Hi!
Over the last time I tried to pack as much condensing power as possible into a 60cm LeChuck case. I ended up with two Cold_Ice deluxe condensors, each one in push-pull configurations with two Delta Fans. As I tried with a SC12, it soon became clear that it could handle much more power, so I switched to a SC21G that was lurking on the shelf for the last months...
If it pays off against a good designed NL11 singlestage may be open for discussion, the unit now makes -38.2°c AT 275W load at 25°C ambient temperature. At least more than enough for a quad core...
Components:
SC21G compressor
2x Cold_Ice Deluxe condensors
4x Delta fans
LeChuck 60cm Case with specially designed front and rear
230cm 0,9er captube
R507
oven-brazed Cold_Ice evaporator
PS: The first one complaining about the run/start cap mounting will be put on ignorIn this tight space the mounting proofed solid, the starting relais is screwed to the bottom of the case and the cable ties hold perfect...
PPS: No, it is NOT silent...
Regards,
Philipp
