Alright, so I figure I start the official log on this project. As previously indicated in my other thread, I'm looking to build out a TJ07 housing a dual-loop watercooled system. This thread is also being mirrored on [H].
Project Goal: Maximum Performance with Minimum Sound
------------------------ Table Of Contents: ------------------------
Post #2 - Unofficial Sponsors
Post #31 - 8800GTX single bracket installation and first paste test
Post #40 - 8800GTX EK waterblock modification - sunken screws
Post #46 - Motherboard Tray Drilling & Dual Res Mounting
Post #52 - ATX Removal
Post #53 - Powder Coating
Post #66 - Leak Test #1
------------------------ Primary Components: ------------------------
- CPU: Intel Quad-Core Q6700 2.66GHz
- MOBO: EVGA 122-CK-NF68-A1 680i SLI
- RAM: G.Skill PC2-6400 4GB (2x2GB) CL5-5-5-15
- PSU: Cooler Master Real Power Pro 1000W
- GPU: Dual EVGA 8800GTX 768MB (SLI Configuration)
- HDD: Dual Western Digital 80GB Raptor (Raid 0 Array)
- SOUND: Soundblaster X-Fi Fatal1ty w/ Front Panel
- NIC: Killer-NIC Offload Card
- DVD: Lite-on DH-4B1S Blu-Ray/DVD/CD Rewriter
------------------------ Water Cooling Components: ------------------------
- CPU: D-Tek FuZion CPU Block
- MOBO: Northbridge: EK-NB EVGA 680i Acetal;
- MOBO: Southbridge: Swiftech MCW30
- RAM: None yet.
- HDD: Danger Den Aqua-Drive Hard Drive Block
- GPU: Dual EK FC8800 GTX Delrin
- PUMP1: Swiftech MCP350 w/ DDCT-01s PetraTech Top
- PUMP2: Swiftech MCP350 w/ DDCT-01s PetraTech Top
- PUMP3: Swiftech MCP350 w/ EK X-RES 100 Top
- RADIATOR1: Thermochill PA120.2
- RADIATOR2: Thermochill PA120.2
- RADIATOR3: Swiftech MCR220-QP Res
- RESERVOIR: Dual EK-150 rev.2
Loop Configurations:
- Loop 1: PUMP1===>RAD1===>CPU==>RES1
- Loop 2: PUMP2===>RAD2==>GPU1===>GPU2===>RES2
- Loop 3: PUMP3===>RAD3===>MOSFETS==>N.BRIDGE==>S.BRIDGE==>H DDS
the placement of the remaining components is yet to be determined. I'm a believer in shortest path, with the exception that a pump really should always be fed input from a reservoir and output should first hit the loops most critical block.
Tubing Options (3/8", brand to be determined):
Tygon R-3400 3/8" ID - 1/2" OD - black and sexy (most likely choice)
Primoflex 3/8" ID - 5/8" OD (1/8" wall) - amazing kink resistance
Tygon R-3603 3/8" - thick and strong
------------------------ Items No Longer Used and Now For Sale: ------------------------
- Lian-Li VCOOL PC-V1000BPLUS Aluminum ATX Mid-Tower, Modified for Water Cooling
- Koolance HD-50-L06 Hard Drive Cooling Block
- Swiftech MCRES-525 5 1/4" Bay Reservoir from the H20-Apex kit, revision 1
- Cooler Master GeminII LGA CPU Cooler w/ brackets
