XtremeSystems Forums
Reply
Old 06-02-2008, 09:07 PM   #1
Naja002
I am Xtreme
Naja002's Avatar
Yes, Another Car Radiator Thread....Major 56K Warning!
After starting to get bored, I started looking for a new project--a PC cooling type of project. I was going to do the copper pipe in the crawlspace along with some other possibilities. But after reading threads about the use of car radiators--I decided to check it out for myself. My initial participation started in this thread--Post #131:
using car radiators...why not?
Seems that the biggest complaint that I found was--car radiators are made of aluminum. Ok, a lot of them are, but not all of them.....
So on with the show:
The PC water cooling system is currently setup to cool 3 PCs (cpu & nb) running 100% cpu power crunching for WCG-cure cancer. At the moment, only 1 PC is connected to this system--the others will follow....
On May 20, 2008 I purchased the below Car Radiator.....with a plan:
Add a Mag Drive 9.5 pump:
Next add the Famous 55gallon Blue Barrel:
A bit of PVC--and the plan starts coming together....
Naja002 is offline   Reply With Quote
Old 06-02-2008, 09:08 PM   #2
Naja002
I am Xtreme
Naja002's Avatar
I decided to offer each PC its own incoming water, so I figured that the easiest way to do that would be to create a manifold:
I decided to make the manifold for 3 PCs, but left the extra PVC space in order to add more later--if necessary.
The manifold is installed with 1" tubing running down through the floor into a crawlspace:
Yes, some "wire-management" is in order....
In the crawlspace it connects back to 1" PVC pipe:
I decided after-the-fact to add drains to the system at the lowest point:
It then runs a few feet up and into an Out-building:
I'll worry about covering things up later:
Once the radiator arrived, I had to check the fit of its new home:
Almost Perfect:
Old 06-02-2008, 09:11 PM   #3
Naja002
I am Xtreme
Naja002's Avatar
In order to prevent the use of mixed metals (copper and aluminum) I needed a copper radiator! So, I found one! (Most are made of aluminum these days).
For excellent cooling ability and flow--I wanted a triple core (3 rows) radiator:
3 rows of nice flat tubing. (Flat tubing offers much greater surface contact and much less warm flow bypass!)
Yeah, Baby!
Old 06-02-2008, 09:12 PM   #4
Naja002
I am Xtreme
Naja002's Avatar
So,......How to connect the 1 5/16" inlet and 1 9/16" outlet to my 1" PVC? Well, here ya go--1 1/4" and 1 1/2" tubing:
Next, I had to figure out how to mount it in place. So, I just attached some 1"x4" pieces to the out-building frame work:
Cut a few notches:
Then screwed the radiator to the frame work via the radiator mounting holes:
Might work ok as it is for a Passive radiator, but I wanted more options.
Old 06-02-2008, 09:13 PM   #5
Naja002
I am Xtreme
Naja002's Avatar
Power Options! With summer upon us, things are warming up and with a radiator this size--a little bit of air movement will go a long way.
So, in order to restrict air movement to only through the radiator--I needed to make a shroud and seal things up. (Please ignore the a/c filter--I didn't end up using it):
After all of these "projects" you can see that I still have all my toes......well, on one foot at least!
Shroud built, door and radiator sealed--Time to add some Power!
The barrel/pump plumbing above has been changed.
On high these fans will use ~63 watts each. On medium= ~50 w, and on low= ~40w. Not bad at all for the cooling they will offer.
A little bit of foam insulation goes a long way.....
None needed on this one though--nice tight fit:
Next its time to finish up the plumbing and get the radiator hooked up!
Old 06-02-2008, 09:14 PM   #6
Naja002
I am Xtreme
Naja002's Avatar
Plumbing to the radiator inlet:
Radiator outlet:
Man, that was E-A-S-Y!
Now the plumbing to and from the 55 gal. barrel--has to be sealed for a closed loop:
The red handled ball valve is for priming the pump:
Into the barrel from the PCs:
And then back out of the barrel to the pump:
I originally put the pump on top of the barrel. It worked that way, but made priming it a real PITA! So, I dropped it down to the floor. Now I use the ball valve to prime the pump, and once the siphon is created--gravity helps feed it.
Time to finish up the main plumbing!
Old 06-02-2008, 09:16 PM   #7
Naja002
I am Xtreme
Naja002's Avatar
Plumbing comes out of the pump (pic above) up and over to the radiator inlet:
Out of the radiator outlet and down through the floor:
Time to fill'er up!
Then put on the trusty radiator cap:
Add the air filter to the outside:
Put the screen back on:
And she's ready to rip!
Old 06-02-2008, 09:17 PM   #8
Naja002
I am Xtreme
Naja002's Avatar
So, I filled it up with this hard tap water and let the system flush for a few days. Ran into a few minor problems and fixed them.
