XtremeSystems Forums
Reply
Old 12-20-2007, 01:52 AM   #1
Vapor
Admin
Vapor's Avatar
Fans, Fans, Fans -- XS Fan Review!
Round 2 is here
As a follow-up to my first round-up, found here: http://www.xtremesystems.org/forums/...d.php?t=137832. I have tested many new fans and retested some of the best from the first roundup.
The environment and testbeds have changed slightly, so unfortunately results are not directly comparable, but this should still answer many questions about many of the most popular fans on the market.
Some test changes did occur!
1) CPU temps were ditched. It was an extraordinarily time consuming process that didn't really differ from the radiator test results.
2) Fans were tested from 5V to 12V in 1V increments. This is a change from Round 1's 4V-12V + minimum running voltage that was tested. Again, for the sake of reducing test time (min running voltage was a bit of a PITA and who runs their fans at <5V anyway?).
3) The dBA scale is, again, an artificial adjustment of raw data to 'consumerize' the data to numbers that we are more familiar with. My 30dBA is not exactly the same as Company A's 30dBA. Then again, Company A's 30dBA isn't the same as any other company's anyway I have used data from a few fans with known-good dBAs and come up with a simple linear conversion for the data....neither the order nor magnitude of differences is changed! Because the environment has changed from Roudn 1, so has the adjustment method. Again, it's not at all exact science, but it does make the numbers appear friendlier without actually changing them
Other notes!
Again, an MCR120 was used as the radiator. All fans were tested in pull in relation to the anemometer and the fans were tested in pull in relation to the radiator as well. If you're wondering why, I believe the thread linked above explains.
Again, all fans have undergone a 24-hour burn-in prior to empirical testing. This is because most people run their fans for a long time. Long-term performance is a lot more important than out-of-the-box performance. I did do 0-hour CFM and dBA tests at 12V and 7V though don't have the results listed....where it matters, I'll tell you.
All fans were also properly warmed up immediately prior to testing.
And if the fan is not listed, I haven't tested it...
2 exceptions: FN122 and FM123.
The Silverstone 'Debacle'
I have tested both the aforementioned FN122 and FM123 for Round 2 and have not listed their performance. I hate them with a passion. Neither are anywhere near their CFM ratings and the FM123 is more annoying to listen to than the 220CFM Deltas in Round 1. I'd go as far as saying it's more annoying than a crying baby. Unlike the baby though, you can kick it. At this point, the FM121, FM122, FM123, and FN122 have ranked among the most annoying or worst performing fans I have ever tested/used. They may all be lemons, but if the lemon rate coming out of Silverstone is 80%, you should stay away. If they are good representations, you should stay away. So ultimately, based on my experience with them, you should stay away. And I really don't have a bias...I actually like the FN121 quite a bit. Shame it has retarded siblings.
I wanted to exclude all Silverstones from this test, but because I was using an FN121 as a carry-over all-star comparison from Round 1, that was not possible. It actually did fairly well in this round-up as well. Go figure.
The Sleeve Bearing Grind
It's common knowledge that sleeve bearing fans have positional tendencies....mostly poor longevity when stored or used blowing up/down. It has to do with the lubrication not effectively lubricating the entire bearing. It's annoying.
They also have low MTBFs....so they've been arbitrarily punished when it came down to selecting my favorite fans. Yes, they're often less expensive...but that's because they're cheaper to make. No major 'punishment' but if it was an on-the-bubble tie for two fans, nod went to the non-sleeve bearing fan. That said, there are some EXCELLENT sleeve bearing fans available and all for under $10 a pop.
Sanyo Denki Makes Some Really Nice Stuff
I'll spoil one result for all of you upfront: the Sanyo Denki San Ace 1011 is king of the hill. And by hill I mean universe. It's really, really good. In addition to its insane empirical results (see below), it makes NO extraneous noises and undervolts like a champ. I have five and they all perform like this and they all start at 4V or lower. They could kick Chuck Norris's ass....silently.
They're ball bearings as well, so you don't have to worry about the sleeve bearing inconvenience. They also perform past their listed specs--something that's exceedingly rare in these SilenX days. Good luck finding any though...and when you do, they're $25 a pop. I also really like Sanyo Denki's Eneloop batteries (hey, I said "stuff" in the title, that implies plurality).
Not All About the Blades
Something I plan to explain further later....but 'static pressure' (realistically: radiator performance) is not ALL about the blade structure. A motor design difference (or just a bad motor design) can hurt radiator performance just as much as a bad blade design. Just want to prepare everyone for when I go into this further....
