The idea was to pack as much as I could into the smallest case possible.. The case dimensions are 14 7/8" W x 12 3/8" D x 11 1/8" H.
Let me know what you guys think.
List of components:
DD Water Box - customized
i7-920 D0 @ 4.1ghz 1.28v 38c idle 58c load. Ambient room temps 74f.
evga x58 SLI LE
6GB OCZ DDR3 1600 ram
1GB Radeon 6870 Crossfire
90GB SSD
1TB Spinpoint F3 (Storage)
Ultra X-3 1,000w PSU
Fans:
2200rpm yates on the rads
1650rpm red led yates on top
WC Parts:
Heat Killer WB
EK 6870 FC WB
MCP 355 & XSPC Acetal Top on XSPC Pump Stand
Black Ice Xtreme II Rad x2
All bitspower fittins
1/2" x 3/4" Primo Flex LRT Clear Tubing
DD Acetal Fill Port
Others:
22mm Red Dot Delrin Vandal Switch
Murder Mod Sleeving
Black pci slot covers & Black Thumb Screws
Logisys 12V 15A Relay w/ Remote Control (controls lights)
Four 4" Red CCFL's.