Now, on June 2, 2008, I have a Q9450 OCed to 3.4 on a GA-G31M-S2L running 100% on Boinc and cpu temps of 46-50C (ambient outside is 30C/85F) and fans on low. I believe that the bottleneck to better temps are A) the current ambient and B) the Apogee GT and MCW30 water blocks.
No Problem for me though.....I will be more than happy crunching at those temps and removing all that heat--OUT--of this room. The cost savings on the A/C should help pay for the cost of running the pump and 2 fans. Good Deal!
When I replace the tap with distilled the temps should get better.
First PC hooked up to the manifold:
This PC will have an open-case home soon:
I left extra tubing in order to not waste any more than necessary when I finished and located this PC's home:
Ambient outside right now is ~67F/19.4C. The Q9450 is still @ 3.4 running 100% on Boinc and temps are: 40, 39, 39, 39.
I'm curious to see what happens when I hook up the next PC.
Old 06-02-2008, 09:20 PM   #9
wallywest
wallywest's Avatar
Subbed!
wallywest is offline   Reply With Quote
Old 06-02-2008, 09:23 PM   #10
MuffinFlavored
Send a message via AIM to MuffinFlavored
I can not wait to see the pictures.
__________________
Gigabyte P35-DQ6 | Intel Core 2 Quad Q6700 | 2x1GB Crucial Ballistix DDR2-1066 5-5-5-15 | MSI nVIDIA GeForce 7300LE
MuffinFlavored is offline   Reply With Quote
Old 06-02-2008, 09:24 PM   #11
aspire.comptech
Send a message via AIM to aspire.comptech Send a message via MSN to aspire.comptech
wtf?!
Im scared...
__________________
Originally Posted by Chruschef in regards to Thermaltake water cooling
you'd be better off cooling your components with a fire....
aspire.comptech is offline   Reply With Quote
Old 06-02-2008, 09:28 PM   #12
philbrown23
Banned
Send a message via MSN to philbrown23 Send a message via Skype™ to philbrown23
subscribed!
philbrown23 is offline   Reply With Quote
Old 06-02-2008, 09:32 PM   #13
SparkyJJO
Xtremely High Voltage
SparkyJJO's Avatar
Send a message via AIM to SparkyJJO
Sweet
__________________
This forum requires that you wait 70 seconds between posts. Please try again in 1 seconds.
SparkyJJO is offline   Reply With Quote
Old 06-02-2008, 09:37 PM   #14
septim
Banned
Send a message via Yahoo to septim
huge!!!
septim is offline   Reply With Quote
Old 06-02-2008, 09:40 PM   #15
qdemn7
qdemn7's Avatar
HOLY FRAG-A-MOLY...
__________________
DFI LP LT X38 TR2
Yorkfield Q9450
2 x 2048MB G. Skill PC2-8000
BFG 8800 GT OC
Asus 1814 BLT SATA DVD-RAM x 2
Seagate 1TB SATA II x1
Samsung 300GB SATA II x 1
Silver Stone SST-ST60F
Dell 2405FPW
Thermalright Ultra 120 Extreme
Thermalright HR-05 SLI
HSPC Large Top Deck Station
XP Pro SP3
qdemn7 is offline   Reply With Quote
Old 06-02-2008, 09:57 PM   #16
Crankyhobo
good god you're a mad man, awesome - very much so, but also mad.
Crankyhobo is offline   Reply With Quote
Old 06-02-2008, 10:02 PM   #17
RockfordFosgate
RockfordFosgate's Avatar
OMG Everthings huge
__________________
Intel Core i7 920 D0 | Gigabyte EX58-UD4P | 3x1Gb OCZ 1600mhz | Gigabyte 8800GT Turboforce 820/2010 | 1TB Seagate | Samsung P2350 23'' | Silverstone Decathlon DA750W | Lian-Li PC777B | Logitech Z-5500 | Creative X-Fi|N97
Watercooling & Case mod soon...
Hardwarena Overclock Team
RockfordFosgate is offline   Reply With Quote
Old 06-02-2008, 10:30 PM   #18
Naja002
I am Xtreme
Naja002's Avatar
You guys crack me up!
Done for now. Hope ya'll enjoy it.
Still having the "Database Error" thing, so I can't get to or respond to PMs......
