Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Whats the best way to arrange 2 pumps in a full WC setup?
    Jan 2006
    Brazil
    Inline or parallel?? 2 separated loops??
    With a full wc setup, is better put my pumps inline or in parallel?
    Have here the folow things to cool:
    CPU - NB - GPU - SB - 2 VREGs each one with its blocks
    2 Rads - 1x 120.3 and 1x 120.1
    2 DD/CPS-MAG pumps
    Is worth make 2 loops, 1 rad per loop or 1 big loop with inline or parallel pumps?
    I have a thing defined at least, even in separated loops or in a big one, CPU and NB will be together in this order and GPU VREGs and SB also together in this order.
    My firt idea was to do a big loop with the pumps in parallel (i already didi it). But i think flow is being affected in this case and im trying to figure out whats wrong. The loop is not yet running mouted, take a look at the pictures i did in mount test to cut the tubes:
    The pumps
    So, whats better to do with this bunch of options, which one will be the most efficient?
    Thanks.
    E8600@4,0Ghz@undervolt + Zalman CNPS7000CuLed | Biostar TPower I45 | 4GB Corsair Dominator DDR2 1066 | ATI Radeon 4870x2 2GB 2x256Bits | Ultra X3 1000W real | DVDRW Samsung SH-S223F | Samsung Spinpoint SATAII 1TB 32MB Buffer | 2x250GB Seagate SATA II 16MB Buffer em RAID0 | ViewSonic VX2025wm 20,1'' Wide DVI | Logitech G5
    Xtreme Cruncher
    Sep 2005
    Bay Area, CA
    Make two different loops. 1 loop for CPU only (120.1) and the rest for chipsets, mosfets, video card and south &north bridge (120.3).
    Mar 2006
    wow thats a maze of tubing. nice heater core there man.
    the general concensus is to have one loop for cpu and one loop for everything else.
    Jan 2006
    Brazil
    Ok, will try to do 2 loops, but which chip come first in 2nd loop? GPU or NB? Cos they are hottest on the loop.
    And if i put the NB together CPU, but after CPU in the 1st loop, will affect NB?
    Thanks in advices
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    I'm gonna have to disagree here. I'm saying go everything in serial. Your using CSP-Mags which are a bit weaker than most other ppl's pumps. Paired up, they produce reasonable pressure (somewhere ~6PSI, compared to ~3PSI single) which will help overcome the natural pressure drop in such a large system.
    Circles SucQ!
    Mar 2006
    you surely know your pumps waterlogged
    Jan 2006
    Brazil
    Well, will post the clean setup pic so u guys can edit and put the loops the way u like and repost it edited
    Here is the way i edit with 2 loops
    (the red line is the fillports, have to get another one to use 2 loops...)
    sorry for the ugly edition :p
    1- with CPU only on the 1st loop and rest of things on 2nd
    2- with CPU and NB (After CPU) on the 1st and rest of things on 2nd
    I am Xtreme
    Feb 2007
    Quote Originally Posted by GueD'S View Post
    where did u get that colored tubing? It looks like a little small diameter wise. You should go with other colors than light blue and dark blue as well (assuming that color is the tubing and not from the fluid in them).
    Did you paint the blocks black? Also, the rads will work better if you install fans on them. I hope you leak tested that setup first.
    I am Xtreme
    Jun 2007
    Quote Originally Posted by DarthBeavis View Post
    You been in the Jager a little bit today DB?
    Circles SucQ!
    I am Xtreme
    Feb 2007
    Quote Originally Posted by Waterlogged View Post
    I wish . . .doing stats homework . . .worse on the brain than Jager
    Dec 2005
    NYC
    That is a pretty beefy setup there, Broseidon.
    I am Xtreme
    Jun 2007
    This is the way I'd set things up.
    GueD'S, can you do me a favor and take pics of the insides of the pump backs. I have a few CSP's myself but they are the other style and the style you have may work better for a build I'm working on.
    Circles SucQ!
    Jan 2006
    Brazil
    LOLOLOL
    Watterlogged, the pumps are mounted with fluid now, and im lasy to do that atm, but in the c-systems web u can view this pump opened and its the same, no difference http://c-systems.ca/features.php
    In your scheme above can u explain me few things? The CPU in the middle of the loop wont get hot?? And with 2 rads wouldnt be better to put one of them between some blocks, like before cpu?
    like this
    Feb 2005
    Rochester, NY
    I agree with waterlogged. I like to have everything in one big serial loop.
    Although, I like your last layout pic, with the radiators separating some of the blocks. I'd do that if it doesn't mean adding a lot of tubing.
    I am Xtreme
    Jun 2007
    The CPU might get a little warmer, how much is hard to say.
    Your modification to my setup will work just about as well. Little bit of extra tubing in yours though.
    I've already been through C-Systems site about 25 times looking for what I need to no avail. What I'm looking for is how they do the inlet from the same side as the outlet. The pumps I have are back inlet models.
