I was wondering if changing the FSB strap to 1066 on the CPU side could maybe help in overcoming the FSB "wall" that many seem to be hitting.
For those with nice mobo's, could you try this mod to see if it helps in raising your maximum FSB?
Materials needed:
-Car Defogger Repair kit --> I used the Permatex Brand from the auto store
* Silver conductive pen will NOT work *
-Steady hands
BSEL1 to VSS connection
Here is how it would look like:
Thank to all in advance,
Bryan d
PS - reason I cannot reap its potential benefits is due to my Asrock 775 VSTA, which struggles to go higher than 300FSB anyway.
) and use a toothpick or pin (pin is better since wood absorbs and wastes some copper unless you reuse the same toothpick every time)
but the Adhesive Tab is available, i can't using it, right ?
