Results 1 to 21 of 21
Thread: Hit a 4Ghz wall @1.35v core shutdown, ideas?
Threaded View
    Jun 2010
    With the setup below I can get a 3.9Ghz with a pretty low CPU-Z vcore of 1.24v. I used the 3 step guide to overclock your i3/i5/i7 on overclockers.com to get to this point. Before I got to these voltages I hit a bclock wall at 192 in step one.
    Once I got to 3.9Ghz I tried starting over on step one with my current 3.9Ghz voltage settings and disabled SpeedStep and Hyper-Threading. My max bclock was 220 in step one this time with prime95 for 10 minutes with a QPI voltage of 1.39v. I dropped the bclock 2Mhz and kept the 2:8 ratio for a 872Mhz DRAM frequency w/ 7-8-7-20 timings. I popped in MemTest86+ and was able to make 3 passes w/out changing the DRAM voltage of 1.53756v. I then moved on to step three and raised the multi back to 21 and lowered the bclock. Again I hit a wall at 185 until I raised the vcore to 1.35v which allowed for 190. I loaded up prime95 and it reached temperatures of 87C on core 1 dropping in order to core 4 which hit a max of 83C. After about three minutes core 4 shutdown. I could tell because the core temp dropped to 63C and the utilization in task manager went to 0% on virtual cores 7 and 8. I tried dropping the vcore down a little lower but it wasn't stable. I tried going to 205 or 215 because I remembered about bclock holes but it still failed.
    So here is my question: Why such a huge vcore difference just to go up 100Mhz from 3.885Ghz to 4Ghz? Do any of my settings look wrong? I ordered two Delta 210cfm 120mm fans to upgrade from my 78cfm Noiseblocker to a push pull config on the radiator to help with my cooling.
    Also, does the fact that my core temps drop in sequential order from core 1 thru core 4 indicate a problem with the seating of the H50? I am currently running an H.264 encode of an HD mpg that includes deinterlacing using Handbrake at the 3.9Ghz settings below and have had RealTemp running the whole time. The max core temps are 76, 74, 72, 72 and are currently 73, 72, 70, 70 and now 73, 72, 70, 68.
    I run both CPUID HW Monitor and RealTemp. CPUID reports core temps 3-4 degrees below that of RealTemp. I understand that CPUID updates less frequently but core 1 for example is consistantly at 73-74C but in CPUID it never goes above 71C. Is one more accurate than the other?
    My setup:
    Xeon W3520 - Corsair H50 w/ 120mm 78cfm Noiseblocker
    Asus Rampage II Gene - Spotcool on the NB, removed NB & SB thermal paste and replaced w/ Arctic Silver 5
    Corsair Dominator GT 2000 7-8-7-20
    2x Geforce 9800GT in SLI
    PC Power & Cooling TurboCool 860 ESA
    My prime95 (1 hour max core temp 78C) and memtest86+ (2 pass) settings:
    bclk - 185
    multi - 21
    C1E - disabled
    Hyper-Threading - enabled
    SpeedStep - enabled
    TurboMode - disabled??? (doesn't show up under SpeedStep and multi never hits 22)
    C-state - disabled
    CPU LLC - disabled
    QPI LLC - disabled
    Voltages:
    CPU - 3.895Ghz @ Auto (1.29375v in TurboV) to support SpeedStep (CPU-Z 1.24v at load and 0.96 at idle)
    QPI - 3340Mhz @ 1.35000v
    DRAM - 927Mhz @ 1.53756v
    Uncore - 3710Mhz
    PLL - 1.81592v
    IOH - 1.33866v
    IOH PCIe - 1.51106v
    ICH - 1.11341v
    ICH PCIe - 1.51106v
Name:	xeon w3520 at 3896Mhz edited.JPG
