Hi fellow XS Members!
Since I have been reading all your awesome work logs I felt obliged to share my current work, even if I started a few weeks ago.
Project name "Virgin Suicide" might be suited since it's my first time building a liquid cooled computer, and also my first time doing anything out of the ordinary with a computer build. Hopefully this will end well.
Lian Li P80
Case selected is a Lian Li P80 Armorsuit black. My first choice was the Obsidian 800 from Corsair, but because of the late release date and release date being pushed forward in Sweden I changed to the P80.
The P80 might not be the best looking case, but since this is my first time I wanted some room to work with, and the P80 is a BIG case![]()
Color Theme
The color theme of this build is black and white, hopefully a clean looking build and not to boring
Hardware
Intel i7 920
EVGA GTX 275
ASUS Rampage II Extreme
Corsair Dominator 1600 CAS 8 6Gb (3x 2Gb)
Corsair HX850W
Intel X25-M G2 80GB SSD
Samsung SpinPoint F1 1TB
Scythe Kazer Server Fan Controller
The Loop
Aquastream XT Ultra
XSPC RX360 Radiator
3x Scythe Gentle Typhoon 1150rpm
Heat Killer CPU Rev. 3.0 LT
EK Water Blocks EK-FC275 GTX
EK-FB RE2 NB/SB (Nickel or Acetal top)
EK Multioption Res 150
XSPC 3/8" ID 5/8" OD White Tubing (3 meters)
Silver Coil (anti algae)
Bitspower Fittings
3x 45 degrees angle
2x 90 degrees angle
12x compression fittings 3/8" ID 5/8" OD
4x stop fittings
1x inline temp sensor
Extras
Scythe Bay Rafter 2.5" in a 3.5" bay
Arctic Cooling RC memory sink
MDPC white and black sleeve
Soggy sandwich (dampening for pump)
Anodised 120.3 Rad Grill without Mounting Holes (15mm spacing)
ThermoChill PS120.3 Radiator Performance Shroud (15mm fitment)
3x anodized fan grills
20x black Lian Li thumb screw
40x M3 black screws
16x black fan screw
Mix of dome head and counter sunk rivets
I will start out adding some pictures of what kind of stuff this build will contain, and add more describing text later on... So here you go, a wall of pictures
A small selection of the hardware
Lian Li P80
Aquacomputer Aquastream XT Ultra
XSPC 3.8 ID - 5.8 OD White Tubing (that's 3 feet - thought I ordered 3 meters
BitsPower Compression Fittings
EK Multioption 150 Res
Heat Killer Rev 3.0 LT
EVGA GTX 275 with EK Waterblocks GTX 275
Corsair HX850W - Resleeving from black to white is ongoing...
XSPC RX360 radiator
Thermochill Shroud
Shoggy Sandwich - Might replace the orange damp with the white one
Revoltec White Cathods - Haven't decided if those are going inside the case
Tunic TX-3 Thermal Compound
This one will not be inside the case, I just love this tool
