Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 91
Thread: My DFI has flatlined my redline....
  1. #26
    Jan 2003
    Macomb Twp MI
    Quote Originally Posted by madpete
    eve2000,
    Issue with Enermax and DFI? I must have missed that one, whats that all about then? Although I will grant you that my volts seem a bit more wobbley than I'd like.
    As it happens I have one of these: http://www.pcpowercooling.com/produc...hp?show=T85SSI
    being delivered early next week, so I guess we will find out if theres a prob.
    I also tried the ram in another pc (Abit mobo) @ default everything and it still wouldn't post (good stick would), i am pretty sure this ram is badly damaged some how.
    You wont beable to use the 4vdimm jumper with that P/S.. I know cause i've had 2 of them now and i've givin up on the thing and returned it!
    Low voltages all around and it was'nt enough juice for my 4 DD 12v water pumps pumps. It would'nt turn on. Tech support made me a addapter so i could run some extra 12v crap off the 8 pin connector and it was crazy unstable. I ended up having to run 2 power supplies just to run my cooling. Not what i wanted to do with a 500 dollar P/S. You would think an 950WATT max powe supply would do it but since its like 4 small 200 watt 12v rails at 17amps, its not enough to power my beast.
    Infact i even noticed my graphics having that overheating look with messed up pixles an all and i thought it was the cards overheating.. But i guess it was just that they werent getting enough juice is all.. I know this now after going back to my 700 watt zippy with an extra Power supply for the pumps.. Its even hotter in the room and there fine now.
    What you need is a Zippy with a LARGE 12v rail..
    Running now, http://www.evga.com/forums/tm.aspx?m=693435
    Intel 3960 @ 5Ghz
    Asus Rampage IV Extreme
    QuadFire 7970
    X-Fi Sound Card
    16GB G.Skill 2133Mhz DDR3 Quad Channel Ram 9,11,10 @ 1.65v.
    3 Acer 23" 3D Ready LCDs
    2x Ultra X4 1600 WATT P/S 's
    MM Extension Ascention UFO Case W/ Top of the line Water cooling. Dream build!
  2. #27
    Dec 2004
    forrest of imagination
    what dimm # when it happened?
    i got my LOVELY twinmos utt killed couple days ago at dimm #3 (yellow) - 1 stick (out of 2) - happened after flashing bios and shut down,clear cmos etc... turn on.. flat line ------------------------------------------------------------------------
    my friend got his twinmos SP killed about 2 week ago at dimm #4 (orange) - 1 stick (out of 2) - running @ 3.4v -- suddenly one day decided do not want to boot...
    both @ 5v jp
    now im running with jp modified "bigtoe" way, 1x512 because my vendor out of stock of utt chips... only psc chip (code CADT) :sad:
    too bad DFI made such a powerful board, now it seems it back fired...
    Quote Originally Posted by HARDCORECLOCKER
    Can't confirm - running 3,72Vdimm from 5-V rail for more than 3 month without any problem...........
    carefull there m8 , im okay for about 4 month also with 5v rail,running almost 24/7 .. maybe 24/6 .. (whatever...) :P ... not its happening in the 5th...
    spooky sounds playing
    muahahahaha *sinister laughter*
    << back to normal voice >>
    seriously, DFI should fixed/solve/find this problem
  3. #28
    -100c Club Member
    Apr 2003
    Riverside, California
    Something pretty wierd just happened....
    I decided to change back over to my OCZ TCCD and wait for the new ATI mobos, but before i did I tried the bad stick one more time and the system booted. It then proceeded to pass memtest+, boot windows and pass memtest for windows with no error. At this point I am thinking that I am going crazy, as I know the memory was dead last night.
    Anyway, I switched off the PC and tried to boot again....this time like last night no go, and again its just that one stick that has the problem. Take it out and the system boots, put it back in and it doesn't (even just on its own, I cleared cmos again, etc).
