Page 1 of 3 123 LastLast
Results 1 to 25 of 56
Thread: Tokara IV - Compact Wooden Case build... In 1 month.
    Oct 2006
    Well, my Current case is just too big... Its more than 2 feet high and 2 1/2 feet long... I'm going off to college mid-August and I've decided I need a smaller case, with more power. Any suggestions are welcome.
    Here's the specs.
    24 in x 20 in x 7 in (L x H x W)
    Hardware:
    EVGA 780i - P08
    Q6600 G0 L747A [ 445x9:4.0Ghz @ 1.55v ] I hope...
    xFx GTX260 216 Black Edition [ GPU:740Mhz Shader:1515 Ram:1215Mhz ]
    6 GB OCZ Reaper DDR2-800 4-4-4-12 [ 990Mhz ]
    750watt Silverstone Modular Strider
    3x HDD [ 2 TB ]
    1x DVD-RW
    1x Sunbeam Rheobus
    Cooling:
    Dual MCR320 w/ 6 High Speed Yate Loons
    MCP655 (Have room for 2)
    MCW-60r2
    Apogee GT (may upgrade)
    Ek-250 Reservoir
    2x 80mm with air ducts to Mosfets and NB
    1x 120mm to cool HDD
    Current Build Stage : Design
    A few problems include
    1. Its going to be heavier because of 1/2" wooden planks all over the place. Not perfect for lans.
    2. The front doesn't have any designs. Just a flat face. Any ideas?
    3. The Window is sort of boring. But maybe simple is best?
    EVGA 780i - 07 [ FSB:1.4v SPP:1.50v MCP:1.6v SPP<>MCP:1.3v ]
    Q6600 G0 L747A [ 400x9:3.6ghz @ 1.38v ]
    6 GB OCZ Reaper DDR2-800 4-4-4-15 [ 990Mhz ]
    Tokara IV - Watercooled Wood case work log
    Oct 2006
    Reserved
    Xtreme Guru
    May 2009
    Southfield, MI
    Dark Cow, looking good, but there is a worklog section. I would PM a mod and ask them to move you over
    Project Millertime: The Core I5 build
    Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
    Feb 2009
    Colorado Springs, CO
    I am hoping you are watercooling everything (including chipset and mosfets), otherwise that motherboard compartment will trap a lot of heat.
    You may also want to check the depth of your DVD drive with the SATA cable plugged in, because most of them will be longer than that front compartment can hold... unless you build the case so the 5-1/4" drives so they are a part of the motherboard "chamber."
    Where will the hard drives be mounted ?
    How will you hold the cards into the motherboard ?
    Any plan to hide the cables ? Because right now there is nowhere to hide them.
    Oct 2006
    Good points there... I would love to water cool the motherboard. Its just the expense for the blocks is ridiculous. I could buy a new x58 mobo for the price... I'm constantly looking at the classifieds and I'm hoping to pick up some old stuff.
    I'm thinking a EK-780i cooler. Then air cooling the mosfets (Can't see myself watercooling those).
    What do you recommend the South Bridge. Is it worth water cooling?
    The hard-drives will be mounted in the bottom right corner of the motherboard compartment. I will probably build a false back with holes in it to hide cables. While I will probably sleeve other cables and "hide" them in plain sight. As for mounting everything, I usually make it up as I go along.
    I'm going to the store either today or tomorrow and picking up some Spanish Cedar for the frame. Its a nice reddish color and it smells great. I love working with it. The benefit is that its light. For the siding I plan on using some white oak plywood then staining it.
    If a mod wants to move this feel free.
    May 2007
    New York City
    you should go get google sketchup... it's a lot of fun... and easy to learn...
    "The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands in times challenge and controversy."
    Dr. Martin Luther King Jr.
