I tried lokking around for the answer to my question but I did not get conclusive results...
I may have found a used iwaki (very lucky) so I am currently thinking big..I am intrigued by car radiators. If flow and head is not a problem why should I stick to conventional computer parts and not go for this: http://cgi.ebay.it/Radiatore-motore-...QQcmdZViewItem
looks big and it is completely made of alluminium. I guess that even passive operation is achievable if the flow is just right...
I have been looking for specific details on the exact heat dissipation capacity of this radiator as well as others but have found nothing....how many watts could an iwaki rd30 + a car radiator (let us take the one I posted a link to) dissipate?
Cheers!
__________________
Watercooled by:
ek supreme
2 iwaki md-30rz in series
2 Audi tt 44x66cm car radiators....
There was someone on these forums that has done that with a Copper Race Radiator from a Japanese company. His delta between temps is insane, and is able to handle his entire rig passive without a problem.
I don't know if you have been following the corrosion / mixed metal wars here, but if you are mixing Al and copper in a loop IMO there is a relativly high risk of corrosion.
__________________
I Are DuneCat
I Controls The Spice
I Controls The Universe
Cooler Master ATCS 840 | Corsair HX 520W | Asus P5Q Pro | Q9550 | HD4870 | Corsair Dominator 4GB PC8500 |
D-Tek FuZion v2 - EK RES 150 - Swiftech MCR-220/320 - Swiftech MCW-60 - DDC 3.2 + Petra's Top
Yeah aluminum and copper is no good. I was thinking of using car rad, but when I saw that it's made of aluminum I changed my mind.
Then I got an air conditioner from a car, pulled the radiator from there, that's the good stuff! All copper tubing, and very big too, my water temps were the same whether with fans or not..
an EVAP from a car will be full of oil unless you mean a H/C? also MOST if not all A/C components are ALU
sorry guys what do you think of this pump? sorry for the off topic but I was just curious to know if something like this could be suited to run such a performing loop:
__________________
Watercooled by:
ek supreme
no one? I could get hold of an iwaki or this.....I am unsure because the head (HM) is 10 which is very good and the flow is actually better than an iwaki.
__________________
Watercooled by:
ek supreme
Anyway the pump is overkill. I will get this one since it has 10m of head pressure and 8400 l/hour of flow !!!
Regarding the aluminium radiator....couldn't anticorrosives do the trick? I can get hold of various chemicals from a friend who works at a lab. I read that phosphates help a lot so I could try those.
It is very difficult to find copper radiators since they are heavy and serve no purpose on cars really (that aluminium can not serve as well and in a cheaper way)
My loop would consist of ek supreme - super pump (should be a univer) - and car radiator.
Isn't there anyway I can get aluminium and copper to work together?
thanks!
__________________
Watercooled by:
ek supreme
anticorrosives could do the trick but you would need a large amount of them in your water. That would hinder performance as well, as compared to distilled water.. i would look for a copper one if i were you
__________________
Intel Q6600 @ 3.6GHz
Asus Blitz Formula SE
OCZ ReaperX PC6400 2x2GB
Sapphire HD4870x2
X-Fi Elite Pro 7.1 & Logitech Z5500
Samsung Spinpoint T166 500GB
Samsung 226BW
Zalman ZM1000-HP
Watercooling Loop 1: DDC3.2 (XSPC Restop), Fuzion v2, BIGTX360 (6x S-Flex F) Loop 2: DDC3.2 (XSPC Restop), EK 4870x2, TFC X360 (3x S-Flex F) Loop 3: to come
[DarthBeavis] "I am gonna try to mod one of these into my wife so can get an early warning of when she gets angry . . ."
yeah, anti-corrosives are typically dissolved solids, which just end up precipitating in your loop, and lower performance. You would need a lot for that huge radiator. Not worth it, find a copper /brass one.
The automotive industry has been mixing them for years.
Like we want to mimick them . . .look at the pathetic fuel efficiency standards . . .if the computer industry was like the auto industry we would have 286's running on 4000k PSUS . . .
Thats because you use antifreeze which is an anti-corrosive agent.
Now in your car, you aren't looking for superb temps as they have a much higher tolerance of heat. For a car 80C is nothing but for liquid cooling you'd be shatting yourself.
__________________
Originally Posted by Chruschef in regards to Thermaltake water cooling
you'd be better off cooling your components with a fire....
