Hello guys,
I have built this unit for my friend jcool. In the picture below you can see the main components. You should understand it, although it is written in German. The unit is optimized for high loads and of course it was not easy. The processor will be cooled with the unit and the remaining components should be cooled with water. The case was already prepared for the water cooling. On top of the case was milled a cutting for the heat exchanger. The unit was built into a Lian Li PC-201 case. To get no problems with condensation, it shouldn't cool under -40C. The unit holds various load between -30C and -40C. At this point I would like to thank PhilippF and tim- for the advice as well as LittleDevil, runmc and cold_ice for providing the components. And thank you jcool for being exceptionally patient through the waiting. Enjoy the pictures, I hope you like it!
Beautiful cutting, isn't it?
Pretty much accessories.
While packing this monster.
Ready for shipping on Wednesday. The package has a weight of 27 kg. However, it is well packed.