    DIY: Self Clinching Nuts
    Canon EOS 7D | Tokina 12-24mm f/4 | Canon EF 24-105 f/4 L | Canon EF 70-200 f/2.8 L IS Mk II | Canon EF 35mm f/1.4 L | Canon EF 400mm f/5.6 L | Canon EF 100-400mm f/4-5.6 L
    Feb 2005
    Tennessee
    So you are finally at it again?
    I also really recommend using Sketchup. For instance, I am wondering in a 7" wide case how you are going to fit your PSU and triple radiator next to each other. Even using a thin rad like an MCR, the rad and 25mm fans take up about 2 1/4".
    On the current project I've been working on (and plan on resuming next week when I get back home), spending a lot of time in Sketchup to plan exactly how I want everything to go has saved me a tremendous amount of headache.
    Sketchup does take some learning, but its nothing that is really too complicated.
    Oct 2006
    you betcha. Here is a quick model. There is about 1" of space between the PSU and the Radiator
    PS... There will be a peice of wood here. I just deleted it to show you the gap... Its pretty big and I don't think there will be a problem.
    Any suggestions? I think I'm going to use a smaller reservoir and stick it on top of the HDD.
    Jul 2006
    Nova Scotia Canada
    I don't see any cooling for your Motherboard or hard drives. No fans, not even any holes. I don't think you will like the result without some.
    i7 860, 20 X 200 = 4.0GHz at 1.35V, MSI P55-GD85, 2 X 4GB KHX1600C9D3K2/8GX, GTX 590, 2 X Corsair Force 3 120GB SSDs in RAID 0, 4 X Barracuda SATA 7200.10 250GB RAID 0, 2 X Barracuda SATA 7200.11 500 GB RAID 0 for Back Ups, OCZ ZX 1250W, Z-5500s, LG Blu Ray Player/DVD Burner, Koolance CTR-CD12 Fan/Pump Controller, Windows 7 X64 Home Premium, HAF X. Vision Quest 24" WS LCD, Optoma H66 Projector
    Cooling: Thermochill PA120.2 GT AP15 in push, DC3.25/XSPC Res top, Apogee Xt Extreme, XSPC Razor, Coolgate CG-240 GT AP15 in push/pull, MCP35X.
    Oct 2006
    O lol. Forgot about that. This model does leave a lot to the imagination, its not very good. But its basic.
    I had to increase the width of the case by .5" to fit the extra fan in there. Thank god you guys made me draw it up in sketch.
    And of course there's going to be a huge hole for the graphics cards etc... So there should be plenty of airflow.
    Mar 2009
    Sweden
    I would've flipped the front rad 90 degrees vertically, that way you'll have a more compact build, and maybe some airflow left over for HDDs and motherboard.
    As you wrote, put a res on the HDDs and the optical drive sticking out above.
    That'll make it somewhat more compact.
    Good luck!
    Oct 2006
    Well, bought some wood but turns out 6 ft isn't enough lol.
    Well, here's a few pics, Work will start tommorow building the bottom, back and the splitters.
    Here's the joint, quite simple, and it will allow me to get that cool long sweeping Lian-Li curve.
    and of course the work place... Its a dump I know.
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    Just to give you something to think about, fans don't have to be mounted on the rads.
    You can mount the fans anywhere on a box as an exhaust and the air will come in through the rads (if they are the only opening) with no dead space from the fan motor.
    It's easier to control the air flow that way.
    Oct 2006
    That's an interesting idea... But I don't think I want to do that because I won't be able to fit all 6 fans on the other side, and I'm not sure how good of a seal I can get.
    Oct 2006
    Just a quick update, cut out a few pieces today, but mostly just planned out the motherboard tray and mounting mechanisms
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    wow interesting project log
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Oct 2006
    thx guys.
    More updates, the thickness planer didn't do me wonders, had to do some repairs
    This router jig took forever to set up, had to really thin out the back for motherboard.
    The joints coming together quite nicely... To be honest, masking tape is really underrated.
