single card pre-test,
will finish dual-sli & tri-sli soon after.
9800GTX Spec:
vGPU=1.2v~1.21v idle, 1.26~1.27v load
vRam=2.0v
ambient=18c,GPU idle=35c,load=53c(100% fan speed)
overclking results summary:
1)Driver 174.20 might have some bug,3Dmark03 result 20% lower than normal,3Dmark05/06 ok.
2)heat same as 8800gts (better cooler but 0.02v vGPU higher)
3)GPU core overclking better (better PCB/PWM/Cooling)
4)vRam overclking better (0.8ns, better PCB/PWM)
5)perf_lvl same as 8800gts clk 2 clk. (only deafault clk higher)
3Dmark03/05/06 benchmark suite screenshots with a 4Ghz E3110:
http://www.unihw.com/html/24/n-124.html
Nibitor3.7a still can't read 9800series bios![]()
the parents will come talk to you shortly. if you have a big creepy van it works faster
