Page 1 of 4 1234 LastLast
Results 1 to 25 of 100
Thread: FINALLY rebuilt my MM UFO Horizon - NOW WITH PICS!
    Xtreme Cruncher
    Jan 2006
    Kuwait for another few years!
    Hey guys,
    I lost my Southbridge on my EVGA 680i AR back in mid-late July. I RMA'd the board for an A1, and decided what the hell, may as well redo the loops and toss in a Q6600 while it's all down. Well, after over 2 months of downtime due to EVGA dragging their feet on my 680i RMA as well as time/work constraints, I have finally completed the complete rebuild of my main rig. One or two of you may remember my build from: http://www.xtremesystems.org/forums/...d.php?t=148403. While I was happy with the previous setup, I'm practically ecstatic with the quad core and the performance I've been able to squeeze out of it.
    The changes I made were:
    1. Replaced lapped E6600 with stock Q6600 (thinking of lapping it)
    2. Bowed FuZion by installing o-ring between top and mid sections
    3. Moved the CPU loop from the PA120.2 at bottom/rear of case being fed case air to PA120.3 getting fresh air at top/front
    4. Added a second DDC2 to each loop for safety/redundancy/extra flow
    5. Replaced both T-lines with Swiftech MicroRes's
    6. Replaced 2x320gb RAID0 with 2x500gb RAID1
    7. Replaced 700W Seasonic M-12 with Enermax Galaxy DXX 1000W
    8. Sleeved all fan/lighting wires with black sleeving and heatshrink
    I finally reached the sweet spot between speed/heat/voltage last night, and the CPU has been priming now for almost 13 hours now. (Assuming it hasn't failed; I'm at work.)
    Right now it is running at 3.7ghz @1.425Vcore (in BIOS), which I was only able to do after pencil-modding my 680i. Before performing the Vdroop mod, I could not get above 3.3ghz @1.475V, as Vcore would drop from 1.46V to 1.40V under load as reported by Speedfan. After Vdroop mod, with Vcore set to 1.425 in BIOS, Speedfan shows 1.41 idle and 1.42 load.
    My temperatures at this speed/voltage are 32-33degC idle and 48-49degC load. These are the same temps I was at with my lapped E6600 at the same speed! I've seen others getting about 10deg difference just from lapping their Q6600, and I'm debating on whether I want to lap mine or not. Also, Speedfan shows my 8800's running at 44-45degC idle.
    EDIT: PICS! Also, my idle temps seem to have gone down a bit, probably due to cooler ambient temps... Now this thing idles at 29-30C!
    Main Rig:
    Q6600 G0 @3.7ghz 1.425V - EVGA 680i A1 (Vdroop mod) - 4GB G.Skill HZ DDR2-800 @1000mhz - EVGA 8800 Ultra SLI @710/2460mhz - 2x WD Raptor X 150GB RAID 0 - 2x WD 500GB RAID 1 - 1x WD 320GB eSATA External - SB X-Fi XtremeMusic - Enermax Galaxy DXX 1000W - NEC 16X DVD±RW DL - 2x Dell 2405FPW (Dual monitor w/ SLI!) - ATI Radeon X300 - MM U2-UFO Horizon
    Dual loops:
    D-Tek FuZion (Bowed) - PA120.3 - Dual DDC2+ w/ PT tops - Swiftech MicroRes - Distilled w/ Red UV dye
    2x EK FC8800 - DD680i NB - PA120.2 - Dual DDC2+ w/ PT tops - Swiftech MicroRes - G11 UV
    Temps: 28-29degC idle / 46-48degC load with MX-2! Pics of my build!
    Dedicated Cruncher:
    Lapped E6600 @3.6ghz - MSI P35 Platinum - 2GB Crucial Ballistix DDR2-800 @933mhz - MSI 8500GT - 320GB WD - Lapped Big Typhoon - Seasonic M12 700W
    Xtreme Mentor
    Feb 2007
    Tried P31? The changelog promises great things for O'Cing quads.
    I'm trying it tonight.
    V-Twin WIP
    Q6600 G0
    EVGA680i
    4GB OCZ
    8800GTX
    LC - Dual loops.
    Dual 20.1 monitors.
