Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Laing D5 Vario Vs. Laing DDC3.2 - Which is better for watercooling?
    Feb 2008
    Wanted to ask which one is better for watercooling, the D5 Vario or DDC3.2?
    I notice D5 Vario head, pressure and flow rate is higher than DDC3.2.
    However I found on Martinm210's Excel Flow Rate Estimator that as soon as the D5 Vario has a little restriction, flow goes down, and DDC3.2 is slighty better flow.
    I want to buy a couple of these pumps, and I'll be using the EK tops on them.
    I've tried to search the forum a little, however I'm told the D5 Vario is better, but Martinm210s chart says otherwise.
    Thanks guys.
    I am Xtreme
    Aug 2008
    martin reviewed it...
    nexthardware reviewed it...here is his estimator
    http://www.xtremesystems.org/Forums/...ight=estimator
    my flow testing....
    http://www.xtremesystems.org/Forums/...20&postcount=1
    Aug 2008
    Define better? What are you looking for? The best flow? Controllable? Those 2 things you can only get from one of each of those models. You can only get control over the D5.
    I can say what was my choice and why I chose it though.
    I chose the DDC3.2 becasue it was little, it performs well with the aftermarket tops, and it performed well enough for what I needed it for to start out with.
    Both are good pumps. They are both reliable. I think the DDC with certain tops will outperform the D5 by a little bit though. It also dumps a little less heat into the loop which is a bonus.
    I had a thread that shows just how powerful those little things really are. They are quite impressive for their size. I've also seen double DDC's on the XSPC double top, and man that seriously moves some water. It'll splash water right out of your resevoir if you take the top off!
    Edited: Correction, that was a Hardwareluxx Top I saw, not a XSPC. Whoops!
    PS Re-Re Edit: The Hardwareluxx top does not fit the newer DDC3.2's
    Admin
    Feb 2005
    Ann Arbor, MI
    Quote Originally Posted by T_Flight View Post
    XSPC makes a double top?
    Oct 2008
    NY
    I believe the DDC3.2 with an XSPC top outperforms the D5. In reality, both pumps are excellent for PC water cooling and you will be happy with either.
    heat
    TJ07-Ultra 1200W-E8400-Rampage Formula-4870-4gb G.skill-74gb Raptor-500gb Seagate-Windows 7
    Apogee GTZ-XSPC Razor-DDC3.2 w/ XSPC top-PA120.3-MCR220-EK 250 res
    Jun 2008
    Los Angeles, CA
    It all comes down to which blocks you're using. Having control over heat dump and flow is a big bonus imho. D5 with DetroitAC top...
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Also depends a little on your loop layout. D5 by default is intlet on the side outlet on the top, DDC with top is inlet on the top outlet on the side.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Aug 2008
    Quote Originally Posted by Vapor View Post
    I belive that was XSPC. I saw it in one of Naekuh's pics. Two pumps go into one top. It's acryllic. Lemme go look it up to be sure.
    Feb 2008
    I beleive EK has a double top for DDC, will upload link after work.
    Aug 2008
    Is it an EK? I'll go find it then. I know I saw it on Naekuh's setup. It's sandwitched in between two pumps. I thought it was an XSPC.
    Lemme go look. BRB...
    Edited to Add: OK, here's one, but the one I saw was Plexi.
    http://www.sidewindercomputers.com/ekdututopg1a.html
    Re-Edit: Here's another that looks more like it. Whew! $$$$$ Expensive.
    http://www.chilledpc.com.au/index.ph...emart&Itemid=3
    We need Naekuh to find out who makes that thing. I can't find one iof XSPC makes it, I can't find it. I thought it was an XSPC though I might be wrong.
    Oct 2008
    Quote Originally Posted by hotdun View Post
    X2 if not 3 or 10........
    Admin
    Feb 2005
    Ann Arbor, MI
    Hardwareluxx makes Naekuh's
    Aug 2008
    Ahhh, OK. Lemme go edit that post and correct that. It also said that the Pump will not fit the newer DDC3.2 on that Hardwareluxx top. What a bummer.
    Oct 2007
    I like the variable aspect of the D5, and it doesn't get as hot on the outside as DDCs. Don't EVAR EVAR NEVAR put a DDC straight down on Petra's Gel Stuff.
    Current Project: City of Light, (sortof) Updated 3/25 - A New Arrival
    Feb 2008
    So, it can be said D5's are more reliable, quieter and run cooler than DDC3.2?
    Cheers.
    Dec 2008
    Quote Originally Posted by nirvana_1911 View Post
    Cheers.
    Wouldn't say yes to any of those.....have seen failures in both DDC's and D5's. The DDC3.2 is NOT the same as the old maligned DDC2 pumps.