Subjectivity Need Apply
Empirical data says one thing...but it must be combined with subjective data as well. Often times murmurs, clicks, even motor thudding goes unnoticed by the test equipment. I'll report my opinion on each fan and back it up with what I can.
Don't Give Me a Hallelujah!
Do not take this as gospel. There are other reviews out there from other people and sites that test fans very well. SPCR's recent reviews (after the testbed update) are very nice and a good resource for super-low-noise folk. Cathar has also tested some fans on a radiator in the WC section...unfortunately he no longer appears active on this forum. His testing was top-notch work and even though our data didn't corroborate on every result, that's important. It means there's variability between individual fans and exactly why this shouldn't be taken as gospel. That said, our data does match significantly
Most importantly, trust your ears. If one fan sounds louder to you, that's what counts. Not what a dBA meter says--what your ears say. On the other hand, I wouldn't trust your hand for CFM measurements....at all. Really, don't do it...airflow patterns are more important than airflow quantity for what your hand will tell you.
A 250 Word Essay on Something You've Learned
Okay, I've learned a lot by testing some 50 fans with different designs. I really can look at a fan and its RPM spec and tell you how it will roughly perform. There are many key design features that lead to different fan characteristics. Blade design, motor design, bearings used, materials used, manufacturer, etc. Additionally, there are some 'rules' when it comes to approximating maximum fan performance (they're pretty damn solid ). I won't detail them here. Also remember I'm fairly reserved when it comes to passing judgement on a fan. So when I call out a fan without testing it, I'm doing it with extreme confidence because there is some glaring issue/problem/whatever with it.
One such example is the new Scythe Slipstream fans. If you have a moment, please compare CFM to RPM specs of the various fans in the series. Please remember that CFM to RPM is roughly linear, with a slight reduction in efficiency as RPM increases....now try the same thing for the Minebea series (very good CFM ratings ) and look at the numbers....tell me again those Slipstream specs aren't BS. I'm not saying they're bad fans. They may be very good in the open air, I haven't tested them....but I will say their specs (especially the 3 fastest) are in the league of SilenX and Silverstone. Their radiator performance will also be mediocre at best (probably why the Ultra Kazes were simultaneously introduced ). I don't know why manufacturers can get away with this...and worse yet, people believe them.
Bored Yet?
Enjoy the round up
__________________
Current Waterblock Testing
Roundup #2: Overall Comparison Thread, Alphacool Livingstone, Alphacool Niagara, Alphacool Yellowstone, D-Tek Fuzion V2, EK Supreme, EK Supreme LT, Enzotech Sapphire Rev A., Heatkiller 3.0 LC, Heatkiller 3.0 LT, Koolance CPU-345, Koolance CPU-350, Phobya, Swiftech Apogee GTZ, Swiftech Apogee GTZ SE, Swiftech Apogee XT
Vapor is offline   Reply With Quote
Old 12-20-2007, 02:25 AM   #2
Vapor
Admin
Vapor's Avatar
High Speed Fans
High Speed fans are starting to get less and less commonplace. Basically, for twice as much airflow resulting in at most 4-5C cooler temps resulting in only 20MHz higher on the CPU overclock, they're 10x as loud. And if you don't mind the noise, chances are every girl you'd ever meet does (unless you know sign language). That's why they're becoming less and less accepted. That said, they do have a use and on top of that there is such thing as undervolting, which is why the San Ace > Chuck Norris.
Open air:
Radiator:
Comments:
San Ace 1011 - They rock...none of my 5 had any extraneous noises at any voltage (basically the best sounding fans) and they perform awesome. At 5V, they push a lot of air and are essentially inaudible in a closed case. The blades ARE fragile....if anything gets in the fan while spinning, blades will break easily and these fans aren't cheap to replace. Do be careful.
Comair - They're beastly loud and push a lot of air. Essentially a server/benching fan.
Panaflo U1A - Carryover all-star from Round 1. Very good performer but gets whipped by the San Ace....rock solid, well built, and long-lasting NMB-MAT motors....not exactly a friendly noise profile though. Some of mine have problems undervolting as well.
Sunon 38mm - The 38mm available from Petras (and probably everywhere else...but saying Petras for model reference). It sucks....avoid it. Has a very annoying sound profile and performs poorly and well below specs.
Sunon 25mm - The 25mm variant also from Petras. It sucks as well....avoid it. Worse than the 38mm in nearly every respect so basically it's the reincarnation of your 2nd worst memory. Worst memory goes to the unlisted FM123.
