw.NCIXUS.com (America)
Heatware: http://heatware.com/eval.php?id=25647
Linus@ncix is offline   Reply With Quote
Old 04-24-2009, 05:44 PM   #19
IanY
I am Xtreme
Thumbs up
Anyone who says X brand block is the best and all trail X brand block is talking through their exhaust catalytic convertor. The single biggest influencing factor for all of you is how a block looks, and most of you don't even have the gumption to admit that. The tests are more often than not driven by preconceived notions and agenda strewn.
Old 04-24-2009, 05:54 PM   #20
Sadasius
Tygon Warrior
Sadasius's Avatar
HEHE, no kidding. Biggest gains I have found is to turn up the damn fans!
__________________
San Ace Awesomeness!
San Ace Awesomeness Part II!
If you cannot handle the truth DO NOT click--> this link!!!
Sadasius is offline   Reply With Quote
Old 04-24-2009, 06:14 PM   #21
shazza
Xtreme Fan
shazza's Avatar
From the reviews I've seen (as mentioned by hondacity), the GTZ consistently performs a couple of degrees "worse" than several of those mentioned. HOWEVER ... it is extremely easy to mount, and that may be important to some. I like it because I can change out my loop or reseat the block without having to get to the back of the motherboard.
__________________
MM#2 : EVGA X58 | i7 920 | Vista 64-bit | Liquid Cooling | Corsair HX1000W PSU | EVGA GTX 285 Tri-SLI | 3x2GB Corsair 12800| WD 750GB | Mountain Mods UFO-CYO
shazza is online now   Reply With Quote
Old 04-24-2009, 06:30 PM   #22
Hondacity
k350 mounts better
oh no..you remind me of the 20+ mounts that day i got the hk3... my thumb feel sore now...
__________________
Old 04-24-2009, 08:34 PM   #23
John Planet
John Planet's Avatar
Send a message via ICQ to John Planet
I've heard a few horror stories about the Heatkiller...
Yeah, I'd like to hear one of those stories too! The HK install wasn't pretty by GTZ standards, but I got it done without TOO much cursing. Other than this I've been pleased with the results.
__________________
Core i7 940 + HK LT, 295GTX + DD 295
ASUS P6T DLX V2, 12gig Corsair Plat. DDR3 1600
2XDDC 3.2 18watts, PC LRT, pure distilled+silver, TC PA120.3/TFC 120.1
2x150gigWD RaptorX, 2x500gigSG, 1x1tbWD BLK SG, 1.5tb external drives
SB Titanium PCI-X, Logitech z2300, Triton AX PC Pro
2xMemorex DL DVD burners-USB attached
Samsung 225BW & 204B
MM U2 UFO powder coat+12x120MM fans, Enermax Galaxy EVO 1250W, Windows 7 U64
John Planet is offline   Reply With Quote
Old 04-24-2009, 08:50 PM   #24
Stealth42o
Stealth42o's Avatar
Very true, however my CPU is the only block in that loop, so as far as I have seen/read. 350 is the "best" block for my setup.
People need to start phrasing there post from "What's the best block" to "What's the best block for me".
If you want to do a multi block loop, 350 would be a foolish choice. HK or LT would be the way to go.
Old 04-24-2009, 08:57 PM   #25
003
Xtreme Mentor
003's Avatar
Doesn't the HK 3.0 outperform the 350 on i7 as well? I'm pretty sure there was a review that showed that.
__________________
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
—Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
003 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
