Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Overklokk GPU cascade
    Xtreme Legend
    Jan 2004
    Norway
    Hello
    I am building a GPU cascade for Stoolman and look at this setup
    The compressor on stage 1 is a Danfoss FR11 and on stage 2 is Danfoss NL11F. The HX is 15ft 3/8" with 3/16 inside.
    On stage 2 i made a suction line HX that is cooling the R1150 down before it goes too the HX.
    My temp meter on HX inn and HX Out only can read down too -50c. After that it crap out and show only L. So i guess that HX temp is about -50c ......
    Look at this picture.... nice temp?
    I wil load test it later today on a FX55
    Regards
    Overklokk
    First in world over 90k in 3D Mark 03 with 90400p
    http://service.futuremark.com/compare?2k3=5160409
    Xtreme Mentor
    Nov 2003
    New-Brunswick, Canada
    Very impressed as always by your work overklokk . Very neat and awesome performance.
    BTW : I wasnt very good with english when I came here.... And others corrected me... I liked it ... So just one thing I saw..... too = also to = at.
    Nov 2004
    Indonesia
    Impressed by your HX temp. What gas do you use on 1st stage?
    Intel Pentium 4 506 China SL8J8 2666 MHz @ 5000 MHz| ABIT AS8-V (i865PE) |
    Mushkin PC3500 2x256MB | ABIT ATI R9550 XTurbo (790/405) | Twin R-502 Single Stager
    Nov 2004
    Indonesia
    Just notice the 2nd stage suction line HE, it certainly helps to get lower HE temps but I wonder if it hurts the 2nd compressor due to higher suction temps (too much 2nd stage gas superheat) - furthermore you haven't put a load tester on evap so the high superheat effect haven't appear yet.
    Jul 2005
    new delhi, india
    really nice.
    what graphic card do you plan to cool.
    Xtreme Legend
    Jan 2004
    Norway
    Hawe tested it on a FX55 Claw now @ 3200Mhz 1,7volt.
    This is idle in windows
    This is load when i run SuperPi 8M
    My HX temp load was -48c inn and -46c out. I run stage1 on a mix of r507 and r290.
    I realy think that this baby wil hold good temp on my friends Stoolman's X850 XT-PE
    Regards
    Overklokk
    Xtreme Legend
    Jan 2004
    Norway
    Quote Originally Posted by the_new_guy
    really nice.
    Tnx.
    He is going too cool a X850XT-PE
    Regards
    Overklokk
    Jul 2005
    new delhi, india
    amazing temps
    Nov 2004
    Indonesia
    Excellent temps! I love it!
    Your on load test prove the suction HE is a good idea (not hurting the compressor)
    I think I should steal the suction HE idea to get better condensing temp on 2nd stage gas, but I'll place it after the main HE instead.
    -100c Club Member
    Apr 2003
    Riverside, California
    DT200 supports 2 temps... where did another probe go? :P Considering sweet temp of 2nd stage, I would love to see temp of first stage.
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
    -100c Club Member
    Mar 2005
    Poland
    Does that FR11 have mineral oil ? What model is it exactly ?
    Peter
    Xtreme Legend
    Jan 2004
    Norway
    Quote Originally Posted by jinu117
    i dident hawe more than one probe for the DT200
    Regards
    Overklokk
    Xtreme Legend
    Jan 2004
    Norway
    Quote Originally Posted by piotres
    Peter
    it was mineral but i cange too esteroil for the r507. The model is: Danfoss FR11 103 if i remember corect. It is from a R12 unit.
    Regards
    Overklokk
    Xtreme Legend
    Feb 2003
    Warsaw, Poland
    Your temps are insanelly low for the loads !
    Xtreme Legend
    Jan 2004
    Norway
    Quote Originally Posted by berkut
    yes it is think this is the best cascade i eva make and its only for a GPU
    Regards
    Overklokk
    Dec 2003
    Denmark
    Hey Overklokk
    How is the priceing on such a cascade ?..
    Jacob Hansen
    Xtreme Legend
    Jan 2004
    Norway
    Quote Originally Posted by JacobHansen
    Hey Overklokk
    I cant say it here
    YGPM
    Regards
    Overklokk
  18. #18
    Dec 2003
    Denmark
    Whoops - sorry.!
    Jacob Hansen
  19. #19
    -100c Club Member
    Mar 2005
    Poland
    Quote Originally Posted by Overklokk
    Have you gargle that FR11 twice with new POE, or just you had poured out oil mineral and put the same volume of fresh POE oil ?
    Awesome temps ..specially that -46*C on loaded HX is just mad with that rather "weak" comp .. ...
    Do you sure to you probe accuracy (specially that white thermo ) ?
    Regards
    Peter
  20. #20
    Xtreme Legend
    Jan 2004
    Norway
    Regards
    Peter
    I take out all the mineral and filed it with POE. Then i let ir run for 2 minits and change oil again
    The white thermo is not the best but its realy good down too about -45c.... The DT200 is good. I testet with another one too se if it read the same temp and it did Tomorrow i wil troe a Tupe K probe on the HX too se the real temp
    Regards
    Overklokk
  21. #21
    Dec 2003
    Austria
    These are awesome temps, very good work!
  22. #22
    Xtreme Legend
    Jan 2004
    Norway
    I tested it again today and this time with a real tempmeter on the HX
    This is inn and out of the HX with only stage 1 running
    This is when stage 2 is pulling down the evap temp
    And finaly all tree temps
    Regards
    Overklokk
  23. #23
    Jan 2005
    The Netherlands
    Nice temps
    San diego @ 3.2Ghz 1.5v(mcw6002)
    DFI NF4 SLI-DR Expert
    ASUS 7600GT SLI
    2x256mb bh6 @ 266mhz 2-2-2-5
    antec 430w
  24. #24
    -100c Club Member
    Mar 2005
    Poland
    What are all pressures on both stages loaded ??
  25. #25
    -100c Club Member
    Mar 2005
    VERONA ITALY
    very nice,impressive temp from hx,good good job
    P5N-Tdlx 780i SLI-Q6600 G0 @3,6ghz.. liquid-2x1gb Geil Blak Dragon 900mhz 4-4-4-10-Pov 8800gt 740-1850-1050 stock cooling-Antec Tc 550Watt-Raptor 10k-2x80gb ide Raid0-500gb sata2 raid0-320gb sata II