__________________
Old 12-20-2007, 03:06 AM   #3
Vapor
Admin
Vapor's Avatar
Medium speed fans
Medium speed fans are slowly getting more and more accepted...people that used to get high speed fans now get these and many low speed users get these and undervolt. Also, another reason for adoption is that ot really does seem that these medium speed fans (60-80CFM at 12V) are stronger at the favored 40-50CFM range than fans built for that range. So you undervolt a little for 24/7 and get a great sweetspot of performance and noise, with the option to crank it up.
Middle speed fans are mostly where it's at....
Open air:
Radiator:
Comments:
Panaflo LH - Old fan that undervolts surprisingly well...has a few murmurs/ticks here and there. Only get it if you're into nostalgia or really aggressive (albeit useless) blade designs.
Sharkoon Golfball 2000 - The carryover king from last round gets beaten...by a few fans. Nonetheless it's still pretty damn good. No extraneous noises or ticks or anything, but the blades do make a bit more noise than competitors and it shows on the graphs.
SilenX 90CFM 18dBA - Just a plain sucky fan. Put it on a radiator and it sucks even more (really, really bad radiator fan...nearly 50% of airflow is lost on the radiator--worse than the Noctua 1200!). That said, it does not make extraneous noise and looks kinda cool. Has a cheap flimsy feel though. Also, the motor overheats. Also, it costs a lot. Also, the specs are WAYYYYYYY off, a big no-no in my book.
SilenX 74CFM 14dBA - Another bad fan. Not quite as bad or overrated as the 90/18 model, but the rest still applies.
Yate Loon D12SH-12 Curved blade from PTS - This is what Petras stocks mostly...it's a very good fan, especially for the price. Especially on the radiator. The 12V and 11V numbers are out-of-line with the expected and with what others experience and I can hear noticeable extraneous noise at those two voltages...probably something wrong with my fan specifically. I still like it too... Like most fans, it improved SLIGHTLY over its 0-hour test numbers.
Yate Loon D12SH-12 Straight blade from PTS - This is what Petras stocks occasionally...it's a very good fan, especially for the price. Especially on the radiator. Mine made no extraneous noises....it's SLIGHTLY better than the curved blade variant on the radiator, but SLIGHTLY worse in open air. I call it a draw overall. Like most fans, it improved SLIGHTLY over its 0-hour test numbers.
Yate Loon D12SH-12 Straight blade NOT from PTS - This is the D12SH-12 available from every place not named Petras Tech Shop. They DO use different suppliers and this fan IS different. It has different internals, scales differently with voltage and noticeably deteriorated from its 0-hour performance. It makes some noises I don't want my fans making: mainly light thuds and clicks. In fact, all but one non-PTS Yate Loon made extraneous noise. Oh, it also doesn't perform that well...look at the graphs.
Yate Loon D12SM-12 Curved blade from PTS - This is what Petras stocks mostly...it's a very good fan, especially for the price. Especially on the radiator. It's not as good as its ratings (56CFM vs. 70CFM rated) but overall the performance is very solid. Like most fans, it improved SLIGHTLY over its 0-hour test numbers. I really like this fan.
Scythe Minebea 1900RPM - Solidly built fan....my fan testing gets EXACTLY the same CFM as the ratings--which is shockingly refreshing. Very high MTBF...but like all NMB-MAT fans it exhibits a SLIGHT murmur or click Also has slightly higher than normal CFM loss on a radiator. Overall a very good fan though, definitely recommended and a VERY safe choice with it's longer-than-you'll-need-it MTBF and very good performance.
Scythe Minebea 1600RPM - Solidly built fan....my fan testing gets EXACTLY the same CFM as the ratings--which is shockingly refreshing. Very high MTBF...but like all NMB-MAT fans it exhibits a SLIGHT murmur or click Also has slightly higher than normal CFM loss on a radiator (slightly more so than the 1900). Overall a good fan though, but surprisingly not as good as the 1900...overall a safe choice with it's longer-than-you'll-need-it MTBF and decent performance.
Scythe S-Flex F 1600RPM - S-FDB bearings kick ass. Very, very little extraneous noise, relatively inexpensive, no positional oddities like sleeves, and fairly well sealed. They also don't have the radiator slow-down that the Minebeas exhibit. But they're also not empirically as good in open air. However, the entire S-Flex range is among my favorites. Very, very good fans that don't make extraneous noises nor cost an a lot.
Zalman ZM-F3 - The shocker of the whole group. Really, it came out of left-field. No fluke here either, Cathar got nearly identical results. No extraneous noise, magic-scaling above ~1600RPM, does well on a radiator, a mere $10 and available nearly everywhere and just overall great performance. A gem of a fan in many respects. It is a sleeve bearing though, it's only detractor.
