03-02-2010, 08:24 AM
#1
From ASUS with love: New Crosshair IV Formula & Extreme!
ASUS makes a return to the higher-end of the AMD platform with two motherboards in its elite Republic of Gamers (ROG) series, with the Crosshair IV Formula and Crosshair IV Extreme. Both motherboards are based on the AMD 890FX + SB850 chipset, and support socket AM3 processors. While the Crosshair IV Formula targets high-end gaming builds, the Crosshair IV Extreme goes all out to woo overclockers. The Crosshair IV Formula, to begin with, has six expansion slots, of which four are PCI-Express 2.0 x16 (operating at x8 when all are populated, or x16, NC, x16, NC), and two PCI slots. The SB850 southbridge gives out six SATA 6 Gb/s ports, while an additional controller gives out two 3 Gb/s ports (one being eSATA). The CPU is powered by a 10+2 phase VRM, with two phase memory power. Connectivity includes 8+2 channel audio with SPDIF connectivity, gigabit Ethernet, FireWire, eSATA, two USB 3.0 ports, and a number of USB 2.0 ports. The board supports the iROG feature, along with a host of other overclocker-friendly features.
The Crosshair IV Extreme, on the other hand, is probably the most complex motherboard for the AMD platform. Apart from overclocker-friendly features of the C-4 Formula, C-4 Extreme adds a wide range of electrical enhancements that include better power conditioning with Super ML capacitors, PWM circuitry, voltage measure points, ProbeIT feature, PCI-Express electrical control switches, iROG Bluetooth device control, physically redundant BIOS ROM chips, and a number of other features. The board itself is closer to being EATX sized. There are four PCI-Express x16 slots here too, but with 1U spacing between them. An open-ended PCI-Express 1.1 x4 and PCI make for the other slots. There are six SATA 6 Gb/s ports here, too, with additional SATA 3 Gb/s controllers, and connectivity largely identical to that of the C-4 Formula. We presume ASUS will release these two in late April, around the time when AMD rolls out its Phenom II X6 processors. Pictured in order (below) are the C-4 Formula and C-4 Extreme.
Source: Techpowerup
I like the direction ASUS is going now  ! for all you AMD lovers now you have a good mobo to play!
__________________
03-02-2010, 08:29 AM
#2
those are MASSIVE looking heatsinks...I thought AMD chipsets were power efficent (that and everyone else who's showcased boards earlier have normalish sized heatsinks), looks like someone might run into issues with backplates on videocards on those boards in the first slot too
__________________
Current System:
eVGA 680i SLi "A2" P30 BIOS
intel Core 2 Quad Q6600 (currently at stock)
OCZ ReaperX 4GB DDR2 1000 (running at DDR2 800 Speeds with cas4)
320GB Seagate 7200.10
XFX 8800GT XXX 512MB (stock clocks)
auzentech X-Fi Prelude
PC Power and Cooling Silencer 750 Quad Copper
Win XP Pro
03-02-2010, 08:33 AM
#3
they are, but I think its for the "bling" factor I guess...
__________________
03-02-2010, 09:46 AM
#4
03-02-2010, 09:48 AM
#5
cOmPuTeRsPoNgE
even for bling those heatsinks are ugly,especially on the Crosshair IV Extreme.just my opinion though.
__________________
____________________________________________
............ ImAcOmPuTeRCRUNCHINGsPoNgE.............
®adaj@'s HEATWARE
03-02-2010, 10:51 AM
#6
OMG, it's so nice. Big improvement.
__________________
03-02-2010, 10:56 AM
#7
Xtreme Guru
its great to see a real OCing board for AMD, however i think they put the cpu too close to the ram slots on the extreme. i think if they used a taller heatsink for the PWM, they could have left the cpu slot alone.
03-02-2010, 12:43 PM
#8
bulldozer
so, the xtremesystems ed. is non standard atx? not that its ever going inside a case. xD
03-02-2010, 12:54 PM
#9
I am Xtreme
they have a huge pwm array, and they have to have bling
this is the 1st asus line that ive liked in a long time, im just waiting to hear that it supports sli because they put an nf200 in it so i can hate it
__________________
p2 1090t, gd70, g.skill 2x2GB ddr3 1600mhz HZ w/ GTS
2x samsung 500gb(raid 0), ocz agility 120GB, SBA2 plat pro antec p180B corsair 750tx
beyerdynamic DT 770 PRO 80ohms headphones (they are like wall hacks for your ears)
03-02-2010, 01:02 PM
#10
alive
feng shui heatsinks
#11
Tygon Warrior
The Extreme looks very nice.
