11-24-2007, 01:52 AM
#1
Banned
9500 running in M2N-SLi deluxe
Ok, I recieved my 9500 yesterday and tested it in an M2N-SLi deluxe mobo. I have both 790X and 790FX boards from MSi to test aswell but wanted to see how well a quad would fair in an AM2 mobo.
Firstly the ASUS M2N-SLi deluxe mobo wouldn't post with the 9500 inplace until flashed with the latest bios (1302). After a quick flash of bios, system posted and proceeded to boot no problem.
Now, I had to spend a few hours battling with this new bios since it would seem to have a few bugs. Since flashing the bios to 1302 I no longer have access to the cpu multi from within the bios, nor can I set the northbridge multi (since this is AM2 mobo not AM2+). In windows speedfan no longer works, neither does memset (not for this chipset) nor AM2tools
On the bright side though AMD-overdrive and Ai booster perform well, excluding the 3 different memory speeds I see reported by AMD-overdrive/cpuz/everest.
I'm sorting out my screenies at the moment, I'll post cpuz screeny and a few bench screens in a couple of mins.
so far in the AM2 mobo, 2700mhz on stock volts.
stepping is as follows
11-24-2007, 02:10 AM
#2
Thnx for the info.Keep posting plz
__________________
24/7    24/7
11-24-2007, 02:17 AM
#3
Banned
good luck with that cpu!
11-24-2007, 03:47 AM
#4
Banned
here we go.
2706mhz in AM2 mobo on stock volts. Need more time to mess around but I'm positive the NB speed is the wall here. CPU runs very cool on stock HS with chilled air.
Since I can't access the cpu multi the system boots at 1100mhz, a simple increase of multi within amd overdrive sorts that out, then I use Ai booster to increase the cpu fsb since overdrive's fsb slider is non functional on this mobo.
I've included a few quick bench scores at 2700mhz as promised  low mem speed just now until I figure this out.
3D 06 CPU, CINEBENCH, EVEREST, CM9, NUCLEARUS
11-24-2007, 03:50 AM
#5
Good mate!!!Keep pushing it!!
__________________
24/7    24/7
11-24-2007, 03:55 AM
#6
Banned
Cm9 & Nuclearus
11-24-2007, 04:19 AM
#7
Banned
can you show the latencies of the caches with cpu-z?
thx in advance
11-24-2007, 05:04 AM
#8
o man i want one so bad!!!!
2.7 not bad! push that sucker past 3!!!
__________________
cpu- AMD Phenom II 940 @3.0ghz...... for now
Asus M3A78-T 790GX
2x HD4870 cat 9.2
2x 1gb ddr2-1066
corsair 750 Watt
CM690
Originally Posted by perkam
Even McDonalds wouldn't hire Hector, at the risk of him reducing the efficiency of the burger grill
11-24-2007, 05:45 AM
#9
About farking time someone got one of these and put it through the paces.
What temps are you getting? RAM settings?
Would like to see:
Geekbench, SuperPi, Prime95 multicore stability test
11-24-2007, 06:03 AM
#10
Xtreme Cruncher
well done
mstp, you can see the ram timings in the pics from lavalys everest, 4-4-4-12 cr2
__________________
XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.9ghz @1.32v under load, corsair dominator ddr2 1066 4gigs, evga gtx260 core 216, pc p&c 750W, TRUE Black, Lian Li v1200b
silverstone tj07 build log
11-24-2007, 06:04 AM
#11
Xtreme News
Great!
Thank you very much AMD-PHENOM!
Now where are those people saying AM2 compatibility with Phenom is non-existent? Even my MSI K9N Ultra had BIOS updates for Phenom over one month ago....
Nice to see ASUS sorted that issue as well  .
I'm getting my Phenom probably end of next week  . Looking for GP9600  !
__________________
RiG1: Phenom II 940BE 0850BPEW (45nm@3850MHz 64bit), Gigabyte MA790FX-DQ6 (RD790FX), 2x2GB OCZ Reaper PC8500@1145MHz 5-5-5, HD5870 1GB, 2x1TB Samsung F1 RAID0 + 750GB Samsung F1 + 400GB Samsung T133 + 30GB OCZ Solid SSD, Hiper 4M880
RiG2: HTPC AMD Athlon II 250, 2GB Crucial Ballistix D9, ASUS M3A78-EM, ASUS HD4670 512MB, 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH
SmartPhone T-Mobile Compact V
XBOX360 Elite paired with 52''  Samsung LCD TV
11-24-2007, 06:31 AM
#12
AMD™ 10h&RV770 cruncher
AMD-PHENOM,thanks a bunch man!
I am really satisfied with the ~4K CPU score in mark06!Done at 2.7Ghz and is really good.For comparison,Yorkfield@3Ghz gets around 4500.
Have you played with Vcore and what are the temps for cores under load @OC speeds.
Keep up the nice mini review
__________________
Quick dictionary lesson:Bulldozer : n. 1. A multi-threaded performance-oriented x86 processor core contained in the “Zambezi” processor for client PCs and “Interlagos” and “Valencia” processors for servers. Included in the “Scorpius” desktop PC platform and “Maranello,” “Adelaide,” and “San Marino” server platforms. “Bulldozer” will be a completely new, high performance architecture for the mainstream server, desktop and notebook PC markets that employs a new approach to multithreaded compute performance for achieving advanced efficiency and throughput. “Bulldozer” is designed to give AMD an exceptional CPU option for linking with GPUs in highly scalable, single-chip Accelerated Processing Unit (APU) configurations. 2.A heavy, driver-operated machine for clearing and grading land, usually having continuous treads and a broad hydraulic blade in front 3. An overbearing person; a bully.
