For stupid as it may seems i almost lost my system for 2 simple brand new o-rings that came with my BFG GTX285 H2O OC wich came with a danger den full cover block and some DD barbs...
i put it to work a month ago and 3 days ago i looked inside the PC and BOTH barbs where leaking from the o-rings...inmediately i turn everything off and pull apart all...thanks god as the block has a big surface water didn't drop...
here are some pic, yesterday i sent a mail to BFG, i been building water systems and never happened this...
the barbs as i took them a month after use
see how destroyed they are and i didn even thigthen them much...they look like o-rings used for years...and also left the residue on the copper of the water block
so well i starded building again i took the chance to clean all and put new tygons just running destilled + some drops of algae control and testing for leaks on that part
after hours of running and testing for leaks i put it to work again
and finally after cleaning all temps drop and are great considering im on 22C ambient and im runing the Q9650 vid 1,1875 that heats up a lot and sharing the loop with the GTX at that OC on the pic
Cheers all
Sergio