03-02-2010, 01:33 PM
#12
just give me a 890 FX based gene and i'm happy
__________________
Rig1: X6 1055T|MSi 5850 OC|4x2gb G.Skill ECO
Asus Crosshair IV|Antec Three Hundred|HX620|UD GX
Rig2: X4 955BE|HD 4550|4gb DDR3|jWele 785GMT
Rig3: E2140|Abit iX38QuadGT|GF 8800GTS512
Laptop: Latitude E6410|i7 620m|8gb DDR3|WXGA+
Quadro NVS3100|256gb PB22-J|6Cell Battery
03-02-2010, 02:00 PM
#13
Thuban + one of these please!
__________________
*ASUS Rampage Formula * Intel Core 2 Extreme QX9650 (10 x 400.0) * 4 x 1 GB Crucial Ballistix DDR2 1066 * Sapphire Radeon HD 4870 X2 w/ ASUS TOP BIOS (811/1000) * Western Digital Raptor X * Seagate 7200.11 1TB * Seagate 7200.10 500GB * Corsair HX1000 PSU * CM Stacker 830SE Black * Dell 3007WFP-HC * Dell 2007FP (Portrait Mode) *
Dual WC Loops:
Loop 1: Swiftech MC-RES Reservoir -> Laing DDC 3.2 w/ XSPC Top -> Swiftech MCR-220 QP Rad -> D-Tek FuZion v2 w/ Quad Insert
Loop 2: Laing DDC 3.2 w/ XSPC Reservoir Top -> Thermochill PA120.3 w/ Shroud -> EK NB S-MAX Acetal Block -> EK 4870X2 FC Block
Fans: Yate Loon Mediums
03-02-2010, 02:20 PM
#14
[sarcasm]Who would have though a company like Asus would make such postmodern garbage?[/sarcasm]
__________________
Originally Posted by Manicdan
using a OCed quad for torrenting is like robbing your local video store with a rocket launcher.
03-02-2010, 04:39 PM
#15
The heatsinks are bloody hideous. They seem like they were designed by a cubist painter on crack.
03-02-2010, 04:48 PM
#16
Glad they decided to put the top-of-the-line model out at the launch of the chipset, instead of at the tail end of it's life like the Crosshair III. Really like the buttons at the top right of the mobo, instead of down at the very bottom - trying to shove your fingers between the case and GPU to hit one of the buttons is a major pain.
But the red/black color scheme is no dice. It'd be a super sweet idea if they were to offer different color schemed boards.
Will definitely get this and a 6 core, and when somebody comes out with a water block, I'll definitely be replacing that butt-fugly heatsink.
03-02-2010, 07:05 PM
#17
Originally Posted by Razzz
integrated X-Fi sound card?? interesting...
__________________
03-02-2010, 07:06 PM
#18
This is probably one of the best looking AMD boards I've seen, though I'm not a fan of ASUS. Only problem is why doesn't it have dual LAN, I thought most FX boards should have dual LAN.
__________________
PC 1: Intel Core i7 970 | 12GB DDR3 G.Skill Ripjaws | Gigabyte 1536 GTX 480 | AeroCool V12-1000 80+ ATX Power Supply | 20 LG SATA DVD+/- RW | LG BluRay/HD DVD Combo Drive| 5.1 speakers | 32" LG HDTV at 1920x1080 1080p | Gigabyte GA-X58A-UD7 | 1x 500 SATA II Western Digital Hard Drive | 1x 1TB Western Digital Hard Drive | Windows 7 x64 Ultimate RTM
03-02-2010, 07:19 PM
#19
I am Xtreme
it dosnt have xfi it has a realtec with xfi codecs/software, most asus boards in teh ROG have it since it was introduced with the 1366 boards
__________________
03-02-2010, 07:35 PM
#20
oh thanks for the clarification
__________________
03-03-2010, 12:08 AM
#21
very nice CIVE
__________________
Intel Core i7 920 DO
Gigabyte X58A-UD3R
Corsair Dominator 3*2GB/1600
ASUS ENGTX460 TOP 768MB DirectCU
Kingston SSD V+ 64GB
Corsair HX85OW
Lian Li PC-A7O1O
DELL 22O8WFP + DELL 2OO7WFP
Creative X-Fi Xtreme Music
Klipsch ProMedia 2.1 THX
Thermalright Ultra 120 eXtreme
03-14-2010, 05:23 AM
#22
the crosshair iv extreme has the same size as the rampage iii extreme
03-16-2010, 12:38 AM
#23
Nanoseconds from Permaban
The Extreme has the buttons in the most retarded place, they'll be hiding behind the ATX connector
03-16-2010, 01:10 AM
#24
there's waterblocks for CrossFire III .... wonder when will they fab for CrossFire IV
03-16-2010, 02:04 AM
#25
Xtreme Monster
Asus is recycling designs, bummer 'The red dragon is doing wonders'
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