    And of course uni-sleeving. First try
  18. #18
    Feb 2008
    Russia
    Wow! The best WCidea i have ever seen! Good luck! Crazy man!
    Intel Q9650 @500x9MHz/1,3V
    Asus Maximus II Formula @Performance Level=7
    OCZ OCZ2B1200LV4GK 4x2GB @1200MHz/5-5-5-15/1,8V
    OCZ SSD Vertex 3 120Gb
    Seagate RAID0 2x ST1000DM003
    XFX HD7970 3GB @1111MHz
    Thermaltake Xaser VI BWS
    Seasonic Platinum SS-1000XP
    M-Audio Audiophile 192
    LG W2486L
    Liquid Cooling System :
    ThermoChill PA120.3 + Coolgate 4x120
    Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
    Watercool HeatKiller GPU-X3 79X0 Ni-Bl + HeatKiller GPU Backplate 79X0
    Laing 12V DDC-1Plus with XSPC Laing DDC Reservoir Top
    3x Scythe S-FLEX "F", 4x Scythe Gentle Typhoon "15", Scythe Kaze Master Ace 5,25''
    Apple MacBook Pro 17` Early 2011:
    CPU: Sandy Bridge Intel Core i7 2720QM
    RAM: Crucial 2x4GB DDR3 1333
    SSD: Samsung 840 Pro 256 GB SSD
    HDD: ADATA Nobility NH13 1GB White
    OS: Mac OS X Mavericks
  19. #19
    Feb 2005
    Tennessee
    Quote Originally Posted by DarkCow View Post
    Now you know first hand why it is a good idea to work up the a model in Sketchup first. You end up with a much better end result this way with a lot less gotchas while building.
  20. #20
    May 2008
    Poland
    You could get rid of 2 fans cooling your HDDs and mobo by cutting a hole in the vertical wall dividing mobo compartment and front rad and redirecting airflow from this rad [or both if you want more flow]. The air from rads is cool enough and you'd get some serious positive case pressure [6 fans blowing air in, 8 if you keep the ones on HDD O.o]
    E6550 2,33GHz @ 3,5 GHz || HD4850 714/1104 || 2x1GB OCZ PC-8500 @ 1000MHz
    Abit IP-35-e || Amacrox 450W PSU
    || Max. sig. size is 500x250 pix, isn't yours bigger?
    Cooled by: Apogee GT || MCW-60 || MCP655 || BW Extreme 123 rev. 2 || MCres
  21. #21
    Oct 2006
    Good idea, I think there is enough room to shove a 120mm in the splitter. There is going to be a serious amount of positive pressure. Everything that's not bolted to the ground is going to be sucked into it
    A good nights work... I'm sore, my back is killing me... But hey, the corners are actually at 90 degree angles whoo whoo! my last case was no where near square...
  22. #22
    Oct 2006
    Gotta glue something to mont the side panels on... Nothing fancy, just flat face. over 20 strips in total...
  23. #23
    Feb 2005
    Tennessee
    I too have had a few of those days working on the build I'm on. I know the feeling! And I too got my corners square to within less than 1/16" which is a first!
    Keep it coming.
  24. #24
    I am Xtreme
    Dec 2007
    looking really good
    just kinda funny you call this the "smaller" one
    and i love the google sketchup, im gonna try it out tonight after i get off work and see if can put some of my old builds into it
  25. #25
    Oct 2006
    lol, I know, its not much smaller at all, it just looks smaller. My last case looks cavernous, this case has all the space put to good use.
    Now onto what in my opinion was the hardest job. The side panels, took all day cutting, sanding, plaining, cutting again, sanding again, repair jobs, plaining again, then sanding, then glueing back on corners etc... etc... etc... Why can't it just be easy?!
    Me at work
    One of 4 side panels, it looks like it may just fit.
    So close, but yet so far!
    With a little bit of patience, and a lot of elbow grease. the finished (well almost) result.
    and of course the most fattening pizza I can buy
