Page 1 of 10 1234 ... LastLast
Results 1 to 25 of 235
Thread: DFI NF4 the UTT/VX/BH5 KILLER READ IF YOU HAVE DFI
    Aug 2004
    Huddersfield UK
    Hi Guys, My 2 DFI boards have killed every stick of Ram I have put in slot 2 on the board! They have so far killed 2 sticks of Twinmos UTT, 4 Sticks of VX and one BH5. I have been using only 3.3 or 3.4 volts each time and each stick has worked for between one and three weeks before dying!! Once more my brother has killed 2 BH5 and 2 Sticks of VX again all of them plugged into slot 2 with the memory at above 3.2 volts i.e 3.4- 3.5
    I am of the opinion that the DFI simply kills memory! I run my PC24/7 and memory in this board simply does not last and I am sick am RMA after RMA. Anyone else experienced dead memory in slot 2?
    IF so post then DFI might want to do something about it!
    Oh and I have used a 110 CMF fan on the Dimms and two 50 CMF fanson the fets if you r thinking it's cooling think again!!
    ASUS M4E
    2600K @5.1 24/7, 1.45v
    8GB G.Skill RipJaw 2133mhz
    580 GTX Tri SLI @925, 2400
    Silverstone Strider 1500w
    OCZ AGility Raid 0 OS, Corsair GT's Raid 0 for data.
    Win 7 64 Bit Sp1
    ASUS R4E
    3690x 5.125 24/7 0901 or 0083b
    32GB G.Skill Ripjawz 2133mhz cas 9 or 2333mhz cas 10 or 16gb 2400mhz cas 9
    Win 7 64 Bit sp1
    "Only the strong will survive!" -Pazza316 when commenting on training with him!!
    Jan 2004
    Ogden, Utah
    dose it not work at all? Or can ya do the samething we all do. Boot with the good stick in an orange slot. after in windows. Shut down, Leave the power supply on. Shove the "bad" stick in the other slot. and try to post?
    http://www.xtremesystems.org/forums/...792#post843792
    anyways.
    Peace Nugz
    teh 0wnage
    Dec 2004
    Quote Originally Posted by pazza316
    condensation from not enough insulation from your phase changer?
    Aug 2004
    Huddersfield UK
    Na guys its not condensation this board kills memory my bro does not use phase and the same thing happens
    ASUS M4E
    Win 7 64 Bit Sp1
    ASUS R4E
    Win 7 64 Bit sp1
    Jun 2004
    Well this kinda scares me abit, considering i was planning on upgrading to DFI
    Aug 2004
    Huddersfield UK
    Angry
    Dont bother! Till DFI sort the problem my mate who owns a shop has had many a RAM stick back fragged by the DFI!!
    ASUS M4E
    Win 7 64 Bit Sp1
    ASUS R4E
    Win 7 64 Bit sp1
    teh 0wnage
    Dec 2004
    maybe its ur powerstream, i remember back when the dfi board first came out it had probs with zippy and ocz powerstream 520 psus. I mean, anandtech has been running their high voltage ram for a while with this mobo and not had a single one die or report of it dieing.
    Mar 2004
    i have heard of this happening to one other person. tRTW was set too low in cmos reloaded, and it nabbed his sticks (TCCD and CH5). he verified in another board. after a CMOS clear, all was well.
    i have never experienced it and have been runnin 3.4 since i got the board on these bh5 (approx. 3 months).
    Testing-
    DFI LP DK 790FXB-M2RSH - 1/16 Beta
    Phenom II X4 940 (CACVC AC 0850BPDW), 3.82GHZ (19x201) @ 1.46v (+150mv), NB: 2.61GHZ (x13) @ 1.3375v (11), HT: 2.61GHZ, PCI-E: 101MHZ, CPU: P-1 state
    OCZ Reaper, 2x2GB @ 2.015v, MaxMemClk-1066-5-5-5-15-20-195x4, DDR2-536, Tony's 1066 Phenom SPD
    Corsair HX620, Swiftech 2xMCR120-QP + MCRES-Micro, MCP-655, Vortex XP (D-tek Fuzion v1), 1/2"
    Jan 2005
    NJ
    been running my BH5 in slot 2/4 with my PS520 at 3.2V for quite some time now. Maybe somehting with the 5V line your doing wrong?
    CPU Z:2700 2k1:27952 2k3:12282 2k5:5763 PCM05 AQ3
    Opteron 165 s939_____OCZ RAM/PSU_____BBATI X800xl
    teh 0wnage
    Dec 2004
    Quote Originally Posted by pershoot
    does it still happen with the newer bioses? I have a few friends with a trtw of 1 and save to the cmos reloaded are they at any risk?