For those interested:
I just bought this:
80-85 SKYLARK, CITATION w/ HDC NEW RADIATOR--3 rows, copper/brass--$88.50 shipped
Lots of Copper/Brass radiators at Great prices--some damaged, some not--check the description:
ltiparts
Old 06-02-2008, 10:31 PM   #19
otisthecat
sub. nice snakes
__________________
asus striker 2 extreme
285gtx in tri sli under water koolance blocks
Patriot PC3-16000 2x2GB DDR3 PVS34G2000LLKN
vista 64 utilmate
w/c nb,sb mosfets bitspower block
otisthecat is offline   Reply With Quote
Old 06-02-2008, 11:24 PM   #20
Giannis86
Giannis86's Avatar
thats a mad looking setup
__________________
Intel Q6600 @ 3.6GHz
Asus Blitz Formula SE
OCZ ReaperX PC6400 2x2GB
Sapphire HD4870x2
X-Fi Elite Pro 7.1 & Logitech Z5500
Samsung Spinpoint T166 500GB
Samsung 226BW
Zalman ZM1000-HP
Watercooling
Loop 1: DDC3.2 (XSPC Restop), Fuzion v2, BIGTX360 (6x S-Flex F)
Loop 2: DDC3.2 (XSPC Restop), EK 4870x2, TFC X360 (3x S-Flex F)
Loop 3: to come
[DarthBeavis] "I am gonna try to mod one of these into my wife so can get an early warning of when she gets angry . . ."
Giannis86 is offline   Reply With Quote
Old 06-03-2008, 03:12 AM   #21
oerekum
Xtreme Cruncher
oerekum's Avatar
Holy crap!
__________________
Originally Posted by CyberDruid View Post
I am thinking "Bacon Railgun" might be the ultimate weapon, as shooting puppies out of a cannon seems inhumane...
[ build in progress ]
Q9450, P5Q-Pro, 4Gb TeamXtreem Dark + 4gb Buffalo Firestix 1066, Silverstone DA650, Silverstone TJ09, 2×WD6400AAKS Raid0, 2× Sapphire HD4870, Dell 2407WFP-HC.
Liquid:
loop1: EK Supreme, MCW30, PA120.2, DDC3.2+XSPC top
loop2: 2×MCW60, D5 vario, MCR320
oerekum is offline   Reply With Quote
Old 06-03-2008, 03:23 AM   #22
DIE-TEMP
Banned
props on your project mate, looks very well put together
DIE-TEMP is offline   Reply With Quote
Old 06-03-2008, 03:26 AM   #23
Jimmer411
Jimmer411's Avatar
Does that pump even flow enough for all of that?! Insane, but I would definately go for a stronger submergable pump
__________________
Phenom 9950BE @ 3.24Ghz| ASUS M3A78-T | ASUS 4870 | 4gb G.SKILL DDR2-1000 |Silverstone Strider 600w ST60F| XFI Xtremegamer | Seagate 7200.10 320gb | Maxtor 200gb 7200rpm 16mb | Samsung 206BW | MCP655 | MCR320 | Apogee | MCW60 | MM U2-UFO |
A64 3800+ X2 AM2 @3.2Ghz| Biostar TF560 A2+ | 2gb Crucial Ballistix DDR2-800 | Sapphire 3870 512mb | Aircooled inside a White MM-UFO Horizon |
Current Phenom overclock
Max Phenom overclock
Jimmer411 is offline   Reply With Quote
Old 06-03-2008, 03:56 AM   #24
jcool
Xtreme Cruncher
jcool's Avatar
Great setup, removing the heat (and noise) from the room is really awesome!
I hope you can expand that easily, it looks like overkill for "only" 3 crunchers to me
__________________
World Community Grid - come join a great team and help us fight for a better tomorrow!
Rigs:
16-Cores: Quad Opteron 8347HE - 30 Ghz
Octacores: Dual Gainestown X5570 | Dual Harpertown X5450 | Dual Harpertown E5420 - 76 Ghz w/o HT
Hexacores: Intel Gulftown Xeon - 24 Ghz w/o HT
Quadcores: w3520 | 2x Core i7 920 | Core 2 Q9550 | Dual Sossaman (Yonah Xeon) - 70 Ghz w/o HT
Dualcores: all retired
--> 200 Ghz working 24/7 to kick diseases right where it hurts
Envy me already? No problem, I'll send you my power bill and you'll instantly feel better
jcool is offline   Reply With Quote
Old 06-03-2008, 07:04 AM   #25
Naja002
I am Xtreme
Naja002's Avatar
That was a question that I had in the other thread linked in the first post here. The answer--for 1 pc is--Definitely: Yes! There is plenty of flow for this one pc. I'll have to wait and find out on #2 and #3. I think it will do 2 just fine--and maybe all 3. But if the theory holds that flow rate doesn't matter--then it will do just fine! The radiator is triple core which allows greater flow than single or dual core, so life is good. Also, with the bulk of this setup being 1" pvc--the pump should be right at home....
Take a look at the other thread when you get a chance--My participation starts at Post #131: using car radiators...why not?
Getting the heat out of this room has become somewhat of a big deal for me. With summer coming--this room is starting to cook. And by removing the heat to where the A/C doesn't have to deal with it at all--Yep, life is Good! I picked up a "kill-a-watt", so I'm going to check some things out when I get to it.
Reply
Tags
car rad, car radiator, copper pipe, copper tubing, huge, mag drive, pvc
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