    Xtreme Cruncher
    Jan 2006
    P31 chipset? I had the Q6600 in my P35 cruncher temporarily while sorting out the Horizon business, and I was able to hit 3.4ghz on air without issue, limited only by temps. I almost cried when I put the quad under water on the 680i and couldn't get it stable past 3.3ghz. If you guys haven't done the 680i A1 Vdroop mod, DO IT NOW!
    Main Rig:
    Dual loops:
    Dedicated Cruncher:
    Xtreme Mentor
    Feb 2007
    Sorry, no P31 bios. The new evga bios was released for our 680i boards yesterday.
    First reports on it are very positive.
    V-Twin WIP
    Q6600 G0
    EVGA680i
    4GB OCZ
    8800GTX
    LC - Dual loops.
    Dual 20.1 monitors.
    Banned
    Jun 2006
    in a Red Rage D....
    bring out the lapping kit...
    and bring on the pictures...
    Xtreme Cruncher
    Jan 2006
    OMG i had no idea there was a new BIOS out. My RMA came with P30 and I looked the other day after building and saw that P30 was still the latest. I will flash as soon as I get home tonight!
    septim, I'll probably lap this weekend. If I can run somewhere between 3.8-4.0ghz with the P31 BIOS and keep the vcore under 1.5V, I will definitely lap to drop the temps back down to an acceptable range.
    Main Rig:
    Dual loops:
    Dedicated Cruncher:
    Xtreme Mentor
    Feb 2007
    Quote Originally Posted by RX7boricua View Post
    Yeah, I guessed that from your post and thought you'd want to know.
    Especially with the change log being all about O'Cing.
    V-Twin WIP
    Q6600 G0
    EVGA680i
    4GB OCZ
    8800GTX
    LC - Dual loops.
    Dual 20.1 monitors.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Not to burst your bubble, but I've heard that the temp readings on the Q6600 G0 is off by 15 C...
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Xtreme Cruncher
    Jan 2006
    Sparky, Coretemp reads the temp correctly, and I have set the offset to +15 in Speedfan. :P
    Main Rig:
    Dual loops:
    Dedicated Cruncher:
    Xtreme Cruncher
    Jan 2006
    Flashed to P31 BIOS last night Jedda, but didn't have any time to do any tweaking, I was busy getting my yearly DSL contract renewed and taking pics which can now be seen in the original post. :P 446 Kuwaiti Dinar a year for 1MB DSL sucks butt. 446KD = $1600 US!
    Main Rig:
    Dual loops:
    Dedicated Cruncher:
    Xtreme Mentor
    Feb 2007
    Wow, I thought we were over charged for bandwidth here in Oz, but that's ridiculous!
    Great pix. It's a really nice layout.
    V-Twin WIP
    Q6600 G0
    EVGA680i
    4GB OCZ
    8800GTX
    LC - Dual loops.
    Dual 20.1 monitors.
    Jul 2007
    Munich, Germany
    The RAM cooler is nice! Where did you get it from?
    Xtreme Cruncher
    Jan 2006
    Thanks! It's a regular ol' Corsair Dominator fan that I got from Newegg, 20 bucks. I didn't really like the Corsair stickers on the fan hubs and the blue one on top of the main body, so I peeled the big blue sticker off, and pulled the Corsair stickers off the hubs. I didn't like how the fan hubs had little marks on them, so I carefully peeled the round black stickers off the underside of the fans, and centered 'em on the fan hubs, replacing them with the Corsair stickers.
    I kinda like the little exposed screws on it, it's like a mini version of the top/front of my case!
    Main Rig:
    Dual loops:
    Dedicated Cruncher:
    Aug 2007
    Philadelphia, PA
    Very nice system! I almost wish I got a MM case after seeing some of the other setups around here!
    AMD Phenom II 955 BE || Asus Crosshair III || Sapphire HD4890 || 4GB G-Skill DDR3 PC12800 || G-Skill 64 GB SSD 2 x 1TB WD Caviar Black HDD
    Lite-On DVD-RW || Thermaltake Toughpower 1000W || Silverstone TJ-07
    || WC Parts: HK 3.0 LT || TFC 120.3 || DDC 3.2 w/ EK top || MCW 60 w/ Iandh Ramsinks
    Xtreme Cruncher
    Jan 2006
    Aww shucks fellas! Thanks Andy! That means a hell of a lot coming from a fellow Horizon owner. I wanted to go all business on the outside, with a party going on inside. I also forgot to mention that I modded my UV CCFL power wires so I could plug them into my Sunbeam fan controller. That way I can easily dim the lights or turn them off completely by simply using the fanbus knobs. Man I love this case!