Coolink SWiF-1202 - Crummy fan...horrible excitation at many random voltages (hence the data line jumps back and forth), just not a good performer in general either. Similar to the Akasa Amber from Round 1--and in looks, I wonder if there's a pattern?
Antec Tri-Cool - Mediocre fan. Makes more (normal and extraneous) noise than I'd like but it's nothing too bad. "H" is 12V, "M" is at just under 9V and "L" is at like 5.5V. If I had a case full of them, I'd upgrade, but maybe not get overnight shipping.
__________________
Old 12-20-2007, 03:45 AM   #4
Vapor
Admin
Vapor's Avatar
Low speed fans
Low speed fans are also getting more popular. For one, with undervolting, many become truly inaudible...and others conveniently run at ideal CFM (and with good/great dBA) at stock volts. They're easy on the ears and especially popular with watercoolers and those with MANY fans in their case. Additionally...most people have realized that even with 40CFM on the CPU cooler, you're getting within a few degrees of what an obnoxious 100CFM fan would do.
Open air:
Radiator:
Comments:
Sharkoon Golfball 1000 - The baby brother of the king of Round 1 performs well. It has a MINOR murmur that I could only hear when super close to it. At low speeds, the blade design does create a slight whiffing noise that hurts its numbers. A good fan...though nothing spectacular.
Silverstone FN121 - An All-Star from Round 1 seems to have continued to do very well...despite its retarded sibling fans too. In fact, I think it got slightly better with age. No extraneous noises or excitation of any kind and very good empirical data both on and off the radiator.
Noctua S-1200 - I have always been harsh on this fan. Although it continues to do well in the open air and even with it's awesome low-pitched barely-there noise profile, I will continue to be hard on it. Open air rarely happens....even a fan filter or a non-wire fingerguard will hamper this fan horribly. Noctua even recognizes this and has introduced a new line built for radiators/HSFs/real-life. It's a good fan with a very serious design flaw.
Yate Loon D12SM-12 Curved blade from PTS - Yes, exact same fan from the medium speed fan post....see that reference. It's a great fan, even if it is sleeve bearing.
Yate Loon D12SL-12 Blue frame and LED not from PTS - This is the darker of the two varieties from places like Jab-Tech. Like other non-PTS Yate Loons, it performed poorly and differently from PTS varieties. Internals and characteristics differed too. Not impressed with this fan. Considering a better fan for the same price is available from Petras, this fan should be avoided.
Yate Loon D12SL-12 clear frame and blue LED not from PTS - This is the lighter of the two varieties from places like Jab-Tech. Like other non-PTS Yate Loons, it performed poorly and differently from PTS varieties. Internals and characteristics differed too. Not impressed with this fan. Exhibited noticeable excitation as well. Considering a better fan for the same price is available from Petras, this fan should be avoided.
Yate Loon D12SL-12 Blue frame and LED from PTS - This is the translucent blue framed SL from PTS...its a 1200RPM variant because Yate Loon says higher RPM versions perform poorly due to material differences. (the previous two are higher RPM versions...hint hint). This fan performs pretty well but is incapable of being 'silent'....I suspect that this is due to the materials used. This is pretty nice LED fan.
Yate Loon D12BL-12 not from PTS - This is a ball bearing version of the D12SL...only available from places like Jab-Tech. Like other non-PTS Yate Loons, it performed poorly and differently from PTS varieties. Internals and characteristics differed too. This fan flat out sucks.
Yate Loon D12SL-12 All-Orange (not from PTS) - This is an all-orange version of the D12SL-12. I did not get it from PTS, though it was the only non-PTS Yate that I could not visually tell apart from the PTS fans. It also performed fairly well...although it had problems becoming 'silent.' Overall a confusing fan....it performed pretty well and very unlike its fellow non-PTS fans. Considering every other YL not sold from PTS did not test well AT ALL, I'd probably avoid it in case it was a fluke.
Nexus D12SL-12 - Also all-orange. A cherry-picked 1000RPM variant of the Yate Loon D12SL-12. Superb noise profile...no excitation or extraneous noises. Though empirically it didn't do great for some reason. I definitely liked this fan a lot.
Sunbeam Blue LED fan from Petras - A competitor to the YL D12SL-12 Blue LED...a bit more high-strung and a brighter blue. Like the YL, it has problems going 'silent' though it makes little extraneous noise. I'd probably get the YL over it....
Scythe Minebea 1100RPM - Solidly built fan....my fan testing gets EXACTLY the same CFM as the ratings--which is shockingly refreshing. Very high MTBF...but like all NMB-MAT fans it exhibits a SLIGHT murmur or click Poor radiator performance due to higher than normal CFM loss on a radiator (much more so than the 1900). Overall a good fan though...overall a safe choice with it's longer-than-you'll-need-it MTBF and good performance.
