Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Thread: urgent!! how do i flash to 1.36b bios on msi k8n neo2
    May 2004
    uk
    Red face urgent!! how do i flash to 1.36b bios on msi k8n neo2
    hello every1, ive jus recived my fx55 and im tryin 2 work out how to flash my mobo 2 the 1.36b bios. ive downloaded and installed msi live update. but i cant seem 2 find the option 2 flash the bios, all it does is takes me 2 the live update for the 1.3 bios!?! can sum1 plz tell me how 2 flash the bios on my mobo, im dyin 2 play with my fx55!
    shigs
    Oct 2004
    Germany
    Go to Dos to flash the Bios , MSI has no soft to update Bios in Win now
    Mar 2003
    worcestershire uk
    Quote Originally Posted by shigs
    shigs
    i just downloaded the bios i wanted and opened up the file folder the bios was extracted too..................... found the 1.3 bios file............. deleted it.......................... coppied over the 1.36 bios file and renamed it 1.3 and then did it all through windows
    May 2004
    uk
    Quote Originally Posted by xs64
    wats the command on boot up 2 get 2 the bios flashin screen mate?
    Oct 2004
    Germany
    Unzip the download file , incluside : AWFL833D.exe and W7025NMS.136
    And then go to Dos n' run command line : awdl833d.exe w7025nms.136 and follow the setup guide
    Mar 2004
    Kuala Lumpur, Malaysia
    Quote Originally Posted by bradpit999
    It worked! Thanks for the "hack" man!
    Saved me a lot of time finding the floppies and hooking them up
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    Quote Originally Posted by arj
    please detail how you did it...
    Mar 2004
    Take the exact steps that you would do when you update through Live BIOS. The BIOS will be saved at Program Files>Setup Files>MSI-7025 v1.30. I renamed the 1.36 BIOS to 1.3 and paste it in there. The BIOS name would be something like xxxxxxx1.36 so I just rename it xxxxxxx1.30 before pasting it into the folder. After that I clicked next and MSI Live Update will do the flashing.
    Oct 2004
    Germany
    Cool man ! That's good for people who don't wanna use floppy anymore
    May 2004
    uk
    many thanks for ur help mate, my fx55 is up and runnin, but now my 6800ultra is borked so i ave 2 rma that , im jus waitin on my ocz 3200el rev2 now, hopefully here on friday. will keep u all updated on my fx55 overclockin and benchies
    btw the fx55 retail fan sure looks a treat, but its very flimsy to attach with my big hands!, so ive jus stuck it under my DD rbx
    shigs
    Feb 2004
    San Diego
    Edit: Got it now, running 1.36
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    MSI got rid of that Thats a nice feature...They need to get it back...ASUS has it and its nice
    Oct 2002
    Field of Battle
    I flashed mine the old fashioned way:
    make 1 floppy as a DOS boot disk (easy in winxp)
    make 1 floppy with the app and the exe. files unzipped (BIOS download)
    boot computer with boot disk in place, replace with BIOS floppy, enter 1 command line, follow directions, save BIOS-no, and go....
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    but those of us who have done away with our floppy drives..be able to flash in windows is a must .
    I am Xtreme
    Dec 2003
    Talking For those w/o floppies
    1 little phrase -
    BOOTABLE USB FLASH DRIVE
    I flash off of it run memtest and goldmemory, NO FLOPPY
    Xtreme 3DTeam Member
    Jul 2003
    Mason, MI... USA
    If it's stable and you have windows installed just use "winflash v1.51" to flash it from desktop. It's mucho easier and i haven't hosed a bios flashing it yet.
    GA-P35-DS3L no more than 450fsb w/1333 chip
    E6550 stuck at 3150
    V-DATA 2x1gb
    MSI 7900GS 512 3Dmark score in near future
    Old A64 scores2001 39,707 3D03 23,768 3D05 11,394 3D06 5914
    Sep 2002
    UK
    Quote Originally Posted by charlie
    Make floppy with Dr DOS Disk For Bios Flashing @ http://www.bootdisk.com
    Or make a bootable CD (requires no burning software)
    Bootable CD works on most boards, incl the MSI Neo 2.
  18. #18
    Jun 2004
    Olot (Girona)
    I did it as I did with my old DFI (nf2 infinity and ut250), using winflash...
    C:\Program Files\MSI\Live Update 3\FlashUty\Award\WinFlash.exe
    || Core 2 Quad QX6850 ES @ 3.5Ghz 1.35V || Thermalright Ultra 120 || Asus P5K3 Deluxe || Gskill F3-12800CL7D-2GBHZ
    || XFX 8800GTX || Dell 2005FPW 20" || Ultra X-Pro 750W LE || 3 x WD 320GB SD + 1 x Hitachi 500GB
  19. #19
    Xtreme Cruncher
    Nov 2003
    MD, USA
    Quote Originally Posted by Poki
    did this at least 5 times with my infinity...
    stop wondering about all these usb drives and floppy drives
    DO IT IN WINDOWS!
    3570K ● Asus V Gene ● 8GB Mushkin DDR3-2133 ● EVGA 660 Ti SC ● Seasonic X750 ● 128GB Samsung 830 SSD & External 1TB RAID1
    SupremeFX SPDIF -> MHDT Constantine DAC -> Darkvoice 336i Tube Amplifier -> AKG K701
  20. #20
    XS D2OL & RAM News
    Aug 2004
    Somewhere, USA
    yeah why don't we just do that? It seems alot easier and the risk is higher if your overclocking....so basicly run your computer at stock when you flash from Windows...unlike me who just flashes and hopes that my OC is just as stable as stock...lol
  21. #21
    X.I.P.
    Oct 2002
    Australia
    Quote Originally Posted by mad mikee
    1 little phrase -
    hmm, I need one of those. Down to one working floppy drive ATM and a box of 10 year old disks
    X800Pro class 3DMark01 : 36670
    X800Pro class 3DMark03 : 16092
    Ti4200 class 3Dmark01 No 1 : 22213
    Super Pi 1M : S754 28 sec, FX53 25 sec
    HEXUS Pifast : S754/Prom 40.55sec, FX53 36.92sec
    Author of A64 Tweaker
    Co-author of NF2 Tweaker
  22. #22
    Jan 2004
    Germany
    1 little phrase -
    How do you make the stick bootable? I mean I can't 'burn' memtest.iso onto the usbstick, can I?
    Sandy Bridge incoming.
  23. #23
    Feb 2003
    Sunny California
    I would have to say try thr 1.37 beta it is much better with more vcore for me!
    Asus rampage III
    i7 950
    corsiar dominators 3x2Gb
    Evga 280 gtx
    silverstone 800 watt power
    ssd 6Gb/s
    Water cooling
    BASS ALE COOLENT FOR ME!
    heat
  24. #24
    Xtreme Mentor
    Jun 2002
    I tried the 137mod beta and the 13/15/18% vcore settings will not stick (like in 136) after saving and re-entering bios they go back to 1.55v default. (check in hadware monitor). The highest one that will stick in 137 mod beta is +10%. That seems to give me 1.76-1.79vcore, so maybe it's enough.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
  25. #25
    Feb 2003
    Sunny California
    Quote Originally Posted by xgman
    Huummmmm I get up to 9.0 with the 1.37 bios if I set the vcore to 155 and the % to the highest! What is the power supply you have and rails what do they look like?
    Asus rampage III
    i7 950
    Evga 280 gtx
    ssd 6Gb/s
    Water cooling
    heat