    Mar 2004
    im sure it was an isolated incident. i wouldnt worry too much. just clear CMOS if you can't POST from a bad setting and youll be fine.
    Testing-
    Aug 2004
    Huddersfield UK
    Apparently it is only a problem on the 5v line BUT it should work OK as the OCZ VX etc is warrantied to 3.5 and I have only used 3.4 - 3.45 their is a problem with the board! me thinks!
    ASUS M4E
    Win 7 64 Bit Sp1
    ASUS R4E
    Win 7 64 Bit sp1
    Mar 2004
    it happened while on +3 to my friend.
    no sense in making a generalisation at this stage. these incidents dont pop up too often (if they did, then it would not be good, ha).
    the wild and unpredictable world of oc'ing, hehe.
    RMA the board, it appears to be faulty if that is happening.
    Testing-
    -100c Club Member
    Apr 2003
    Riverside, California
    Nope, It happened to my 4 sticks of Mushkin blue running around 3.4v as well. None of them will boot on any machine I have (thats 4 desktops I tried) with the memory after the incident. Could be the VRM on DFI NF4 using 5v jumper is what is causing it is my guess. Typical sympton before death of 4 sticks were cold boot issue (random became more frequent as memory started dying than became... impossible to boot).
    I might try PSU direct voltage memory voltage method but for time being sticking to 3.2v setup and have had no issues for about 3 weeks so far. (but than the 4 blues died after about 2-3 months of usage)
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
    Aug 2004
    Huddersfield UK
    I have a contact that says this is not a generalisation! Its the board!
    ASUS M4E
    Win 7 64 Bit Sp1
    ASUS R4E
    Win 7 64 Bit sp1
    Apr 2005
    I like conspiracy theories as much as the next guy...but c'mon, if I had a dollar for every time someone said "xxxxxx is a fact because *I have a contact*" well, I'd be rich...if this was a problem with more than a few people we'd see message boards lit up everywhere with these sort of problems...tons of people have been running BH-5/UTT in their DFI / NF4 mobos for a long time now without problems...and I find it hard to believe that DFI knows that their motherboard is killing RAM and not doing anything about it, especially given their close relationship to OCZ who is the primary purveyor of this type of memory through their VX line...I'm willing to believe that *your* motherboard kills this type of memory, I'm willing to believe that there may be a couple other people out there that have had memory killed by their DFI NF4 mobos...I do not believe that DFI just plain kills these high voltage IC's, and that everyone should panic...I've read about people having their TCCD ram killed by their NF4 board too...does that mean we should all stop using Winbond or Samsung IC RAMs and go buy something with Micron or Hynix in it? no...Sorry for you loss, but I really don't think there's cause to try inciting people, getting everyone worried, and claiming that some companies that have been good to us in product support are secretly scheming to ruin our computers...c'mon now
    Just my .02, if you guys wanna panic then feel free, start a protest in front of DFI's headquarters demanding answers or something
    ***System currently in limbo due to Cold Boot issues***
    **(OC values stated below are pre boot-issue values)**
    A64 4000+ San Diego (CABHE 0515 VPMW) ::current clock - 260x11 = 2860mhz::
    DFI Lanparty SLI-DR (414-3 BIOS)
    OCZ PC4000 VX Gold (2x512) ::current clock - 1.5-2-2-8 @ 260mhz (3.5vDimm)::
    BFG 6800GT OC PCI-E w/ NV Silencer ::current clock - 420/1150::
    HD's = 2x 74gb Raptor (RAID 0)
    Enermax 600w SLI Certified ATX v.2.01 PS (3.3v@34a / 5v@34a / 12v1 and 12v2 @18a ea.)
    Case = Thermaltake ARMOR (modded to add 1x 92mm bottom mounted, filtered, intake fan)
    Cooling: HSF - Tt Big Typhoon w/ 120mm Panflo U1A @ 115cfm / Case Cooling - 4x 120mm Panflo U1A (2 intake, 2 exhaust) 2x 92mm Panflo U1A @ 69cfm (1intake, 1 exhaust) 1x 92mm Panflo U1A over RAM (aprox 300cfm total flow)
    100% Load 24/7
    Mar 2005
    Seattle
    Quote Originally Posted by jinu117
    I had the same symptoms, then 1 stick of my twinmoss died. Ran 24/7 for about 6 weeks 260, 2-2-2-6@ 3.4v. It was also the stick in the #2 slot. I don't think that this is random. I have been checking into it more, and just about any forum you go to, there is a thread about this. Really disappointed about this. I am switching to some tccd now. Hopefully this issue will not happen with it.