Scythe S-Flex E 1200RPM - S-FDB bearings kick ass. Very, very little extraneous noise, relatively inexpensive, no positional oddities like sleeves, and fairly well sealed. They also don't have the radiator slow-down that the Minebeas exhibit. But they're also not empirically as good in open air. However, the entire S-Flex range is among my favorites. Very, very good fans that don't make extraneous noises nor cost an a lot.
Scythe S-Flex D 800RPM - S-FDB bearings kick ass. Very, very little extraneous noise, relatively inexpensive, no positional oddities like sleeves, and fairly well sealed. They also don't have the radiator slow-down that the Minebeas exhibit. But they're also not empirically as good in open air. However, the entire S-Flex range is among my favorites. Very, very good fans that don't make extraneous noises nor cost an a lot. Admittedly the "D" variant is a little underpowered 12V for my tastes...
Enermax Marathon - Positional quirks in the weirdest ways...subpar performer. Overall a mediocre and forgettable fan like all of Enermax's fans.
__________________
Old 12-20-2007, 04:10 AM   #5
Vapor
Admin
Vapor's Avatar
My favorites
In Round 1 I made a graph of "All-Stars" that was originally misinterpreted....all I did was take the best from each class and put them together to show that the best medium speed fans were the best overall performers. Turns out, people took the name "All-Stars" not-so-literally and thought they were my recommendations. They may have been the better fans empirically, but at the time they weren't my recommendations. I wouldn't have recommended the U1A at all (too loud and undevolts poorly) and the YL SL I had tested made a few funky noises every so often and was getting worse over time. That and it just wasn't up to the performance that the Sharkoon and ebmpapst were exhibiting, so why would I recommend it?
Well, the number of AWESOME fans in this roundup was a lot higher and these are true recommendations with reasons listed below
FWIW, the order in the chart legend is the order of my personal preference as well.
Open Air favorites:
Radiator favorites:
Comments:
All-purpose awesome fans:
San Ace 1011 - This fan really is in a league of it's own....yeah, the Zalman may 'catch up' on the radiator...but the San Ace isn't a sleeve bearing and is overall better construction. It is the real deal and somehow better than every other fan...ESPECIALLY in open air.
Zalman ZM-F3 - The surprise of the bunch catches up to the San Ace on the radiator, but overall it's still not quite as good....though definitely an awesome, awesome fan.
Scythe S-Flex F - Another great fan a lot like the Zalman, but also not a sleeve bearing fan. No excitation, no extraneous noise....just a great fan (gets near-'silent' at 5V too, which is rare for a medium speed fan).
Yate Loon D12SM-12 Petras - An unbeatable value....98% the performance of the S-Flex and the Zalman for fraction of the cost. It's overrrated (surprising considering the SL is slightly underrated), but a very, very good fan
Scythe S-Flex E - The silent-friendly fan of the bunch...easiest to make 'silent' while also having great otherwise performance. It's also a wonderful S-FDB bearing fan that has little downside.
Case fans:
Scythe Minebea 1900 - A great performer in open air but falls back a little on a radiator...great MTBF, non-sleeve bearing fan and a good price.
Scythe Minebea 1100 - Also a great open air performer that falls back noticeably on a radiator....great MTBF, non-sleeve bearing fan and a good price.
Silverstone FN121 - I rue giving this company any accolades, but the fan does perform once again. Unlike its sibling fans, it actually is rated appropriately too. It gets 'silent' in a hurry and makes no extraneous noises. It does fall back a little on the radiator and is sleeve bearing.
Radiator specialist:
Yate Loon D12SH-12 from Petras - Included the data from the straight blade version just to keep the atypical 11V and 12V numbers from the curved version from dissuading anybody. This is a very, very good fan on a radiator with surprisingly little CFM loss (has to do with the low CFM:RPM ratio in the open air ). No extraneous noises at a great price with performance better than the Minebea 1900 on a radiator puts this on my favorites list
__________________
Old 12-20-2007, 04:13 AM   #6
Vapor
Admin
Vapor's Avatar
Yate Loon comparison
Yate Loons are a big deal. In modern computers, we've shifted toward numerous large, quiet fans...so price becomes more noticeable in end-cost. And they're the least expensive fans you can buy, come in many varieties, and ultimately, pretty damned good. Actually...some are great and others suck.
In my testing: one thing became very clear, the one variable for determining quality is place of purchase. Petra's Tech Shop Yate Loons outperformed the others by quite a bit. And most importantly...they performed differently. They had different physical characteristics.
