XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Liquid Cooling > Liquid Cooling Worklogs
Reply
Old 08-26-2007, 05:42 AM   #1
Jedda
Xtreme Mentor
WIP, my V-Twin
Was fairly happy with AC and my Lian Li V1000 but needed to upgrade cpu and graphics as I do a lot of 3D modeling and other gpu intensive use.
So, I started by adding a 680i board, e6600 cpu and 8800gtx gpu to my existing case.
As this empty interior shows it's a tight little case.
Took about two weeks to realise it needed WC.
Looking through everyones' builds here, I could see I wanted a quad or similar.
However there was a couple of problems.
Neither MM cases or Lian Li 343 were sold in my country and although a couple of intrepid souls had shipped theirs' in it was a total cost blow out at step one. That was not going to go down well with the little woman, especially as the V1000 was only a couple of months old. Still I figured it could go to her if I found a case to suit me.
The other was that switching AC cooling had shown how much I didn't want to have to strip out half the build and motherboard any time I wanted to change a block. Along with that I was hoping to adequately cool quad cpu, dual gpu and chipset in the future, so two loops with all that entailed was to fit in some how.
The more I looked for WC components, the more a PA120.3 for each loop looked right. So a few more of the usual cases were crossed off the list.
As the first couple of 343B builds appeared I could see it was in essence two Lian Li cases joined together and guys were fitting two big rads. Why not do the same?
If my V1000 was only six inches wider there'd be room for everything I wanted and even a small section at the front for my M-cube set up.
The V-Twin was conceived!
I'm currently trying to make it a reality. A very slow process.
Jedda is offline   Reply With Quote
Old 08-26-2007, 05:51 AM   #2
mcoffey
Banned
oh man,
don't be a tease, more pics please.
andyc
mcoffey is offline   Reply With Quote
Old 08-26-2007, 05:59 AM   #3
Jedda
Xtreme Mentor
First off was getting a second V1000 and stripping it out.
Wasn't too difficult. Just drill out a few rivets and the motherboard plate came out. All the drive cages, fans and front slot covers were removed.
I'd already done some sketchup and photoshop work and knew the stock slots had to go. They don't look great on one case and it was twice as bad with two.
The finished look will be the same hole pattern as the rest of the case.
So there it was a case with a hole. I was committed.
Old 08-26-2007, 06:03 AM   #4
Jedda
Xtreme Mentor
Strip my first box and tape up the motherboard plate.
Then pop the stripped mobo back in, so I could mark out the block fittings through their holes.
Out with the mobo and in with a hole saw.
Old 08-26-2007, 06:07 AM   #5
Jedda
Xtreme Mentor
I use a hole saw for each corner then join the holes with dremel or jig saw (once I found how slow a dremel is and had the first exploding cut-off wheel whistle past my ear). Jig saw rules!
Old 08-26-2007, 06:13 AM   #6
Jedda
Xtreme Mentor
A little bit of file work to clean up the edges.
And then cut and fitting some edge mould to neaten everything up and protect against the leads fraying.
You can see I joined cpu and N/B cut out together but this pic doesn't show the S/B holes. The two long slots are for my mobo wire management. The top Grommet is for usb leads.
Old 08-26-2007, 06:16 AM   #7
Jedda
Xtreme Mentor
Joined up.
Here's how it looks from behind the board.
There'll be a rad top and bottom in this half.
Old 08-26-2007, 06:20 AM   #8
Jedda
Xtreme Mentor
Cut out the top rad twice. First time with a hole saw but after seeing how it looked with individual grills I went to a full hole for the TC grill.
And had to add a couple of rad hose holes up front.
Old 08-26-2007, 06:22 AM   #9
mcoffey
Banned
Now that's some skilz. Very nice and great work, keep it coming. Damn that's looking good, front looks really good.
subscribed,
andyc
Old 08-26-2007, 06:36 AM   #10
Jedda
Xtreme Mentor
subscribed,
andyc
Thanks Andy.
The front is never going to look as good as the 343 but I think with everything behind that hole pattern it should look integrated.
I have an extra power button, of course, so I'm going to use it to open and close the dvd door. That way I can stealth it into the other mesh.
Wiring, sleeving etc is taking up heaps of time. Just getting rad screws sorted took a week.
BTW crap camera batteries, so I'm swapping rechargeables in and out. So the date stamps don't mean anything.
Old 08-26-2007, 07:12 AM   #11
KaptCrunch
Banned
Jedda
your a tease thought it was motorcycle.
Whats your plans on rad and motherboard placement? nice handy work there
KaptCrunch is offline   Reply With Quote
Old 08-26-2007, 07:29 AM   #12
disruptfam
I am Xtreme
disruptfam's Avatar
Send a message via MSN to disruptfam
looking good keep us posted
__________________
Originally Posted by skinnee View Post
No, I think he had a date tonight...
He and his EK Supreme are out for a night on the town!
disruptfam is offline   Reply With Quote
Old 08-26-2007, 07:32 AM   #13
Solarfall
Xtreme Guru
Solarfall's Avatar
Send a message via AIM to Solarfall Send a message via MSN to Solarfall
looking good, this is gonna be a great project.. keep the updates coming bro
__________________
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
Solarfall is offline   Reply With Quote
Old 08-26-2007, 08:28 AM   #14
Anemone
Perpetually learning
Love this concept, and if I didn't have a 343 it would be a high contender. Could use one of the switches for reset one for power, but don't hit the wrong one
More pics! More pics!
Has to be some form of addiction we have watching systems come together
Anemone is offline   Reply With Quote
Old 08-26-2007, 08:31 AM   #15
Idaho
Idaho's Avatar
Looks very good and good concept! Hopefully you won't have to move it much after the build though! I wonder how sturdy the joint between the two cases will be once you get the weight of the entire system in there. How are the two cases joined together physically? Did I miss it?
