Hello, I'm In a bit of panic! I'm ordering stuff soon, like tomorrow. And I need your help!
I cant decide if I should go Mcubed or Aquaero. And if it even is worth it to control the 2 ddc's
Choice #1: Use Mcubed's products and control the two ddc3.2's
Products needed: Mcubed BigNG, Sensorhub And? What extra should i get to have the two DDC3.2's? Maybe a MiniNG? or 2 Fanamps?
This also give me some safety if one of the pumps decide to die on me (automatic shutdown)
Choice #2: No control over pumps and just control the fans.
Products needed: Aquaero
They both have pros and cons.
Mcubed
+ Raw power.
+ A lot of addons .
+ Huge amount of sensors.
+ Digital sensors.
- Old software (but ill think they are working on updates. But how much?)
- Messy program.
Aquaero
+ Easy setup.
+ Good program and updated software.
+ Good Support from aquaero.
- Lacks in power output.
- Controling the pumps.
That are the ones I can come to think of...
My gut tells me to go with the aquaero but I really don't know
Edit:
I'm holding off on the buying any of the controllers since naekuh informed me about koolance new product!
