RD-20 just freakin rocks.
Guys, my setup is running. dual primed at 1.525 (9x333, my board craps out with anymore) with my new pump rad and psu. ( I give credit for the same oc at less volts to my new psu fyi). But anyway, back to the pump, judging from how fast the bubbles in the loop go, I gotta say, damn, the flow looks like it's almost doubled from my md-20. Took 24 hours to bleed my loop before if I had a t-line in, now takes like 1. Also, if you want a good idea of how forceful the flow is, it's kinda like having a d-5 hooked up to a whitewater block or any other non restrictive block. Think about that, then think about the pins of the g-5.....Cleaned out my g-5 too, 3 jet pins were clogged
, needless to say, I was more careful this time filtering the water. Uh yeah, and make sure your pa120.3 , the screw cap on the bottom is closed before u fill it :P Or like me, you'll end up with water on the floor of your kitchen. I have 3 san ace fans pushing the rad with no shroud, not sure I like it, I'll have to test pull too, then push and pull with a 1" shroud (made of dead 120mm fans). Best part is, all I did to mount the rad was buy some 1/2" neoprene from walmart, slap it on, and slid the rad in, fit just snug enuff to not move at all. Looks nice and clean, I'll take some pix of it later for u guys, it's like 2 am here
I don't really like the converter I bought for the pump though, I wanna run it at 24v and it's running at 21, I feel like I'm being cheated, heh. Also I have no idea if this is doing better than my weapon 302 core setup because the ambient temp in my room varies too much and I don't feel like figuring the math atm. I can tell u it looks cleaner, I suspect the loops true power will show if I decide to add gpu blocks into the mix.
Overall man, u can't beat this pump, almost twice as powerful as the md-20, 1/3 the size, it's silver so matches my case, (not aqua blue) AND runs off your case psu for a nice powerful clean setup. Anyone who gets this pump, you will NOT be dissapointed. pump + converter = @ 260 bux fyi.
ALIENS are bringing my next kentsfield based rig in a UFO case!
- You may not post replies
- You may not edit your posts
Forum Rules
