Heya!
Allright I've been planning my new rig for a few months now and I figured that I could start a worklog about it (I like writing stuff and taking pics) and now would be a good time to start it. And also good way to make my first post in these forums after a while of lurking
. Oh and also. This is my first time ever watercooling my pc
Well might as well get started with the components.
Hardware
CPU: Intel i7 920 D0
GPU: Sapphire HD5870 1GB
Motherboard: Asus P6T Deluxe
RAM: 6GB OCZ Platinum 2000mhz 9-9-9-30
Hardrives: 2x Seagate Barracuda 7200.11 500GB (old parts)
PSU: Corsair HX620W (RMA'd, might get a HX650W as replacement)
Sound card: Asus xonar D2X 7.1
Case: Lian Li PC-A71F + new side panel with plexiglass + new top panel with 2x 120mm fan grills + 5,25" hardrive rack.
Other: Scythe Kaze Server, 2x Revoltec 30cm cathodes
Fans: A bit mixed... read about this below
Watercooling:
CPU: Watercool HK Rev. 3
GPU: EK Water blocks EK-FC5870 Acetal
Motherboard: None, ran out of money.
Pump: Swiftech MCP655
Reservoir: EK Water blocks Multioption 250 rev.2 (and anti-cyclon thingy)
Radiators: Swiftech MCR220, MCR220 QP stack and Thermochill PA120.3
Tube: Masterkleer 1/2" clear (Blue UV) with blue UV coils
Liquid: Distiller water with a silver coil
Project phases:
None yet
Other stuff:
This workstation project is a part of a little longer project that consists of the workstation, new desk and new speakers. Eventually also planning on switching my current 23" and 19" LCD's to a 3x 23" set.
The workstation got its name from the speakers which will be 2x Genelec 6010A and 5040A subwoofer. So I shortened it to Gene and though it would make a cool name for the project. And here's an work-in-progress model of the desk which I will build next year
, ran out of money.
