Results 1 to 8 of 8
Thread: Single Loop Vs Dual Loop
    Jun 2007
    Hi everyone,
    I finally decided to try watercooling and I think I have all the parts, but I don't know whether to go with a single loop or dual. I'm going to be cooling a Q6600 after the price drop, a P35 northbridge, and an 8800GTX. Will one Thermochill PA120.3 be able to cool this or is it better to go with two Swiftech MCR 320's in seperate CPU/NB and GPU loops? I am looking for as high an overclock as possible on the cpu and as high as I can get on the GPU without volt-modding for now. Here are the parts I am considering:
    Pump(s): Swiftech MCP 355 w/ Petra'sTech Top
    CPU Block: Swiftech Apogee GTX (Bowed)
    GPU Block:Swiftech MCW 60
    NB Block: Swiftech MCW 30
    Reservoir(s): Swiftech Micro-Res
    Radiator(s): Thermochill PA120.3 or Swiftech MCR 320
    If there's anything else I should list, tell me and I will post it.
    On a side note, will the heatpipes on say an Asus P5K Deluxe be enough to cool the northbridge or will watercooling be necessary. Either way, i will have a fan blowing over the the entire motherboard.
    Thanks,
    Ninja Boy
    L-l-look at you, hacker.
    Jun 2007
    Perth, Western Australia
    We can't answer that question until you give us some idea of what fans you're going to be using on the PA.
    Presuming some reasonable CFM, I'd say you'd be fine with the PA120.3 Once you get GPU temps under 40C load, in my experience, you're not going to see any more benefits at stock volts until you get down to sub-zero levels.
    Rig specs
    CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
    Foundational Falsehoods of Creationism
    Jul 2006
    Vancouver, BC
    What are your space constraints if any? If you want a more compact solution... Another option may be to run a PA120.2 for your CPU loop. With a DDC and Yate Loon fans on my heavily overclocked quad, I get load temps around 60-deg at 1.55V. You could then use a MCR220 on the rest if you wanted.
    Feb 2007
    Arizona, USA
    It depends on how much you are willing to spend.
    A dual-loop would be best, utilizing the radiator set-up that virtualrain mentioned.
    Core i7 920 D0 B-batch (4.1) (Kinda Stable?) | DFI X58 T3eH8 (Fed up with its' issues, may get a new board soon) | Patriot 1600 (9-9-9-24) (for now) | XFX HD 4890 (971/1065) (for now) |
    80GB X25-m G2 | WD 640GB | PCP&C 750 | Dell 2408 LCD | NEC 1970GX LCD | Win7 Pro | CoolerMaster ATCS 840 {Modded to reverse-ATX, WC'ing internal}
    CPU Loop: MCP655 > HK 3.0 LT > ST 320 (3x Scythe G's) > ST Res >Pump
    GPU Loop: MCP655 > MCW-60 > PA160 (1x YL D12SH) > ST Res > BIP 220 (2x YL D12SH) >Pump
    Jun 2007
    Thanks for the quick replies. I'll probably be using these fans for the radiators. Space is not a big issue, but the MCR 320 is cheaper and according to this, they perform the same so i might go that route. If i do go dual loops, would it affect the temps of the CPU whether I put the northbridge on the CPU loop or the GPU one?
    Thanks,
    Ninja Boy
    Mar 2007
    Huntington Beach, CA
    Quote Originally Posted by ninja boy View Post
    Thanks,
    Ninja Boy
    It's always best to isolate the CPU on its own loop to get the most OC headroom for your CPU. However, it comes down to personal preference as some people don't care too much about the 1C-2C difference it might make.
    MM Extended U2-UFO CYO (Duality front, Standard back, Horizontal Mobo brace) Anodized Black || eVGA X58 || Intel i7 920 || 6 GB Corsair Dominator PC3-12800|| eVGA 295GTX || Asus Xonar Essence STX || VisionTek 650 TV Tuner || 1 300GB WD Velociraptor || 1TB WD's Black Ed. || LG 22X DVD-Writer || Lite-On 20x DVD-Writer || Corsair CMPSU-1000HX PSU
    CPU Loop: DDC-2 w/ XSPC Reservoir Top -> Swiftech GTZ -> Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
    GPU Loop: DDC-2 w/ XSPC Reservoir Top -> (Koolance VID-NX295 FC block) ->Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
    Chipset Loop: DDC-2 w/ XSPC Reservoir Top -> Alphacool Silentstar Dual HD waterblock enclosure -> Bitspower Black Freezer eVGA x58 MOSFET-> Bitspower Black Freezer eVGA x58 NB -> Thermochill PA120.2 (Pull: 2 Scythe S-Flex G)
    2 x Dell 2408FPW LCD || Logitech Z-5500 Digital 5.1 || Logitech G9 Mouse || Logitech G15 LCD Keyboard || Logitech Quickcam Ultravision || Sennheiser Headphones
    Banned
    Oct 2006
    Houston, Texas
    Absolutely right. Depends on your goals. Is having another rad (fans), pump and mess of tubing worth a few degrees? Not for me. My goal is a nice medium overclock and silence.
    Jul 2006
    Vancouver, BC
    When dealing with heavily overclocking a quad, it definitely pays to have a dedicated CPU loop IMHO... it's stunning how hot they get! If overclocking is not a primary consideration or even if it is and you have a C2D... a multi block loop with a Fuzion is very effective.
