*note: I hope to borrow a camera this weekend to take some pics...
I had the stock cooler replaced by a Zalman 700LED but was far from impressed with the results... overall my temps dropped by 10C compared to the stock cooler... 44C idle 80C full load... so in short it sucked...
I had a spare Zalman 9500 since I bought myself a Typhoon some weeks ago.. yes you can see where this is going....
After taking the GTX out I started measuring what needed to be cut and what could be left but above all if I was able to mount that huge cooler on the GTX using the default mounting holes and clips I had laying around...
Luckily the mounting holes aligned for 97% with the Zalman retention clip used for Pentium mobos... so I knew it was gonna fit
First off the cooler was almost 1cm too high to it needed to be shortened so I cut off a large portion of the top fins with a metal scissor..
Once that was sorted it needed to have a very large section of the side removed to avoid contact with the PCI slots etc....
After an hour of cutting I could finally mount the Zalman on the GTX.... AC5... the bracket and bolted it on.... clean fit...
Plugged it in the mobo... connected the wires and fired it up.... and I nearly wet myself... from joy and nerves LOL
Idle temps went from 44C to 38C... full load temps went from 80C to 46C
Downside is I probably need to support the card due to the weight of the Zalman.... but it's not a major issue...
As said pics to follow hopefully this weekend....
Update: pictures....
Update: Some more pics
And just in case the pics don't show up you can look here.... http://www.nxsecure.org/NightCrawler/4400/
NC™
Reply With Quote![Send a message via AIM to [XC] moddolicous](images/misc/im_aim.gif)
