Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: MSI Neo2 Platinum and OCZ Powerstream
    Sep 2004
    Boston, MA
    Hey guys - unfortunately, i got my FX55 and MSI Neo2 Plat. last week and i've been unable to use them yet due to my stupid OCZ PowerStream PSU. To make a long story short, i plugged my original one in, booted up a few times, then wouldn't boot up any more. I call OCZ, they dispatch me a new PSU thinking that this one just died. I get the new one, put it in, same exact problem. So now i'm thinking "Great, mobo or proc is dead" but no - i pull my friends PSU out of his computer and put it in mine, powers up like a charm, works great - i put my OCZ into his computer, it works...i don't understand, does OCZ only like Intel platforms? Either way, i'm getting yet another RMA from OCZ now because i didn't do this test before hand...but i went ahead and ordered an Enermax CoolerGiant 480w PSU as i hear they are good and have stable rails...anybody had any experience with these? Let me know...thanks!
    Intel 3930k @ 4.55ghz
    Asus Rampage IV Extreme
    Intel SSD 520 480gb
    AMD Radeon 6990
    Corsair AX1200 PSU
    Aug 2002
    .CA
    I'm using an OCZ PowerStream 470 with my K8N Neo2 and I am having to issues. Just check and make sure that your rails are in spec, maybe the board has some weird over voltage protection.
    Sep 2002
    UK
    There are loads in here using OCZs without any problems.
    I read over here (OCZ support forums) about a few people finding some rails high from stock, so maybe the Neo2 has something like DoGMaN said. (weird over voltage protection)
    O'h look what I just found !
    Sep 2004
    Boston, MA
    thanks for the reply's...split, that thing that you just found - that describes my exact problem - it worked for about 30 minutes then just poof - no more computer...but nothing changed between those times so i don't believe there to be any possibility of grounding...very strange stuff...i'm thinking maybe its bios is somewhat fubar'd or something..i'll try and flash it with a newer version...who knows, it might do the trick i hope...lol..thanks again for the help.
    Intel SSD 520 480gb
    AMD Radeon 6990
    Corsair AX1200 PSU
    Sep 2002
    UK
    I wonder if the BIOS trats modded could be more fault tolerant.
    You can find a few flashing tips here.
    arj found a shortcut.
    Take the exact steps that you would do when you update through Live BIOS. The BIOS will be saved at Program Files>Setup Files>MSI-7025 v1.30. I renamed the 1.36 BIOS to 1.3 and paste it in there. The BIOS name would be something like xxxxxxx1.36 so I just rename it xxxxxxx1.30 before pasting it into the folder. After that I clicked next and MSI Live Update will do the flashing
    Xtreme Recruit
    Jul 2004
    Same weird problems here guys!
    DLT3C + NF7-S, plugged in the OCZ, worked great for half an hour, rebooted, and never opened again!. Mobo was toast (switched bios with another NF7-S with no results so it's NOT BIOS problem), tested cpu in another system and it's dead. ONLY these 2 were harmed. OCZ worked flawlessly on a friends Gigabyte+barton for a week or so, and is working flewlessly on a AN7+sempron for 1 week now. I am leaning towards blaiming the OCZ for this, cause the only two things that I did was to add some hyperX memory, and the 520 Powerstream. I haven't heard anyone toasting a cpu+mobo because of faulty ram so it must be the PSU... But then again.... it works fine so far....in 2 different systems... I can't RMA it, I am not sure it's faulty!! During the 30 minutes before the mob+cpu died I measured the lines with a polymeter during prime and they were steady as rock (all 3 with 0.1V up by default)
    Thought I was the king of bad luck, but it seems others share my misfortune!!
    "Violence as a way of achieving racial justice is both impractical and immoral. It is impractical because it is a descending spiral ending in destruction for all. The old law of an eye for an eye leaves everybody blind. It is immoral because it seeks to humiliate the opponent rather than win his understanding; it seeks to annihilate rather than to convert. Violence is immoral because it thrives on hatred rather than love. It destroys community and makes brotherhood impossible. It leaves society in monologue rather than dialogue. Violence ends by defeating itself. It creates bitterness in the survivors and brutality in the destroyers."
    Martin Luther King Jr.