    So the memory is defo buggered, but why would it just come back to life like that for no reason, work perfectly for a bit and then keel over and die again for seeming no reason?
    Is this that electro-migration that Oscar was talking about?
    No. Just don't play with the stick anymore and RMA it. This is pattern it will eventually totally kill the memory. When it goes, it will take ALL the memory you had installed in at same time most likely. (4 Mushikin blue I had)
    Ignoring it will only force break down.
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
  4. #29
    Jan 2005
    Cheshire, UK
    Quote Originally Posted by eclypse
    Eclypse, you gotta be kiddin me right? I just paid a small fortune for this so called monster
    Intel Core i7 3820 / ASUS X79 Sabertooth
    Gskill 2133mhz Quad 16GB / Auzentech X-FI Forte
    Sapphire HD5970 OC 2GB
    4x 500GB Western Digital "Black Edition" (Raid5)
    Thermaltake ToughPower 1500w PSU / OCZ 1250W PSU
    Corsair H100
    CoolerMaster CM-690 / Windows 7 Pro 64bit
    Samsung T260HD 26" LCD / HDTV
  5. #30
    Feb 2005
    Milano (ITALIA)
    Quote Originally Posted by eva2000
    On 5v jumper ? strange noticed a few more folks past few days report ram being killed on DFI but only since the issue was reported ???
    No, I used 5v rail only for benchs, dayuse at 2.9v 2.5-2-2-5 260mhz
    I hope the new bank is good same the old (and dead) bank
  6. #31
    Jun 2004
    Quote Originally Posted by Sniper 86
    what ram is that???
  7. #32
    Nov 2002
    Hawaii
    What BIOS are you guys running? I'm going to assume you are all using a BIOS version older than the 414's.
    Dell 2405FPW
    Lian Li PC-75B
    PCP&C 510 ASL
    DFI LP UT NF4 SLI-DR Expert
    Opteron 180
    Chilly1 SS Phase Change
    2x512MB Mushkin Redline XP4000
    BFG 7800 GTX 256MB PCI-E
    2xWD 740GD RAID 0
    Maxtor 6B300S0
    Plextor PX-716SA
    Audigy 2 ZS
    Klipsch Promedia Ultra 5.1
  8. #33
    Aug 2004
    .ee
    it would seem that DFI only kills UTT sticks. i have never heard it kill old BH5...
  9. #34
    Jan 2005
    There has been people with dead "old" BH-5 and even TCCD, the notion that it kills only UTT is not correct.
    Check these 2 previous threads for more info:
    http://www.xtremesystems.org/forums/...ad.php?t=62804
    http://www.xtremesystems.org/forums/...ad.php?t=63932
    DFI NF4 Ultra-D, 7.04-2BTA BIOS
    AMD Opteron 165 Denmark, CCBBE 0610 DPMW, 2.70GHz, 9x300, 1.350+104%
    G.Skill ZX, PC3200, 2x1GB, 2.5-3-2-5-1T, 245MHz, 2.70V
    eVGA GeForce 7600 GT 256MB, ForceWare 84.21, stock
    Enermax EG495P-VE SFMA 2.0
    Thermalright XP-90 w/ 92mm Panaflo H
    AMD Opteron 165 Denmark, CCBWE 0551 UPMW, 2.61GHz, 9x290, 1.450+104%
    G.Skill HZ, PC4000, 2x1GB, 3-4-3-6-1T, 237MHz, 2.60V
    BBA Radeon X800 XL 256MB 440/545, Omega (Cat 6.12)
  10. #35
    Jan 2003
    Macomb Twp MI
    Yeah it killed my G-Skill 4400LE TCCD after i flashed my bios..
    Intel 3960 @ 5Ghz
    QuadFire 7970
    X-Fi Sound Card
  11. #36
    Feb 2005
    USA
    few questions:
    which rail did you run? 5v?
    Orange or Yellow slots?
