OCN2
Results 1 to 13 of 13
Thread: New single-stager for Moonman's 2600K
    -100c Club
    Jun 2005
    Slovenia, Europe
    Thumbs up New single-stager for Moonman's 2600K
    I haven't built anything in a while so this was kind of refreshing. Yesterday was a crappy day for mountaineering therefore I've decided to build a cooler for my old buddy Moonman which I promised him a week ago. It's built for Sandy Bridge CPU, albeit it's a bit of a overkill but I'm pretty sure he'll find other purposes for the unit Unit also encorporates hi-side/low-side bypass (ball valve) in order to bypass the cold boot bug issues of his CPUs. The valve also enables quick restart of the unit as the unit reaches equilibrium almost instantly.
    Components:
    - Tecumseh RK5512E 9400btu/h R-22 rotary compressor 220Vac
    - 0.94kW condenser
    - 10W motor EBM Papst + 230mm fan blade
    - Littledevil CPU evap (complete lineset 1m /w 2.3m 0.9mm cap)
    - 30g filter/drier
    - MDF wooden base plate 350x500x22mm
    - 4x industrial rollers fi55 /w brake
    - 2x coffee (2dcL)
    I had no R-22 lying around therefore I charged 20% cooking gas (liquid phase) and 80% R-507.
    Start at 10AM:
    Continuing after lunch:
    The cooler brazed together:
    Vacuuming and electrical wiring:
    First charge:
    First ice :
    Unit finished at 6.30PM:
    I'll be load testing next weekend
    Best OC Regards,
    Niko
    Administrator
    Nov 2007
    Stockton, CA
    As allways, very nice and clean units you make Niko
    /dev/zero
    Nov 2002
    Germany, Berlin
    Pretty^^
    Xtremesystems.org
    i7-4820K * ryba 2-stager + 1-stager * EVGA X79 Dark * 32G Team Xtreem 2666C11 * EVGA GTX 680 SC Sig. * Intel G2 80G * Corsair HX1000 * Lian Li PC-70B * Watercool Heatkiller, EK Fullcover/Backplate for GTX, MCP355 Dual Setup@Koolance RP-402X2, PA120.3+Alphacool 360, Tubing 16/10.
    I am Xtreme
    Aug 2008
    very nice mr tibs
    all outta gum
    Dec 2006
    Poland
    So quick, so clean, and it has wheels!
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Administrator
    Nov 2007
    Stockton, CA
    Quote Originally Posted by G.Foyle View Post
    LOL
    He makes it look so simple in his builds
    all outta gum
    Dec 2006
    Poland
    Say what you want, but wheels are not a common feature on single stages!
    www.teampclab.pl
    Test bench: empty
    Sep 2005
    UK
    Nice build tiborrr. I would like to know though how you could have done a thorough evac including the build in 8 and a half hours ?
    DFI LP UT P35-T2R/E8600 @ 5.1ghz/Modded Mach2 GT
    EVGA Classified/i975 @ 5.04ghz/Custom built SS
    3x2gig G-Skill Perfect Storm
    Asus 5970
    2x150gig Velociraptors/250gig Caviar
    PCP&P Turbocool 1KW
    -100c Club
    Jun 2005
    Slovenia, Europe
    Thanks for all the kind words fellas! Yeah, the wheelis makes for a nice skateboard
    Vacuuming from the low side and the high side and an open bypass valve. The evac was practically reached within couple of minutes but I've left it for half an hour. Note this was a new system, no refrigerant soaked in the oil yet.
    Jan 2005
    Germany
    don´t you insulate the pipe from liquid seperator to rotary?
    -100c Club
    Jun 2005
    Slovenia, Europe
    It's insulated, the pic was taken prior to that
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Looking nice I'm still jealous of what you Europeans are able to acquire for condensers. I've given up on sourcing individual condensers like a luve condenser from the suppliers in the US.
    Dec 2010
    BEI-JING for CHINA
    Hi tiborrr,your system is not very well ,i think. for example,the tem of the compressor.and the suction and the discharge ratio,
    and so ,i think this system is not work long and long
