Well i'm not going to say this case has ventilation like a full tower, so I wouldn't recommend it for anyone wanting to do serious overclocking. My room is about 22c and the cpu idles at 30c, gpu at 31c. Running prime95 as I write this and temps are at about 50c so i'd expect them to climb to about 55c eventually. The GPU under load hits about 68c which is typical for the 670 in a full size tower from what i've read on reviews.
If you like this case but don't need the handle, there's an identical model with a 140mm top fan towards the rear of the case. As for weight, I'm a gym rat so no to me it's not heavy at all. I've had a TJ07 and the difference is night and day if that helps
Betfinix (sp?) has a new case called the Legacy, you may want to check that out, it's pretty sweet.
I also purchased a fan controller by scythe, the one where the buttons push in and out. I ended up returning it because it left am ugly gap between the controller and the 5.25" bay that I didn't want to look at. But you "can" remove the face plate from the ssd tray and mount a can controller on to it. May take some minor modding but it's possible to fit both in the bay.
Hope this helps.