    Quieter? I cannot hear my DDC2 pump running at all.......and I'm sitting about 2ft from it.
    Cooler? Both are elec. pumps, both get warm. True, the DDC does concentrate its heat on the bottom, but the D5 does produce its share of heat, just in different areas.
    Feb 2008
    Quote Originally Posted by Humminn55 View Post
    I understand DDC2 aren't around anymore, and those pumps were bad.
    Also, D5 Vario is reasonably larger than the DDC3.2...
  18. #18
    Oct 2007
    Cheers.
    Reliability is about the same, but tiebreakers would be the stigma of the older DDC's that were somewhat unreliable; also I've seen a lot of D5 derivatives in industrial applications so that makes them seem more reliable to me.
    DDC I would say is quieter.
    D5's external casing doesn't get as hot as the DDCs, but I imagine they both put out the same heat dump. Most would say that the DDC is better if it has a fan under it, and that's not needed with a D5.
    I have had a D5 for a while now, and am glad that I have it over a DDC. I don't think people would regret buying a DDC though.
  19. #19
    Oct 2007
    Nice I always wanted to see a D5 vs DDC thread, tho before buying my D5 I was thinking on this modded D5, any thoughts on that particular model? (please ignore price just performance side) modding a D5 with those parts is a good idea? (besides bling factor)
  20. #20
    Dec 2007
    Beneath The Remains, Greece
    I also posted this on another thread. Do u think its worth getting EK top Rev2 for the D5 vario?
    Intel i7 3770K (4.8Ghz@1.36v) ~ Asus Maximus V Gene ~ 8Gb G.Skill Ripjaws X 2133 C9 (@2400 C10) ~ Asus GTX 670 DCUII (1230/7000) ~ Samsung 840 Pro 128Gb ~ WD Black 1Tb ~ Corsair AX 850W ~ X-Fi Titanium Fatal1ty ~ Epoz Aktimate Mini ~ Ducky Shine Blue Led /w MX Red ~ Logitech G700 ~ Samsung S27A850D 27" (2440x1600) ~ SilverStone TJ07B-W
    WaterCooled by XSPC Raystorm ~ TC PA 120.3 + 3xAP 15 ~ MCP655 with EK-D5 X-Top Rev.2 ~ EK Multi 250
    Powered by APC Smart-UPS SC 1500 ~ MGE ellipse premium 500
  21. #21
    Apr 2006
    Hong Kong
    I recently had a D5 that died - it's been used for about 4 years 24/7 with multiple refills of the loop - i think the constant priming had it running on air for too long over many short periods of time.
    At any rate, I've replaced the D5 with 2 DDC3.2's and XSPC Res tops - I can say that both DDC's running together create less sound than my D5 did but *only* once the system has fully bled. Until that moment, they were loud... very loud as air bubbles passed through the impeller.
    What strikes me as odd about the DDC3.2 with xspc restop is that I don't have any indication as to my flow just by watching the water in the res - it appears not to move. At least with the D5 / EK res or Swifty res I could gauge my flow by sight. The controller on the D5 was also mighty useful.
    "Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
    2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
  22. #22
    Xtreme Recruit
    Dec 2008
    Quote Originally Posted by CedricFP View Post
    I confirm, my DDC 3.2 + Top is very loud because of air bubbles.
    It would be solved when the bleeding will over.
    I m pretty sure of that because before i reset my liquid cooling loop, it was quieter.
  23. #23
    Jun 2007
    mars
    but with ddc u can monitor rpm at any control panel
    or plug rpm wire to mobo and set system to shutdown if pump fails
    Intel Xeon W3520 4200MHz HT
    Foxconn Bloodrage
    3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
    MSI GTX480 M2D15 850/1700/2000
    Samsung F1 1TB
    Corsair TX950W
    Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
    NEC 2690WUXi
    Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
    Loop 2: Laing DDC1-T -> EK-FC GTX480 -> Thermochill PA120.2 -> EK Res 150
    *New* CM 690 II Advanced Watercooled
    *Coming soon* Stacker 832 Rebirth!
  24. #24
    Apr 2006
    Hong Kong
    Quote Originally Posted by rioja View Post
    Yes that's true I had forgotten about the RPM wire.
  25. #25
    Nov 2008
    CA,USA
    What kind if output do you use to monitor the rpm? mobo fan power connectors ok?
    Armor.exe worklog
    Mobo: Asus Rampage 2 Extreme X58
    CPU: i7 920
    GPU: ATi HD 4870x2
    Sound: Auzentech X-Fi Forte 7.1
    PSU : Corsair HX1000
    RAM: OCZ 3 x 2GB tri channel DDR3-1600
    HDD: WD 640 Black RAID 0 + 1
    Watercooled