11-24-2007, 07:09 AM
#13
that cpu score is pretty good, on par with a kentsfield. maybe high nb clock is what helps k10 performance?
__________________
Core i7 920 3849B028 4.4ghz cooled by gtz | 12gb gskill ddr3 1600 | Sapphire HD4870x2 cf cooled by xspc fc | Asus Rampage II Extreme | 600gb Velociraptor Raid 0 / 1tb + of storage | Modded Rocketfish case + 1200w toughpower | mcp 655 pump + mcr 320 + black ice pro II
11-24-2007, 07:33 AM
#14
Hi AMD-Phenom,
Can you post some results that include graphics performance as I notice that so far you've only included CPU performance, i.e. only run the CPU tests...
I've been finding that with my M2N32SLI that there are some major issues with the graphics perforamance, and my current thinking is that it is a compatability issue, to do with the NB, PCI-E, HT issues within the BIOS...
I'd be really grateful if you can provide some insight into the graphics issues..
I've also been having problems with my RAM, and any attempt to get the RAM to run as rated via the SLI profiles results in a failure to POST...
I can't make any changes within the BIOS either, if I do then POST fails, do you experiece similar problems....
Perhaps if I try using the AMD OVerdrive, instead of the BIOS to make system changes then I may have more luck.....but I'm more accustomed to making these changes via the BIOS....
Appreciate any insight you can give into the above....
PS. Which version of CPU-Z are you using as when I tried 1.41 it didn't show a HT Link Speed, and neither did v.1.42, though v. 1.42 does dipslay the Phenom logo rather than the AMD logo..
11-24-2007, 07:36 AM
#15
Indeed.Lets hope the TLB bug won't stop people from running NB @higher clocks.I expect to see a nice boost when NB is run near core clocks or even higher.Should reduce L3 latency greatly and improve mem. bandwidth(both of these are way off the standard RevF which hampers Phenom a lot)
__________________
11-24-2007, 08:16 AM
#16
How about running cinebench? I want to see +3GHz.
__________________
C2Q Q6600@3.6GHz
Asus P5Q Pro
Kingston Valueram 2x2GB PC6400 CAS6
Club 3D GTX295
Benq G2400W
WD 6400AAKS & 3200AAKS & 2x 2500JS & 10EADS
Coolermaster HAF932 + Chieftec CFT-1000G-DF
11-24-2007, 08:42 AM
#17
yep, same here. i'm mostly interested in 3d performance. if this chip can show that it can oc to 3.4+ and keep up with a kentsfield clock for clock if the nb is clocked higher than stock, i will reconsider phenom.
__________________
11-24-2007, 09:11 AM
#18
I haven't seen any OCs near 3 Ghz yet.
__________________
Intel E8400.C0 "Wolfe"| 400x9 3600 Mhz @ 1.272 Vcore
TT Sonic Tower | Dual 120mm Antec Fans | Silent Air @ 1200 RPM
ASUS P5Q-E | BIOS 0610
G.Skill F2-8000CL5-2GBPQ | 400 MHz (5-5-5-15) @ 2.0 V (? Auto)
XFX 7800GT
Wester Digital Raptor 74GB | Maxtor Maxline III 300GB | Seagate 7200.7 120GB
Antec P-180 | Antec True Power 2.0 550W
Dell 2407 | Dell 2405
11-24-2007, 09:32 AM
#19
Well in fairness "AMD-PHENOM" has got to 2.7GHz on stock voltage at the moment and with an AM2 mobo with IMO a flakey BIOS.
So 3.0GHz shouldn't be out of the question, once BIOS issues are resolved and on a AM2+ mobo as well..... its still very early days, and I know speaking for myself, that BIOS and compatability issues are whats holding me back, until I can get a fully compatible BIOS and full system compatability then I don't see the point in trying at the moment....
I'm sure once mobo manufacturers catch up, and get some decent BIOS' to support Phenom, then more and more users will be able to try to OC the Phenom and more results will become available.
I'm itching to try to OC my 9500, but I'm stuck waiting for a GOOD BIOS from ASUS rather than the severely limited one thats available at the moment....
11-24-2007, 09:40 AM
#20
Banned
Oh no3s..
11-24-2007, 12:27 PM
#21
Heres a WPrime comparison for you, the 6400+ @ 3520MHz and the Phenom @ stock 2210MHz, as I can't OC at the moment with the current BIOS for my mobo.
BTW My stepping is: CAAZB AA 0743 FPFW
6400+ @ 3520MHz
Phenom 9500 @ 2210MHz
So a nice little improvement given the lower clocks on the 9500, a good OC on the Phenom will see some nice gains I'm sure..... now if only ASUS will give us a better BIOS.....!!!!
11-24-2007, 12:44 PM
#22
6400+ @ 3520MHz
Its time...
to test the chip with a 790FX mobo
11-24-2007, 12:51 PM
#23
LoL...yeah...unfortunately my bank mangager disagrees and is forcing me to stick with this AM2 mobo for the time being.....!!!!
11-24-2007, 12:59 PM
#24
quoting from southpark
" Those Bastards! "
__________________
Asus M3A78-T 790GX
2x HD4870 cat 9.2
2x 1gb ddr2-1066
corsair 750 Watt
CM690
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
