Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Very important, read it before you kill your RAM
    Banned
    Jan 2004
    Land of Buckeye
    Just talked with Oskar couple minutes ago.
    when you play winbond utt type of ram on DFI NF4 series, and if you set the jp17 on 2-3, after your play is done. PLEASE, do as followed:
    Clear CMOS before set the jp17 back to default 1-2 position or set the 3.2v before set the jp17 back to 1-2. Several of my friends already killed their ram already. Be very careful about this.
    and be sure look at when you set 2.6v and see if voltage monitor under the bios is showing exactly what you set.
    Mar 2004
    Toronto, Ontario Canada
    Why is this necessary?
    Xtreme Mentor
    Oct 2004
    Man. It seems like such a hassle to go through just to use the computer. Does this only pertain to RAM that takes advantage of the 4.0VDIMM jumper?
    Banned
    Jan 2004
    Land of Buckeye
    I tell you guys what, now, Oskar is writing the BIOS to prevent this happen further.
    Be patient bro. Just wait for the bios later.
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    The DFI jumper has adverse effects on memory voltage when bios is reset and the jumper is set to the 5v
    Some people dont know about this. Thanks for the reminder.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Mar 2005
    so it applies to all previous bioses or just one particular one?
    Jan 2005
    Philly
    OPB, do you mind if I do a link and translation of this?
    Every man shall kiss his lips that giveth a right answer - Proverbs 24:26 KJV
    Memory Addict
    Aug 2002
    Brisbane, Australia
    could you clarify what you said a bit confused :o
    so you mean, to change from 5v jumper back to 3.3v jumper (from 4v max to 3.2v max options) you must either
    1. clear cmos before changing jumpers
    or
    2. set vdimm in bios to <3.2v vdimm ???
    so in otherwords if you only ever change 5v to 3.3v jumper when vdimm is set between 2.5-3.2v vdimm you're safe ?
    you mean 2.6v vdimm option can give you more than that ???
    Mar 2005
    OPB do you mind if i add this to my thread on another forum too?
    Banned
    Jan 2004
    Land of Buckeye
    do whatever you guys want good for the forum.
    Eva2000, I am testing the newest beta bios now, bear me for couple minutes, I will post. So you don't have to worry about how to set it.
    Feb 2005
    USA
    Quote Originally Posted by Onepagebook
    the newest beta bios?? which version....the 331?? if you have something newer please share....hehehe
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
    Jun 2004
    The Baltics
    Ouch, where were you earlier...
    I assume, this is the case or what (just with an adverse effect - killing bios or the board, not ram): http://www.xtremesystems.org/forums/...ad.php?t=58965
    At least two people have had big trouble if moving the Vdimm jumper to default position and clearing cmos, so don't do it simultaneously.
    away & gone
    Jan 2005
    Philly
    my friend told me that this info was written on the manual book. But not as detailed as your explanation. Thanks for the info OPB, sure it will save a lot of RAM and friends from toasting UTT.
    Banned
    Jan 2004
    Land of Buckeye
    414-1
    414-2
    414-3
    Add support for AMD Venice , San Diego Core cpu Cool n quiet
    prevent Jp 17 jumper problem cause vdimm still stay at over 3.3v when jp17 set back to 1-2.
    DFI recommand cumstomer need to set to 3.3v AND clear CMOS before set the jp17 back to 1-2 default position.
    Nov 2002
    Hawaii
    So if I use this new beta BIOS, it should be ok to run my RAM at 3.3V+ 24/7? Provided I have sufficient cooling of course.
    Dell 2405FPW
    Lian Li PC-75B
    PCP&C 510 ASL
    DFI LP UT NF4 SLI-DR Expert
    Opteron 180
    Chilly1 SS Phase Change
    2x512MB Mushkin Redline XP4000
    BFG 7800 GTX 256MB PCI-E
    2xWD 740GD RAID 0
    Maxtor 6B300S0
    Plextor PX-716SA
    Audigy 2 ZS
    Klipsch Promedia Ultra 5.1
    Memory Addict
    Aug 2002
    Brisbane, Australia
    i assume 414-3 is the 310 tables one ?
    Jun 2004
    Saginaw, Michigan
    Quote Originally Posted by B5I8
    I believe they are saying it's ok to run at those volts. Its when you switch the jumper on the board from the 5v rail to the 3.3v rail it can have adverse affects if not done correctly.
  18. #18
    Banned
    Jan 2004
    Land of Buckeye
    it's not 24/7 concern,
    it's about the situation regarding some users when they test both tccd and utt type of ram
    they need to switch the jp17 and some times they just shut down the system when vdimm still set to over 3.3v then they switch the jp17 immediately back to 1-2. so that's really dangerous.
  19. #19
    Feb 2005
    USA
    awesome!! which version do you recommend for the TCCD such as GSKILL 512LA? don't know what was being updated on those new BIOS but I assume the 414-3 is similar to the 331-3 so I'm going to flash it now and test it.
  20. #20
    Nov 2004
    Kenmore, NY
    Quote Originally Posted by eva2000
    I was going to ask the same thing...
    ~MadMikeSS~
    Intel Q6600 G0 @ 3.2GHz 1.31v - AX MP-05 SP LE cooled
    P5B Deluxe 1236 BIOS
    HIS HD4850@750/1100 - AX MP-1 cooled
    Mushkin 4GB(1GBx4) DDR2-800 5-4-4-15 1.9v
    FSP 700W PSU
    Lian-Li PC-V2000B
  21. #21
    Banned
    Jan 2004
    Land of Buckeye
    I and Oskar would recommand :
    TCCD use 1,3
    Winbond and other ram use 2,3
  22. #22
    Nov 2002
    Hawaii
    I recall reading a post that said something about not using the 5V jumper for 24/7 use. Can anyone confirm this or did I have a brain fart .
    Also, I know it's off the subject, but whatever happened to the G. Skill Winbond UTT modules? I've been watching Newegg like a hawk and still no sign of it .
    Dell 2405FPW
    Lian Li PC-75B
    PCP&C 510 ASL
    Opteron 180
    2xWD 740GD RAID 0
    Maxtor 6B300S0
    Plextor PX-716SA
    Audigy 2 ZS
  23. #23
    Jan 2005
    Philly
    sorry, i need a little explanation though. A little confused.
    What actually happens when for instance, vdimm are set @3.5v and I shut off the system and switch the JP17 back to 1-2 ? Does the mobo is still supplying @3.5v even I set the JP17 back to 1-2? Or there will be a voltage spike which kills the RAM?
    about the bios files, my friend said that it's not compatible with the UT series.
  24. #24
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    HAHA - funny, I did it the other way round but didn't kill my RAM, only my BIOS chip.
    THX for info - unfortunately a bit late for some people.......
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
  25. #25
    Jun 2002
    Ohio, U.S.A.
    It's stuff like this why I'm tending to avoid this board. It's like it's not even a finished product.
    If I had a nickel for every thread I see about some problems with DFI nf4...
