Swiftech releases new block for NVIDIA GeForce 8 series
Named after the famous Stealth fighter bomber because of its angular shapes and black livery, Swiftech's Stealth is a VGA water-block designed exclusively for nVidia's high-end GeForce™ 8 series graphics cards. At the time of publication, the Stealth is compatible with the 8800 GTS, GTX and Ultra models.
The ultimate GeForce™ cooling performance:
Using the same core cooling technology as the Apogee™ GT and GTX CPU water-blocks which are recognized as the best performing water-blocks on the market, the Stealth unique design approach focuses cooling where it is most needed: at the GPU level; with its extended wings covering the memory modules and NVIO chip, the massive aluminum housing also maintains the lowest possible temperature of these surface mount components; this allows in effect for the most advanced overclocking techniques which are necessary to take core and memory frequencies well beyond factory specifications.
Source:
Swiftech
http://forums.techpowerup.com/showthread.php?t=32247
