Mountain Mods Pinnacle 24 with Quad TFC on side Panel and Triple TFC in front with two loops.
Having the quad on the top panel prevents have 2 drives and a fan controller.
So I modded the case to have the quad on the side and built my own bracket for the drives.
This is a great case but having the rads in the front and top only is to common and makes for to much tubing.
MM should have cut out a hole for the mobo back plate, its OK I cut one myself.
Same components as my sig but with and added Quad TFC rad and mcp355 pump with XSPC res/top.
I will be taking my time on this build so it will look and perform great after its done.
Loop #1: Quad rad -i7 920 CPU W/ K-350- res/pump
Loop #2: Triple rad - GTX 260 W/DDtieton block - Swiftech MCW-NBMAX for NB - res/pump.
The side panel was solid, I used a 4 1/2 inch hole saw to cut out for the rad.
Good thing I had a great pattern, the top panel with three holes cut out that came with the case.
1/2"x1/2"x1/16" aluminum L corner was used.