    Main Rig:
    Dual loops:
    Dedicated Cruncher:
    I am Xtreme
    Feb 2003
    Netherlands
    Stunning!
    Great colour combo, well done.
    The black fangrills give a very smooth stealth finish, i love it!
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    OMG THAT'S SEXY wow i love your colour's u used...
    How did ya get that purple? that's sik
    1 word gorgeous!!!
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
  18. #18
    Xtreme Cruncher
    Jan 2006
    Thanks guys, that purple is actually supposed to be red. I bought it from Petra's Tech, and added it to distilled water along with a few drops of PTNuke. I would've preferred red instead of the purple/pink look, but I still think it looks pretty good. Next time I make a jab-tech order, I may try some of the Dtek red UV dye.
    Main Rig:
    Dual loops:
    Dedicated Cruncher:
  19. #19
    I am Xtreme
    Jul 2007
    nah man the purple is awesome it's different everyone use's red and that...If i were you i would keep the purple!!!!
    i'ma buy some petra's red dye and pt nuke now i want the purple for my rig... lol
  20. #20
    Xtreme Mentor
    Feb 2007
    So the pix show your real life colours closely?
    V-Twin WIP
    Q6600 G0
    EVGA680i
    4GB OCZ
    8800GTX
    LC - Dual loops.
    Dual 20.1 monitors.
  21. #21
    I am Xtreme
    Jul 2007
    how do u take such good pic's?
    When i take pic's mine are always blurry or grainy....
    It suck's cuz my build doesn't look halk as good as it does in real life...
  22. #22
    Jun 2007
    Brisvegas, Down Under.
    It depends on the camera but some have an option of taking pictures close up. I know I have to switch to that on mine in order to remove the blur.
    Loving the case. Is that a custom one? Might have to take another look at MM...
  23. #23
    I am Xtreme
    Jul 2007
    man i can't stop looking at this build...Imho 1 of the best rigs on here...
    I love how u keeped everything black...And just used the tubing to light the case up..
    I have like 8 leds fans in my case...maybe i should switch over to yate loon's go for sleek black look aswell...
    I Really like your new rig compared to your old one..Not saying your old rig wasn't nice but this one is alot better...
  24. #24
    Aug 2007
    Excellent all i can say.
    Dell Ultra Sharp 24" LCD
    Core i7 920 @ 4GHZ
    Gigabyte EX58-UD5
    2 GIG Wintec AMPX DDR3 @ 1600mhz
    ATI 4850 512MB
    Sweiftech Dual MCR320 Radiators
    Dtek Fuzion + MCW60 + MCW30 blocks.
    ATI 650 Pro HDTV Wonder
    (2 X 150GB RAPTORS) RAID 0
    Thermaltake Armor LCS
  25. #25
    Mar 2007
    Trenton, NJ
    nice i love dual loops with two different colors
    MY RIG: BLUE DEVIL
    CASE*BLACK SILVERSTONE TJ07-MODIFIED
    MONITER*32-INCH SAMSUNG WIDESCREEN LCD TV
    OS*MICROSOFT XP HOME EDITION SP3
    MB*GIGABYTE P35-DQ6 F9B BIOS
    CPU*INTEL E7200 3.6GHZ 1.3v
    RAM*2GB G.SKILL PK PC8500**DEAD**
    PSU*PC POWER&COOLING BLACK QUAD 750W
    HD*SATA MAXTOR 150GB 8MB CACHE & SATA WD 250 GB 16MB CACHE
    GPU*GIGABYTE HD4670 @ 811/1100
    MY WATERCOOLING SETUP
    CPU*SWIFTECH APOGEE GTZ
    PUMP*SWIFTECH MCP 655
    RAD*SWIFTECH MCR320 W/ 3 SCYTHE ULTRA KAZE MED. SPEED
    RES*T-LINE
    TUBING*DURELENE PVC
    COOLANT*DISTILLED WATER & PT NUKE
    WORKLOG-Blue Devil TJ07
