starting new worklog with lian-li v2010 , need some ideas
motherboard - blooderage
memory - dominator gt
the case is black (i will powder coat satin black inside)
1. like this plate but not UV blue , i want clear plate to put some red led inside.
http://www.acryan.com/index.php?opti...d=24&Itemid=59
i want to start a worklog and buying all the water cooling and modding parts , can you give some ideas??
black case with touch of red.
2. how can i mount the 140X3?
like the mount on the bottom of TJ07.
there is any brackets i can buy somwere?
3. side windows:
can i do a clear side windows without to see the screws from the outside (like bolt on)?
clear i mean like the original lian li side windows:
http://lian-li.com/v2/en/product/pro...29&ss_index=73
or like murderbox:
here is my computer:
project logo:
i think about glow logo with plexi or acryl with red led attached to the top of the case with laser cut or water cut (i didn't know how it call).
like the FLOW project:
but again , how can i attached the plexi/acryl without to see scerws from the outside??
if you have more ideas for the logo design , i'll be happy to hear.
i know how to build the water cooling system
i want to put PA140.3 + 120X2
but i'm talking about the design of the case
like murderbox or MDPC system as inspiration.
i checked the worklog list and i didn't found a lot of V2010 cases.
so i ask for help and ideas for clear/clean/simple design.
4. what is the different between TJ07 and V2010? (tj07 is more popular)
V2010 look bigger and could fit any size of rad.
thank you
