Hmmm XFX might not be clocked as high in real 3D mode http://forums.guru3d.com/showpost.ph...postcount=1172 ?
for those unfamiliar with delta clock or geometric clock on 7800GTX series they had a 40mhz delta clock so for example BFG 7800GTX rated 460/1300 in 3d mode would be 500/1300 and drop back to 460/1300 in 2d mode.Originally Posted by glenboy
With 7900GTX, MSI has 50mhz delta while XFX 7900GTX XXX has a 15mhz delta.
If MSI 7900GTX stock core is 650mhz then 3d = 700
If XFX 7900GTX XXX stock core is 675-690mhz then 3d = 690-705mhz
so in 3d mode it might end up the same clocks!!!!!
Interesting to see what other 7900GTX brands have for a delta clock value!