    What bios?
    how much vdimm?
    my first pair of Redline also ended up dead in orange slot2 at 5v rail with only 3.5v vdimm, rma took about 1 1/2 week....not too bad, talk to Tom and he'll take care of you.
    Agent....how did yours ended up dead?
    Edit: by the way, last month I'd also had a pair of TCCD got killed in orange slots, ran them 24/7 for about a month with two fans blowing on them at 330 @2.5-4-3-7 1T with 3.1v.
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
  12. #37
    Feb 2005
    abit an8-sli
  13. #38
    Memory Addict
    Aug 2002
    Brisbane, Australia
    i've had my DFI NF4 SLI-D for 6 months using 5v jumper mainly with original BH-5/6 and UTT BH-5/CH-5 ram from OCZ PC3200 Gold/GoldVX and no ram has ever died, but being scared by this report switched back to 3.3v jumper and TCCD Gskill ram for now.
    what is strange to me is that all these reports of dead ram coincide with the release of this confirmed DFI news of 5v jumper issues ? even some of the reported ram being killed only happened after this news was released ?
    i'd like to know how many of these users were using pre-414 series bios that had that know killer issue reported at http://i4memory.com/showthread.php?t=440 and http://www.xtremesystems.org/forums/...ad.php?t=59414 and not related to just using 5v jumper as such
    Just talked with Oskar couple minutes ago.
    when you play winbond utt type of ram on DFI NF4 series, and if you set the jp17 on 2-3, after your play is done. PLEASE, do as followed:
    Clear CMOS before set the jp17 back to default 1-2 position or set the 3.2v before set the jp17 back to 1-2. Several of my friends already killed their ram already. Be very careful about this.
    and be sure look at when you set 2.6v and see if voltage monitor under the bios is showing exactly what you set.
    ben, TCCD at 3.1v is bloody hot considering how hot they are just at 2.8v
  14. #39
    Memory Addict
    Aug 2002
    Brisbane, Australia
    eve2000,
    sorry but that psu won't work either according to OPB http://www.ocxtreme.org/forumenus/showthread.php?t=274 but worked for another user FROG so lucky dip
  15. #40
    Feb 2005
    Milano (ITALIA)
    Quote Originally Posted by AMD-me
    what ram is that???
    2x512mb Crucial Ballistix pc4000.
    Quote Originally Posted by B5I8
    I'm running 510-3 bios.
    Quote Originally Posted by ben805
    few questions:
    What bios?
    how much vdimm?
    Normal 3v
    Orange
    510-3
    2.9v with a 50cfm fan on the ram.
  16. #41
    Memory Addict
    Aug 2002
    Brisbane, Australia
    not sure how closely you guys monitor your chipset fan but when i use 510-x bioses my chipset fan can stop completely for moments at times driving up chipset temps... i since went back to 414-3 as best bios for me...
    wonder if using 510-x causing chipset fan to stop and heat killing chipset on board and ram ???????
  17. #42
    Feb 2005
    USA
    underload the TCCD was only slightly warm at 3.1v and I had two 90mm fans on top of them, they were the best sticks I ever had as well....bought 3 more pairs afterward and none could match the performance, been kicking myself in the arse ever since and I doubt I would ever come across nice TCCD like that anymore
    As for chipset fan, always have mine on full speed.
  18. #43
    Jan 2005
    Cheshire, UK
    few questions:
    What bios?
    how much vdimm?
    Yeah, 5v rail
    Dimm slot: Orange slots (interesting you should say that, cause my VX died in the orange slots and someone else mentioned it too)
    Bios: 510-2
    Vdimm: 3.5v
    Corsair H100
  19. #44
    Dec 2003
    Nederlands
    I have also 2 killed redline sticks.
    I had my first set. Within 3 day's one of them was dead. Then came the second set and now again 1 dead stick.