Simply, Petras has different Yates than everyone else.
Further investigation and chatting brought up this important fact: Petras is the only retailer to deal directly with Yate Loon. Other retailers (Jab-Tech, P-PCs, etc) unfortunately use a middle-man. This middle-man can apparently sell them fans at costs below what Yate Loon would sell to them, so the business choice was clear.
Why did Petras stick with Yate Loon directly? Not sure...but we should be glad they did. Their $4 Yate Loons are among the best-as-tested fans, competing and beating fans 2-6 times their price. Furthermore, they really don't have any 'bad' qualities other than being sleeve bearing (which isn't a bad thing for most people, but it makes a difference for some).
How are PTS fans different from non-PTS fans:
1) different voltage scaling. 12V may be similar...but at 5V the non-PTS fans spin noticeably slower (but aren't that much quieter, if at all). This could be a good thing, but it does sacrifice tunability in the mid-range.
2) different radiator performance. The fans may have identical blade structures, but put them both on a radiator and suddenly the non-PTS is sucking wind. PTS Yates have CFM-loss numbers comparable to most 38mm-thick fans. They're excellent on radiators.
3) different performance growth over time. 0-hour numbers are very similar. That is, take the out of the box, plug them in and test, and they appear to be the same. Run them both for 24-hours and retest and like most fans, the PTS Yates get 1-2% better. The non-PTS fans drop back nearly 10% and often develop odd noises. Ultimately, performance for the long-term is important, not performance right when you get them. PTS fans have a major advantage here.
4) external appearance. There are minute differences in external appearance, the 5xx are very noticeable, 6xx less so, and 7xx nearly or exactly identical. This means that new fans are no longer externally discernible. This is not a good thing...at least with the older fans you could pick them up, look at them, and know which one was the good one.
5) internal appearance. PTS has done a take-down of some of the various offerings and the internal differences were shocking. Nothing 'bad' necessarily, but it was clear they are very different fans.
So yeah, they're different fans, let's see some graphs and show the performance discrepancies.
Open Air:
Radiator:
CFM vs. CFM-loss%:
(hint for this graph: separate them into two separate groupings: black plastic fans and clear plastic fans...)
Okay...I think I've said enough on the subject and I'll let the numbers do the talking
__________________
Old 12-20-2007, 04:13 AM   #7
Vapor
Admin
Vapor's Avatar
Reserved for further comparisons.
__________________
Old 01-02-2008, 05:20 AM   #8
Vapor
Admin
Vapor's Avatar
This is a copy of the main body of my thread from Air cooling. I feel it can be of assistance to many in this section and have stuck it here as well.
For the previous discussion, please read this thread:
http://www.xtremesystems.org/forums/...d.php?t=170224
Thanks for looking
__________________
Old 01-02-2008, 08:26 AM   #9
smee
smee's Avatar
Wow!
Great review vapor!
Thanks so much for doing this
Another fan I would like to have tested/reviewed is the Tt Silent Wheel 130mm.
__________________
[PROJECT] "Theblank.box" - Supported by: (UN) Designs, PetrasTechShop and Bitspower.
[theblankbox.net] - A build I've planned for ever so long, is finally becoming a reality.
[My Comp] Dell XPS Studio 13 || Intel P8600 2.8GHz || NVidia 256MB 9500M || 4GB 1066MHz DDR3 ||WD 500GB 5400RPM || Windows 7 RC1 Build 7100
Connected: Samsung 2220WM 22" || Creative 2.1 Speakers || Logitech Illuminated Keyboard || Logitech G500 Mouse || Skullcandy Buds
[Network]
2Wire 2701HG-B /Bridge Mode (as Modem) || Buffalo WHR-HP-G54 w/Tomato Firmware 1.25 || Trendnet TEG-S80G 8-Port Gigabit Switch
[NAS Box]
Intel Atom 1.60GHz || ASUS AT3GC-I || GMA950 || 1GB 667MHz Crucial || 250W PSU || 2X Samsung 1TB HDs || Windows Home Server SP1
[Flickr] - Canon 30D || 28-135mm f/3.5-5.6 IS USM
smee is offline   Reply With Quote
Old 01-02-2008, 08:36 AM   #10
Exahertz
Exahertz's Avatar
Excellent Work! Thanks Vapro!
So is there anything we can do to combat the bad lubrication? I have heard of ppl peeling back the sticker and shooting something like vegetable oil in there every few months or more. Any other ideas?
I have a bunch of Yate's and i want to keep them going for as long as i possibly can.