__________________
MSI K9N Diamond 1.2 Bios
AM2 X2 5600+ @ 3.3 Ghz
2 GB Firestix DDR800
MSI HD2900XT
Silverstone Zeus PSU
X-FI Xtreme Music
Antec 900 Case
Petra's basic H2O Kit
Idaho is offline   Reply With Quote
Old 08-26-2007, 08:46 AM   #16
Movieman
I'm feeling BLUE!
Movieman's Avatar
I was thinking this also. Maybe add a 3/16" aluminum plate across the whole bottom riveted in for structural strength..Maybe in some key locations bolts and washers to spread the load and take any stress off of the rivets..
Make it the entire size of the bottom and add your wheels after to tie it all together..
__________________
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Originally Posted by Frisch View Post
If you have lost faith in humanity, then hold a newborn in your hands.
Movieman is offline   Reply With Quote
Old 08-26-2007, 09:02 AM   #17
Jedda
Xtreme Mentor
Thanks for the responses guys.
So far I'm using the standard side panel mounting holes to bolt them together but I have the axle mounting points underneath if it needs to be strapped together like Movieman suggests. We'll see.
I'm not sure about wheels yet. Two pairs of V-series trucks looks OTT and the wheels domed hubs conflict anyway. I may have a set of 343 castors coming, which would be great as they have brakes too.
I've tried a set of local castors and not been really happy with them. Hope the 343B ones suit it more.
Old 08-26-2007, 09:20 AM   #18
migueld
migueld's Avatar
Send a message via AIM to migueld
I like the motherboard backplate mod, very practical, nice work
migueld is offline   Reply With Quote
Old 08-26-2007, 09:38 AM   #19
LogAn'sRun
LogAn'sRun's Avatar
Awesome!! About time you teased us with some pics Jedda. I knew that you've been working on this for a bit with the info I've gathered from some of your posts, great to finally see it irl!!
*waiting to see more* xD
__________________
They say the definition of madness is doing the same thing and expecting a different result.
Howlin' Pelle Almqvist
Project Log Completed: v1000 - very first mod
LogAn'sRun is offline   Reply With Quote
Old 08-27-2007, 02:32 AM   #20
Jedda
Xtreme Mentor
Wanted socket head screws for a contrast on the top rad grill, so had to tap the rad holes.
First a quick drill to get 3.3mm for M3 threads. I used the hole offcuts to protect the core.
Then the tapping was easy. There's enough room that the tap is turning freely before you get near the core.
I won't bore you with the fan sleeving. It's been seen enough.
But since it was done already, I decided to do a trial fit as I wanted to see how it was going to look from the front.
What do you think?
I'm kinda happy with it but might play around a bit more.
The screen is mainly to show the M-cube readings but can do other stuff too. I'm not totally keen on it's look without the hole pattern. Might mount two stealthed dvd's instead.
This camera is garbage. Gotta bite the bullet and finally get a digital slr. Been using my old nikons and hasselblads with film, like a dinosaur. Never have caught up on all my scanning of transparencies. lol
Old 08-27-2007, 02:35 AM   #21
welshtom
welshtom's Avatar
Send a message via MSN to welshtom
drill the holes in the bezel?
also - that case needs some colouring
__________________
Chilled PC UK - Watercooling Parts, Any Custom work undertaken including Laser Cutting (any parts, grills, side panels, brackets etc), Anodising, Powdercoating , Custom Spraying and Airbrushing, Fabrication, Watercooling Installs and more all done to the highest standard.
International shipping no problem, even on Cases!
welshtom is offline   Reply With Quote
Old 08-27-2007, 03:43 AM   #22
Jedda
Xtreme Mentor
Actually that pic is quite puzzling. In the flesh, all the sections look exactly the same colour and finish. They must be reflecting different specularity to the camera's flash, but not to the eye with other light sources.
I can't drill the LCD bezel as the pcb and components extend behind it.
Painting the case has crossed my mind. We'll see. First I want to finish it as silver and black and make it work.
After that I might strip and paint it, if I'm not content with the outcome. It definitely looks better than the pics show. Which is a bit frustrating.
Old 08-27-2007, 06:13 AM   #23
AndyM
AndyM's Avatar
Now there's a cube! I like it so far, keep 'em coming
__________________
C2D E8400 @ 4.4 Ghz
Asus P5K Deluxe
Nvidia 8800 GTS @ 648/900
2GB Ballistix
Dtek, Swiftech & EK blocks, 2x D5, PA120.3, 2, & 1.
WD Raptor X 150GB & Seagate 7200.10 320GB
X-Fi Prelude
Corsair HX620
Silverstone TJ07
Dell 2407 WFP
AndyM is offline   Reply With Quote
Old 08-27-2007, 06:37 AM   #24
Cathar
Xtreme Legend
Cathar's Avatar
Read the title, and thought you were talking about one of these.
The case project is shaping up to look good though!
Cathar is offline   Reply With Quote
Old 08-27-2007, 06:50 AM   #25
Origin_Unknown
Xtreme Cruncher
Origin_Unknown's Avatar
excellent project idea...
keep up the good work
i dont understand why people like the 343? maybe its just me that doesnt like it?
__________________
E8500 - G.Skill F2-8000CL5D-4GBPQ 4*2GB PC 8000 - DFI LT X38 T2R
Palit 8800GTS 640Mb - Lian-Li A71 w/ 6 * Noctua NF-P12 - Corsair TX750
Thermalright Ultra Extreme - HR03 - HR05 IFX *2
We'll Keep the Red Flag flying high - Because Man United will never die
Origin_Unknown is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