    When dit you guy's found out one stick was dead ? When running the systems or after switching from 3.3v > +5v ? My first set was killed after a switch to +5v 2e i don't know anymore
    This is realy a big problem. By my Twinmos sticks are still alive i ran those in orange slots and old bios. I swiched many times between 3.3 an +5v but i had no problems. Now with reds 510-2 bios and yellow slots i have already 2 dead stick
    System Specs: -=Game PC=- | -=Lan Box=-
  20. #45
    Aug 2004
    I still dont think its a board issue, I have a strong feeling ppl are flashing with High volts still going through ram. I also think that ppl are pumping for example 3.6,3.7 volts through there Redlines when they are only rated to 3.5 then complain there sticks are dead.
    I still say and remain conviced that this is a UTT issue, yes there is one of two instances of TCCD/BH5(old) dieing but giving the VERY SMALL number I would say this is more coincidence.
    Giving the Memory controller is on die, I would of thought that if the board was spiking bad enough to KILL Ram, I would have a guess that the memory controllers would be dieing also.
    Just my
    DFI Ultra-D
    X2 3800 Toledo 290x10 (1.39v) (not tweaked yet)
    2x 1GB Ballistix
    Sapphire X1950 256
    Seagate Barracuda 7200.9
    OCZPowerstream 520
    Custom water cooled
  21. #46
    Dec 2003
    Nederlands
    Quote Originally Posted by jiff
    Just my
    I don't know that to think.
    I whas using max 3.4 with 80 mm active cooling. Not flashing the board. And i have got 2 DFI Ultra D's here one stock bios one 510-2. And 2 venice cores both did not work. one module works fine other not. And at start both modules worked. So somthing is killing it but i don't know what.
  22. #47
    Feb 2005
    USA
    I think Mushkin should start suggesting user to stay the hell away from the 5v rail for now because it looks like almost all dead Redline were on that same damn rail, I can not imagine how many RMA replacement they've been dealing with....
    Astennu...I feel for ya, hope your 3rd pairs won't be on 5v rail again LOL just do the jumper mod for now man, otherwise they'll just keep dying.
  23. #48
    Oct 2004
    Boston, MA
    Thank God this board hasn't killed any of my RAM but it sure is starting to annoy me Sometimes when I try to boot up right before it gets to the Windows loading screen it says Boot CD: DISC ERROR INSERT SYSTEM DISK AND PRESS ENTER Originally when I had this problem switching from SATA port 2 to 4 solved it (SATA 1+2 don't work at all for me). But then after a little while the problem came back again. For a while, I could solve it by switching from SATA port 4 to 3, and when it happened again from 3 to 4, but that doesn't seem to work anymore. Now I have to reset the CMOS 2 or 3 times until for some reason the board decides to start working again...until it starts all over again
    File Server:
    Super Micro X8DTi
    2x E5620 2.4Ghz Westmere
    12GB DDR3 ECC Registered
    50GB OCZ Vertex 2
    RocketRaid 3520
    6x 1.5TB RAID5
    Zotac GT 220
    Zippy 600W
    3DMark05: 12308
    3DMark03: 25820
  24. #49
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    a lot of people probably thought it was initially bad memory. When someone finally reported having the same issues, people started putting 1 and 1 together and figured it might be the boards fault especially when they had more than one set go on them. Just a thought, i could be wrong though.
    Asus Rampage Formula X48
    Intel Q9650 @ 4.33GHZ
    OCZ Platinum DDR2-800
    Palit 4870x2
    Creative Xi-Fi Extreme Music
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
  25. #50
    Dec 2003
    Nederlands
    Same here. I thought is was the memory but after 2 times i clould not be the memory.
    This is a big problem. I don't know what 2 do.
    Get for the 3e time redline modules or get VX 4000.
    And I won't run 3.3 anymore. I just gonna stick with the 3.2.
    And may be later i'll mod my coolermaster realpower for higher 3.3 volts. But i don't love the idea off voiding the warranty of my 3 monds old PSU.
