Click images to enlarge
110mm Vs 92mm.
1000-2000rpm Vs 1350-2600rpm
Source
110mm Vs 92mm.
Source
I cant wait for the 160 mm to put a comair rotron axial on![]()
If you have a cooling question or concern feel free to contact me.
That is a huge ass mofo heatsink. Can't wait to see how well it performs
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
I wonder how much it weighs?
So this is just a slightly enlarged 9500
Intel Rig
2500K @ 4.8 Ghz 1.304v | ASRock Z68 Extreme3 Gen3| 2x4Gb Ripjaws DDR3-2133 | Radeon 7970 @ 1250/1800 | Corsair HX850 PSU
Custom Water of course
But with a slower fan speed for quiet.
If you removed the fans and have mediocre case air flow and your not pushing voltages to hard it may be a good passive choice.
Every since I put my HTPC case together with nothing but Zalman HSFs and Zalman case fans I have a new found enjoyment of silence. I have already pulled the power connections on three of my case fans and it's still too loud. Kudos for Zalman focusing on silence and performance. It's easy to slap a Tornado on something to cool it, it takes more work to make something perform well with very little noise.
Heh, i'd care more about silence, but in my dorm my only sound is through headphones, with Iron Maiden playing - so bring on the loud fans :P
Intel Rig
Nice.... very interested to see how it cools the CPU..
It's going to look hot in my case with the 9500 on my GPU already...
Lian Li V2000+ Modded
Intel Core I7 920 @ 3.8Ghz 1.325v Thermaltright Ultra 120 Extreme RT1366
Asus Rampage Extreme 2
OCZ 3x2GB DDR3 1600 Platinum
EVGA GTX460 768MB 850/1700/2100Mhz SLi
EVGA 8800GT SSC 730/1800/2000Mhz
Corsair HX850W
How do you support the GFX PCB? Isn't the 9500 a little heavy? What are your temps too? I see you clocked it to 500 core, which is only 10 higher than my old XXX's arrived stock, so did it really give that much an improvement.Originally Posted by NightCrawlerâ„¢
Looks really nice any case, too bad it won't work with SLI.![]()
I don't think that would even fit in my case!![]()
honestly, I hope zalman tweaked the design of this, cause the 9500 is only a "ok" heatsink.
making it bigger, isn't really gonna do much for it.
i hope we will see many reviews soon cause i was just planning to buy the TT BT but i guess i should wait now
Soon to be :
ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
Used to be: SaFrOuT
Pls watch your languageOriginally Posted by nn_step
I hope this means price cut for CNPS 9500 CU
Perkam
Don`t think it`ll be cheaper. At least till "old" model is in stock.
Zalman brand also plays part in it`s price.
I hope it wont require disassembling the mobo.
That's a pretty beastly HS/F.
I wonder how it performs, compared to the Tt Bt! I wonder if we have a new king hs/f. :worm:
Nick
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
how about a different word COOLOriginally Posted by mindwreck
bigger then the already $60+ 9500 that doesnt let you change or add fans (though possible, you need your own modding)
an $80 hsf that probably wont be any better then a $40 TTBT doesnt sit well with me.
well you can't get much cooler than Ambient on Air dude..
but it is alot quieter than the TTBT
a lot quieter !!!!!
i really doubt that
Soon to be :
Used to be: SaFrOuT
How quiter can yoy get when it`s already absolutly noiseless![]()
Temps don't go over 50C even after a few hours of gaming.. I can clock it to 520 with ease above that i get issues due to the lack of vcore..Originally Posted by krille
The backend of the card is supported with an aluminium strip to the bottom of the case..
Here's the thread with pics and all http://www.xtremesystems.org/forums/...ad.php?t=86526
Indeed a big shame for no SLI...:p
Corsair HX850W
