There will be two versions, a normal one and one for us and picture say more than thousand words so![]()
normal version, fluo red top and normal acryl top
and Xtreme version, acetal - delrin top
there will be two ways of flow (on same block):
- parallel for lowest restriction possible, and non GPU side will be little more restrictive, so most of the flow will go on the GPU side.
- successive for most Xtreme.
If all goes to plan, I will have first test samples in few days, so stay tunned for results.