    Sep 2004
    Boston, MA
    Very strange - i'm 99.9% positive that my chip and mobo are fine, specifically because i can turn it on with another power supply and successfully load windows - thats sort of indicative of a working computer lol....either way..i tried flashing to the modded bios, and while its nice to have, it didn't fix the problem with booting with the OCZ...weird weird stuff...i just hope that the enermax i bought won't have this problem and i can start OC'ing this thing...lol...thanks for the help and support
    Intel SSD 520 480gb
    AMD Radeon 6990
    Corsair AX1200 PSU
    -100c Club Member
    Apr 2003
    Riverside, California
    Similar problem... however, power cycling do work on it (meaning turning all off... let psu drain, etc). This problem only happens with my OCZ out of 4 brand name PSU. But than this could be individual model issue.
    [SIGPIC]http://www.vapoli.com/Images/Forum/vapoli.jpg[/SIGPIC]
    Single Stage Work Logs
    Quote Originally Posted by killermiller View Post
    Those ccb's will die if you look at them wrong.
    heatware: jinu117
    Xtreme 3DTeam Member
    Aug 2003
    Germany
    MSI K8N Neo2 + OCZ Powerstream 420W here. No problems with that.
    PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
    Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
    Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
    Feb 2004
    Home of the Sun Devils
    Did you try adjusting the rails? In core cell my 3.3 line was reading 3.22 so i turned it up a notch to compensate. I started having problems with the computer not booting pluse the led on the back of the powerstream was in the red indicating it was over 3.3v. I'm starting to believe the voltage readings are as wacked as the temperature on this mobo. I'm idleing at 46'C cpu temp with my vapochill.
    i7-3930K
    GA-x79-UD3
    Corsair H100
    4x2GB F3-12800CL6
    X-Fi Xtreme Music
    EVGA GTX 470
    Pioneer BDR-207DBK
    2X128GB Samsung 830's
    3XWD2002FYPS
    Corsair TX850
    Dell U2412M
    ___________________
    Oct 2004
    compare your corecell temps to your bios temps - i bet teh bios temps are lower!!
    alternatively you can install mbm5 as it reports the same temps as the bios...
    corecell was telling me i was idling @ 50C with watercooling and in the bios/mbm i was really idling @ 38c - pretty significant difference !!
    Case: Coolermaster Stacker 830 SE w/ Seasonic M12D-750
    Mobo: Giga-byte EP45-UD3P Rev 1.0 Bios F10e
    CPU: Intel e8400 Q832A163
    RAM: 8gb Mushkin 996593
    Display: Dell 2405FPW
    Video: Sapphire HD5850
    Cooling: TRUE /w 2x SFF21F
    O/S: Windows 7 Ultimate x64
    Aug 2003
    Germany
    My 3,3V was up to 3,45V and no problems!
    Xtreme Mentor
    Nov 2003
    Abit has actually had notes in bios releases regarding updated to provide PSU compatibility. As strange as it seems, The board could be at fault, and compatibility problems CAN be caused, and fixed via bios. Unfortunately MSI seems to have problems with releasing bios fixes so don't hold your breath if thats the problem.
    Mar 2004
    Toronto, Ontario
    Just to add, my OCZ PowerStream 520W works no problemo on both an IC7-MAX3/2.4C combo and an A7N8X/2500+ Barton combo.
    I'm yet to test it with an A64 platform (still awaiting mobo & video card)...
    Merlin:
    AMD Athlon 64 FX-55 :: MSI K8N Neo2 Platinum :: 1024 MB OCZ 3200 EL Rev.2 :: BFG GeForce 6800 Ultra OC
    Lian-Li PC71 :: 36.7 GB WD Raptor :: 300 GB Maxtor DiamondMax 10 :: 21" Dell UltraScan P1110
    Jan 2003
    Montreal
    Just received my Neo2 this evening and I am experiencing the exact same problem with a Thermaltake Silent power 480w PSU. The only way I can get the system to boot is to clear the CMOS... Haven't tried my enermax yet cause I don't feel like ripping apart my MachII Barton system
    DFI Ultra-d
    X2 3800+ @ 2.5ghz Thermaltake Heatpipe
    Leadtek 6800gs 515/1300
    1gb OCZ Rev 2 Platinum @ 500 (2.5/3/37/1t)
    2 x 250gb DiamondMax 10 (RAID 0)
    Jul 2003
    Belgium (Brussels)
    No problem with my ocz powerstream 520w and my MSI but i've seen one thing, if the 20 pins molex isn't enought good placed i have no post!
