Hey guys, this will be my first real case mod/project log. I've liked the Lian Li V1200/2000's for a while and was quite disappointed when they were discontinued almost a year ago for the new ones that are regular ATX. A couple weeks ago I shelled out the cash for a v1200b plus II while they can still be found and have decided to make this the case for my main rig and my TJ07 will become my media pc case. I spend more time on/next to my main rig and if I am gona get a new case I want to be able to look at it.
Hardware is pretty much what I have listed in sig but will be upgrading my vid card, most likely to a gtx 260 core 216. I will be sticking with air cooling...for now (can't afford water) but I may upgrade to a TRUE and see if I can get my OC any higher. I'm currently at 3.5ghz but have been able to boot at 3.9ghz 1.4vcore in bios but load volts is more what i'd be worried about since I crunch WCG and am at full load 24/7. I like keeping my temps around 45C at load according to everest, any higher makes my room too hot.
Hardware:
Asus Maximus II Formula
Intel Xeon X3330 ES
Corsair Dominator 2x 2gb 1066
Evga 7900gs → too be upgraded
PC P&C 750W
I want to keep this looking clean and love what I see around here of cases with black interiors (like murdermod's and boxes, clean and black) so my first step was to get the interior powder coated black. When I ordered the case I sent it straight to Cyberdruid and had him work his magic. A week later I received the case and must say that it is stunning. My jaw dropped when I pulled the side panel off.
enough of my babble, on with the pics
yes, actually taken after the top was cut cause the first set of pics were grainy and i couldn't justify showing them
showing the contrast between the gray of the hard drive rails and black of the powder coat
Since there is only 1 fan in the top half of the case (ignoring the pci bracket fan cause I won't be using it especially once I get a window), I wanted space for more fans and the best place is the top panel. So, the next thing on my list of mods was to cut the top panel for a 2x120mm rad gill.
While reading charles_h's newest project log, I got an idea on what to use to cut the pattern out. I don't have a RotoZip and am not going out and buying one just for this. I do have a dremel and like the idea of the bit instead of using cut off wheels. So, I used the bit pictured below and set the speed to 8
I was able to cut out the pattern pretty quick, threw on the sanding wheel and touched up an edge or two and am quite happy with the results of my first major cut. One edge is a little wavy but I can fix that later. If I could do it again i'd clamp down a strip of wood or something to use as a guide to help keep me straighter.