    Next time you pull the system apart, if you could, it would be greatly appreciated.
    Circles SucQ!
    Jan 2006
    Brazil
    Oh, understood, when i dismount the crazy mess i did surely will take the pic for u. Just wait a couple of days. Will remake the loop here, and then I'll be able to take that pic
    I am Xtreme
    Apr 2005
    Upstate, NY
    I'd combine the loops only because 1x120MM rad sucks for the CPU.
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
  18. #18
    I am Xtreme
    Jun 2007
    Many thanks.
    Circles SucQ!
  19. #19
    Dec 2005
    NYC
    Bro you're going to need some mechanical worm-drive clamps or maybe PVC locking tube clamps at every single junction otherwise you are GUARANTEED to have leaks. With 2 pumps in series and large amounts of tubing + WB architecture pressure-drops in the way of fast-flowing water, you will have a TREMENDOUS back-pressure force working against the weakest links of your loops (the tubing).
  20. #20
    Jan 2006
    Brazil
    Quote Originally Posted by pH(x) View Post
    U are refering to the 2 first pics? That was taken at the moment i finish cut tubes to test its arrangement, when i finish the setup surely that it will have clamps Now i redoing the setup.
    Waterlogged, here the pics u wanted
  21. #21
    I am Xtreme
    Jun 2007
    1,000,000 Thanks GueD's.
    I always wondered if they offset the hole like that.
    Circles SucQ!
  22. #22
    Xtreme Cruncher
    Jun 2006
    On top of a mountain
    Wow that's alot like what I want to do with my P5K Deluxe.
    I realise that aesthetically or w/e it might be tidier to plumb as depicted above starting at the SB...but I don't see it.
    To me the block to start with is CPU...then Chipset...then GPU.
    It will make plumbing a bit gnarly...but as long as you follow Darth Beavis' Advice and use thicker lines you should be fine
    To answer your original (titular) questions I think the best way to run pumps is one before the CPU and one after the CPU--this has been shown to drop temps--especially with restrictive CPU waterblocks.
    What a set up...I am still trying to wrap my mind around spending as much in blocks as I would for the CPU/RAM.
    Good luck: and be sure to run it in with the sys powered down first.
    20 Logs on the fire for WCG: i7 920@2.8 X3220@3.0 X3220@2.4 E8400@4.05 E6600@2.4
  23. #23
    Xtreme Cruncher
    Jun 2005
    Lakeland,FL
    Quote Originally Posted by CyberDruid View Post
    ***good layout***
    750W Thermaltake Modular PSU
    DFI UT X58-T3eH8
    Core i7 920 @ 20 X 200 1.325V
    CORSAIR XMS3 DHX 4GB (2 x 2GB) DDR3 1600
    768 MB EVGA 8800GTX
    1 X 36GB WD Raptor
    2 X 150GB WD RAPTORS
    1 X SpinPoint P Series SP2504C 250GB
    1 X Maxtor 6L300S0 300GB
    16 X NEC DVD Burner
    7 120mm Yate Loon LED Intake Fan
    4 120MM Yate Loon Exhaust Fan
    28" HANNSPREE Monitor
    Watercooling Loop:
    1 X PA120.3
    1 X PA120.2
    2 X Laing DDC's w/EK-DDC Dual Turbo Top
    7 X Yate Loon Blue LED Intake Fans
    4 X Yate Loon Blue LED Exhaust Fans
    1 X Swiftech GTZ
    1 X GPU EK Fullcover Waterblock
    1 X XSPC Dual Bay Reservoir 5.25" with Bubble Window
  24. #24
    Mar 2006
    I look at dual loops much the same was as I look at multi-rail PSU's. Inefficient.
    One loop may even not even be utilizing half its capacity, while the other may be insufficient. I find that to be a bigger drawback than whatever flow difficulties you may have to overcome with a single loop, but having two pumps offers a lot to overcome any imbalances in your loop as far as restrictions go, and even better, using two adjustable MCP-655's makes it that much easier.
    One single big, huge capacity loop is better IMHO.
    Abit IN9 - Kentsfield QX6700 @3520
    1.5 vcore watercooled D-Tek Fuzion/PA-160/MCR120/2x MCP655
    2x2GB G-Skill (1080Mhz) 5-5-5-15@2.2vdimm
    2x XFX 8800GTS 648/999
    2x 74GB Sata Raptor Raid0
    2x 320GB Sata WD
    X-FI Elite Pro
    Lian Li V2100B
    Dell 2405FPW
    PP&C Silencer 750
  25. #25
    Jan 2006
    Brazil
    I like this setup too, but, wont the vga get hotter staying at the end of the loop?? And if i change the path from second pump (the upper one in layout) to 120x1 rad, changing the water intake from bottom to top wont help the pump to push less water upwards? Cos if water goes from bottom to top through the rad there will be more water volume than if it goes up from tube and then goes down through rad to cpu... am i right?
    And thanks for help
    []'s
