Hiya dudes! Thought I'd share some of my progress on a work of mine. It's kinda getting into the same league as your setups!
In advance I'd like to excuse my in some cases bad english.
Alright, here it comes:
PROJEKT :: CLMEAN-MACHINE
In this thread I'll show you some progress from socket 775 to i7 and some exchange of hardware and style. I would like you all to comment on what I should do better, things I should think of and perhaps also some suggestions on what I should do now to make this rig a real XS system!I would also like som help and tip about how to set your camera to get that really cool effect some of you have, like Screamer etc.
I have an Nikon D40 and I also can use an D300, but it's really to complicated for me. :P
#Plans: [ ] = Unfinished, [ - ] = Skipped, [ X ] = Accomplished, [ / ] = Bought but not used
-Finnish sleeving my TX650w PSU [ X ]
-Powdercoat the inside of the chassi black [ - ]
-Beat 4.7GHz on my i7 920 D0 (I'm at 4.515 atm) [ ]
-3 way SLI with GTX280 or an HD5870 [ X ]
-Extend my H2O with two loops and more radiators [ ]
-Buy more Noctua fans for all usable spots. [ X ]
-Buy 3x2GB DDR3 ram [ ]
-Sleeve the Case cables [ X ]
-Make an opening in the motherboard tray for easier removal of CPU-block [ ]
-To use 3dmark Vantage instead of 3dmark 06 [ / ]
-Through out the same type of hose in the system [ X ]
-Cooler fittings [ X ]
-Use front bezels with mesh instead of the original ones. [ X ]
-Switch from 775 to i7 [ X ]
-Cool the motherboard, CPU and GPU by h2o [ X ]
-Buy an Lian Li V1000b plus II [ X ]
-Beat the magical 4GHz [ X ]
-Beat some old personal 3dmark records [ X ]
-Buy an plexi case-side [ X ]
-Paint the silver case-side black [ X ]
-Re-build the 5.25" Laing style [ ]
-Dress the inside of the chassi in plexi [ ]
-Switch the original Lian Li wheels to casefeets. [ X ]
Components in use ATM:
| PC |
CASE: Lian Li V1000b
CPU: i7 920 d0 @ 4.515GHz | 1.4v
Mobo: EVGA X58 3x SLI CLASSIFIED @ 215
GPU: HD5870
RAM: A-Data @ 1720Mhz 8.8.8.20 T1
PSU: Corsair HX750W MDPC-X MOD
SSD: Kingston V Series 64GB
HDD: 3x1TB Samsung f1, 1x1TB Seagate, 1x640GB Seagate, 1x1TB Hitachi Deskstar
| H2O |
CPU: Heatkiller v3.0 LT
PUMP: Laing DDC 18W EK-top
RES: Swiftech Micro Res Rev.2
RAD: Black Ice SR-1 240
FITTING: Nickel Compressor ID 1/2" OD 3/4"
HOSE: Tygon ID 1/2" OD 3/4"
Exchanged hardware under the time of the project:
Gigabyte EX58-Extreme
XFX780i
Q9550 e0
Alphacool 3x120 radiator
Alphacool cylinder reservoar
GTX280 with EK fullcover GPU Block
Corsair TX650w MDPC-X modded
Corsair RAM fan[/i]
The Rig:
Previously on Projekt :: CL[M]EAN-MACHINE
Oh, some pics of the project, before it became a project. :P
Sleeving
Chassi:
OK, let's begin with what you came to see.
This is how it first looked when I called it a projekt.
I got complains about the cable management so I tried some more.
It didn't quite suffice so I tried harder yet, and switch position of the SSD
Moved the Sata cables. (And moved some more cables actually)
Some motherboard cooling pics and some less sexy hose management
Took myself some time to try harder.
Got a tip to move the pump to get less hose so I did it.
Some low quality pics!
Redid the hose management, a new case-side and the new bezels is on.
A smal upgrade, painted the case-side and added some noctuas to the specs. Also exchanged the wheels for some feets. Also bought an HD5870 which is the like second absolutely brand new GPU i've bought since the Nvidia 7950GT. I must say that it were more of an upgrade than I thought! I will buy a new block for the HD5870 to, but there's some other stuff to buy first.
Got tired of thating blue PCB of the Gigabyte motherboard so I bought an Evga x58 X3 SLI Classified 760, it matches the colorscheme alot better, don't you think?
My "new" mouse! Maybe the best ehm.. Not infrared or lazer mouse ever built? Not actually using it tho. :P
Modding:
To make this thread a little more interesting I'm going to modify this case a bit. I'm going to make room for an 3x120 radiator in the top of the chassi and also exchange the wheels with feets (Already done tho), add plexicovers inside the case to make it shiny (also already done) and make some changes based and inspired of Laine with the 5.25" room.
Something like this: CRED TO Laine FOR THE MODIFICATIONS AND IDEAS FOR THEM
And this is about where I am atm:
And some reflections in the plexi. I've painted it black on one side and leaved it shiny on the top side resulting in quite a stylish surface.
I am thinking of buying the EK motherboard and GPU nickel acetal block. Any thoughts of them? I really like EK's stuff and always used 'em.
Any thoughts on how to manage the hoses when having just the motherboard and CPU and also when I have CPU, motherboard and GPU. With and without an extra loop. Anyone out there using the same or a similiar setup?