    Main Rig
    i7 2600k l Asus P8P67 l 2x2gb Gskill l GTS450 l Venomous X l XClio 680
  18. #18
    Mar 2005
    California, USA
    http://forums.extremeoverclocking.co...d.php?t=169487
    Quote Originally Posted by Impaqt
    I would recomend using ONE stick of expendable ram when you flash to a new bios ifyour using 4v setting on your DFI. I've seen THREE reports (Including me) of ram chips dying when optimized defaults were loaded after a Bios flash when the 4v jumper was on.....
    - quote from extremeoverclocking forums
    Q6600 G0, G41M-ES2H
    2x2gb OCZ Reaper HPC, Windows 7 Ultimate 64-Bit
    Intel 160gb X25-M, 1tb WD Caviar Black
    460 eVGA GTX SC EE 1gb
    Corsair 620w, Asus 24" 1920 x 1200
  19. #19
    Mar 2004
    Quote Originally Posted by Jester FPS
    ya see, i flash all the time on +5 feed, and always load optimised defaults, clear cmos, etc.. guess every ones situation/envmt. is diff..
    Testing-
  20. #20
    Feb 2005
    Hmm... I am about to get a new DFI and some VX 4000. I am assuming this just happens on a few and isnt much of a problem? Lemme know if this aint a good idea.
    AMD Athlon 64 3000+ NewCastle @ 2450mhz (245x10)
    OCZ PC3200 Platinum (2x256) @ 225mhz 2-3-2-5 [retired]
    Corsair PC3200 TwinX (2x512) @ 245mhz 2-3-3-10
    Seagate 250GB 7200.8 SATA
    Soltek SL-K8AN2E-GR - nF3 250
    Antec Neopower 500W
    ATI Radeon 9800Pro
  21. #21
    Dec 2004
    I had 1 set of VX4000 die on me after trying to uprgade processors from my FX-55 to San Diego 4000+. That to was in slot 2/4. Since I have upgraded to the Mushkin Redline and bios 510-2, I changed to the 1/3 slots. They are supposeldy better for higher voltage rams... We'll see!
  22. #22
    teh 0wnage
    Dec 2004
    so if my friend flashed his bios to 510-2 b4 switching over to 5v rail he should be fine?
  23. #23
    Nov 2004
    Portsmouth UK
    I agree with saiamne, making huge generalisations like this is not the way to go. DFI is the *best* motherboard producer, it terms of its contact and support with the overclocking community, a flaw so large would have been brought to its attention quite some time ago, if it existed. I dont doubt that your board has killed some ram....its a faulty board, RMA it, and for gods sake, stop putting more ram in it.
    I also dont doubt that there are several board similar to this, but you have to get perspective, does every user that has no problems post about it? Do users that do? Irrespective of that, how many users on this forum use BH-5 & UTT based ram at high voltages, and have done so for months??
    With respect, it would be better if you did not make alarmist statements that trigger this sort of response:
    AMD-me:
    pazza316:
    And as a side note, your from the UK, why are using words like this:
    bro
    Heheh, just kidding.
    E2180
    MSI P35 Neo2 FR
    Geil Black Dragon 2x1GB
    EVGA 7900GTX
    Toughpower 750W
    Viewsonic VP191b
  24. #24
    Apr 2005
    uscfan: I'm in the same boat with you... oh and Go Bears =)
    Intel Core i7 930 @ 4ghz | Gigabyte X58A-UD5 | 6GB G.Skill Ripjaws DDR3 | Radeon 4850 | Crucial m4 128GB SSD
    Intel Core i5-2400 | Asus P8H67-M EVO (Waiting to change to Z68) | 8GB G.Skill Sniper DDR3 | 8x2TB Samsung F4-HD204 | OpenIndiana | ZFS raidz2
  25. #25
    100% Load 24/7
    Mar 2005
    Seattle
    I am very happy with my dfi board, but there are enough people reporting this kind of problem to make me wonder if there is some kind of issue with the board. Maybe it is just that the ram can't handle high volts for an extended period of time. When my ram died, I was not flashing bios. Everything was running fine. I was trying to find a better way to mount my 2 80mm fans than just the zip ties I was using. After plugging it back in again, could not get it to boot. Then I put in some old ram, flashed to 4/14-3, tried with my twinmoss, again no boot. Finally figured out that 1 stick just plain died. So, I don't think that it is only an issue when flashing. I also don't understand how everything can be fine, then after being shut down for 1/2 hour, 1 stick just dies
    Main Rig