    - MSI K8 Néo 2 54G with bios 1.8
    - Venice 3000+ 0515 FPCW @ 2875Mhz (1.65v)
    - 2*512 OCZ EL Series Dual Channel Platinum DDR PC3200 rev 2 @ 580Mhz 2.5 3 3 7 1T dual @ 2.85v
    - Asus X800XT PE @ 627/649 with Dangerden Maze 4
    - OCZ Powerstream 520w
    3dM01: 37342 - 3dM03: 15404 - 3dM05: 7086 - Spi 1M:26s - Spi 8M:4m 58s - Spi 32M:23m 49s
    Mar 2004
    Toronto, Ontario
    Just put together my FX-55/K8N Neo2 system within the last 24 hours.
    Running 100% strong on an OCZ PowerStream 520W with absolutely no booting or 100% full load issues.
    Merlin:
  18. #18
    XS Local
    Dec 2001
    Close to Neweggs New RMA Center, CA
    i also now have this problem..
    i had the pc shut off after 2 hours after i went to bed, and not it will not start. it will only give power apon holding the power button, then it dies out.
    This is retarted.. ive modded my ocz520w so no warranty, So i may have to see if i can get my money back on this mobo.. i never liked msi anyways, but it looked like a decent mobo :\
    Opteron 175 Dual Core CCBWE 0544XPMW @2.3ghz 1.41v
    DFI SLI-DR Expert 11-25 Bios
    G-Skill 1gb GH UTT @210 2-2-2-5
    BFG 7800GT OC 485/1170 NV 5rev3
    74gb Raptor 300gb Maxtor 500gb Hitachi
    OCZ 520w SLI 3.46v 5.16v 12.64v
    Thermaltake CL-P0114 Big Typhoon
    3dmark01 3dmark05
    Heatware
  19. #19
    XS Local
    Dec 2001
    interesting... i lowered the pots and it booted... so it does seem to be a high voltage issue...
    3dmark01 3dmark05
    Heatware
  20. #20
    Jul 2004
    The Netherlands
    no problems here...
    been running my msi with an ocz 520W without any probs.
    3.3V upto 3.8V, 5V standard at 5,5V and the 12V at 12,3V.
    Never a had any problems
    i must say that i also shut down the psu when i shut down my pc,
    maybe that prevents me from having problems?
  21. #21
    Oct 2004
    Tampa, FL
    I am curious what the serial no is for the Neo2 Plat that are not wroking on the OCZ PSU...I bought this mobo and own a OCZ 520 w PSU...my serial # K04010051037
  22. #22
    Xtreme Mentor
    Nov 2004
    Elma, NY
    Ive got neo2 and 520 PowerStream - no probs here either.
    i7-2600k @ 4.8Ghz 1.38v L044A892
    ASUS P8P67 LGA
    16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
    1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
    Cooler Master UCP 1100 Watt PSU
    GTX 680 1300/7000
    Lian Li PC V-2000
  23. #23
    Jan 2005
    I'll have a look at my serial. I have the same problem, posted about it in the same post meantioned earlier here
  24. #24
    Dec 2004
    Portugal
    also had similar probs!! didnt work with ocz 520w or chiftec. but worked with a tt purepower and a weak psu that didnt have 12v plug. It seems that we must have extra carefull wtih static discharge. rma the board and now i'm waiting for another msi. the serial start like 0412...(do not remember the rest)
  25. #25
    Mar 2003
    Columbus, Ohio
    Ive got neo2 and 520 PowerStream - no probs here either too
    Same weird problems here guys! DLT3C + NF7-S, plugged in the OCZ, worked great for half an hour, rebooted, and never opened again!. Mobo was toast (switched bios with another NF7-S with no results so it's NOT BIOS problem), tested cpu in another system and it's dead. ONLY these 2 were harmed. OCZ worked flawlessly on a friends Gigabyte+barton for a week or so, and is working flewlessly on a AN7+sempron for 1 week now. I am leaning towards blaiming the OCZ for this, cause the only two things that I did was to add some hyperX memory, and the 520 Powerstream. I haven't heard anyone toasting a cpu+mobo because of faulty ram so it must be the PSU... But then again.... it works fine so far....in 2 different systems... I can't RMA it, I am not sure it's faulty!! During the 30 minutes before the mob+cpu died I measured the lines with a polymeter during prime and they were steady as rock (all 3 with 0.1V up by default)
    Have you tried another stick of ram, triy different slots
    "...If you are not part of the solution, you are part of the precipitate..." Stephen Wright
    MSI-Neo2, Athlon64 3200+, 0447-SPAW2750mhz (10X275)@1.55V 38 degrees idle, 42degrees load
    LR Cascade, Mag 5, OCZ Powerstream 520W, BFG GeForce 6800GT OC, OCZ PC3200 Platinum Rev II 2X512mb 2.5,4,4, 6
    Setup
    Heatware