__________________
Current System Build
Designaton:" Rad Hat "
__________________
  • Mother Board, RAM and CPU:
    Mobo: Asus Maximus Formula (SE) BIOS 1207 | CPU: Intel q9650 @ 3.80GHz Vcore 1.272v | RAM: Crucial Ballistix Tracer PC2 8500 4x1GB
  • Graphics Processor:
    GPU: BFG 8800GTX | BFG 8600GT (Quad Monitor Setup)
  • Hard Drives:
    RAID: 2x 74GB Raptors on RAID 0 for OS Drives
  • Case and Power Supply:
    Case: Antec Case | PS: OCZ ProXstreame 1000W
  • Water Cooling:
    Pump: Swiftech MCP655-B | Rad: Dual Swiftech MCR320's | Fans: 6x Yate Loon D12SH-12's (W/ Variable RPM Rheostat) @ 88CFM Max Each - 528CFM Total!!!
  • (Water Blocks and Fittings):
    CPU: D-Tek Fusion Block | GPU: Danger Den Full Coverage 8800 Block | Mobo: EK's Mosfet, NorthBridge and SouthBridge Blocks
    Res: Swiftech Micro | Tee's: 4x MartinM's High Flow Copper Tee's | Elbow's: None | Y's: None
Flow Order: >> Rad's 1 & 2 in parallel > Res > Pump > CPU > GPU > SB > NB > Mosfet 1 > Mosfet 2 >>
Temperatures: CPU: 57°C Max, Running Prime95 | GPU: 58.3°C Max, Running 3Dmark | NorthBridge: Untested!
Last Updated 11/11/09
Exahertz is offline   Reply With Quote
Old 01-02-2008, 08:39 AM   #11
MorGo7h
MorGo7h's Avatar
Any idea of the scythe kamikazes ultra's? Good fans for rad cooling?
__________________
System: E8400 // P5Q-E // Ballistix // HD3850 // HX520 http://valid.x86-secret.com/show_oc.php?id=419486
Thermochill pa120.3 // D-tek FuZion bowed+ costum nozzle // MCW60 // EK150 // dcc1 18w w/top
MorGo7h is offline   Reply With Quote
Old 01-02-2008, 08:44 AM   #12
emoners
emoners's Avatar
wow! Thanks for the info Vapor...GREAT review!
but now i'm just more confused which one to get
__________________
Project B.I.L.H.A.T.: ZOTACź GeForce™ 9300-ITX WiFi Rev.01 (+ Noctuaź NC-U6) | Intelź Core2Duo™ E7400 Wolfdale SLB9Y (+ Scytheź Shuriken™) @stock voltages | OCZź NVidia SLI-Ready DDR2-6400 2x2Gb | PowerColorź ATI™ Radeon HD4770 | Western Digitalź Caviar™ Black 1Tb | Silverstoneź SG05 | Windowsź 7 Ultimate 32-bit
RETIRED:
• DFIź LanParty UT P35-T2R Rev A02 (05/21 Bios) | DFIź LanParty JR P45-T2RS Rev A03 (10/07 Bios) | Intelź D945GCLF2 Little Falls-2 | Intelź Core2Duo E6850 Conroe L723A348 | Intelź Core2Duo E8400 Wolfdale Q746A446 | Intelź Core2Quad Q6600 Kentsfield L723B837 | Intelź ATOM™ 330 | XFXź NVidia GeForce 8800GTX | XFXź NVidia™ 8800GT XT Alpha Dog Edition | Creativeź Sound Blaster X-Fi Fatal1ty XtremeGamer Pro
emoners is online now   Reply With Quote
Old 01-02-2008, 01:12 PM   #13
ferrari_freak
ferrari_freak's Avatar
Send a message via MSN to ferrari_freak Send a message via Yahoo to ferrari_freak
Those Zalman's are a real suprise. I'm sad to see that the LED YLs don't perform that well though I was going to get a few for looks and silence in one.
__________________
Originally Posted by jimmyz View Post
A DFI board is like a divorce, expensive, but well worth it.
Originally Posted by virtualrain View Post
I dunno... I think a DFI board is more like marriage... demanding, time consuming, and a PITA but rewarding in it's own twisted way.
ferrari_freak is offline   Reply With Quote
Old 01-02-2008, 01:35 PM   #14
MrToad
I am Xtreme
MrToad's Avatar
Finally this thread is stickied in the forum it belongs to ^^
Thanks a lot, your work really helps to make an informed decision
MrToad is offline   Reply With Quote
Old 01-02-2008, 08:09 PM   #15
Fush
hot review!111111
Fush is offline   Reply With Quote
Old 01-02-2008, 08:41 PM   #16
septim
Banned
Send a message via Yahoo to septim
oh well, this beats linking everytime someone ask for the best rad/all around fans out there...
thanks again vapor...
septim is offline   Reply With Quote
Old 01-02-2008, 08:51 PM   #17
Boogerlad
can u test this air pusher? http://inventgeek.com/Projects/IonCooler3/Overview.aspx i wanna use that on my rad but fear that it has like zero static pressure.
Boogerlad is offline   Reply With Quote
Old 01-02-2008, 11:10 PM   #18
Jedda
Xtreme Mentor
I routinely lubricate my Y-L fans with sewing machine oil (couple of drops) before installing.
Vapor
Great info! Thanks mate.
__________________
V-Twin WIP
Q6600 G0
EVGA680i
4GB OCZ
8800GTX
LC - Dual loops.
Dual 20.1 monitors.
Jedda is offline   Reply With Quote
Old 01-02-2008, 11:52 PM   #19
Sideroxylon
Sideroxylon's Avatar
GREAT WORK!!!! That's some good stuff. Thanks for the hard work and info.
__________________
Intel QX6700 @ 3.2g------------------------Cooled by
ASUS P5B Deluxe--------------------------D-Tek Fuzion
2g Corsair XMS2 8500---------------------EK FC88 GTS
BFG 8800GTS 512 OC (G92)---------DDC 3.2 w/ Petra's top
2xWD 150g Raptor (raid 0)------------------PA 120.3
2xWD 74g Raptor
SB X-FI Gamer Extreme
Logitech Z-680 speakers
Silverstone TJ07 case
Sideroxylon is offline   Reply With Quote
Old 01-03-2008, 12:49 AM   #20
qdemn7
qdemn7's Avatar
Vapor
Mind posting some pics showing just how you do it?
__________________
DFI LP LT X38 TR2
Yorkfield Q9450
2 x 2048MB G. Skill PC2-8000
BFG 8800 GT OC
Asus 1814 BLT SATA DVD-RAM x 2
Seagate 1TB SATA II x1
Samsung 300GB SATA II x 1
Silver Stone SST-ST60F
Dell 2405FPW
Thermalright Ultra 120 Extreme
Thermalright HR-05 SLI
HSPC Large Top Deck Station
XP Pro SP3
qdemn7 is offline   Reply With Quote
Old 01-03-2008, 06:32 AM   #21
Master_G
Great work, and a surprisingly easy read for something so quantitative, a huge thanks for all the work you have put in to make this happen.
G
Master_G is offline   Reply With Quote
Old 01-03-2008, 03:28 PM   #22
serial099
serial099's Avatar
I went with the sharkloon 2000's on my rig due to your last round-up and while a few fans seem to be better performers on this round-up I'm definetly not upset at all I went with these. They look like a real good solid fan still.
__________________
Rig info
M/B: ASUS M3A79-T Deluxe | CPU: AMD Phenom 9950 BE | GPU : ATI 4850 x2 2048mb connected to 1 LG 22" LCD and 1 19" LCD| RAM : 4x2gb OCZ Platinum 1066MHZ | 3 Seagate Barracuda hard drives 1 250 GB, 1 320 GB, 1 1TB
Watercooling setup: 2 radiators : 1 Thermochill 120x2, 1 Thermochill 120x3, 8x Sharkloon Golfball 120mm fans, 1 Swiftech MCP 655-B pump, Tygon tubing, D-tek Fuzion v2 CPU block, 2 MCW-60 GPU blocks, Swiftech Micro-Res
serial099 is offline   Reply With Quote
Old 01-03-2008, 04:31 PM   #23
disruptfam
I am Xtreme
disruptfam's Avatar
Send a message via MSN to disruptfam
could you add
scythe kaze ultras- and
scythe slip streams
please
__________________
Originally Posted by skinnee View Post
No, I think he had a date tonight...
He and his EK Supreme are out for a night on the town!
disruptfam is offline   Reply With Quote
Old 01-04-2008, 04:08 AM   #24
dnb#
dnb#'s Avatar
Send a message via ICQ to dnb#
this sticky rocks! good job mate, this is really going to help the WC section.
__________________
The multiple screen Wallpaper topic!: http://www.xtremesystems.org/forums/...d.php?t=190723
The System wallpaper topic!: http://www.xtremesystems.org/forums/...d.php?t=180050
dnb# is offline   Reply With Quote
Old 01-05-2008, 12:24 PM   #25
lazy
[XC] Lazy Cruncher
lazy's Avatar
Wow... very thought-out review.. thnx Vapor!
__________________
Under Construction------
MM H2gO - On Air for now /////
Coming Soon...
lazy is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
