Well... today i received my heatkillerand im thinking to silver,chrome or nickel plate the upper copper part of the block
The think is which of these 3 metals has the better results with heat, corrosion etc.???
Xigmatek Elysium - ASUS P8Z77-WS- 3770K Testing.... - G.SKILL 16gb F3-17000CL9Q-16GBZH @ 2133 - ASUS 7970 MATRIX Platinum - Corsair AX 1200w
CPU EK-Supreme HF nickel plated - Pumps 2 x Laing DDC-1Plus with EK-DDC Dual TOP V.2 - Radiator ThermoChill PA120.3
Nickel, its the cheapest.
No, but dont plate the bottom base.
um, kinda hard to not plate the bottom... the thing gets dipped into some liquid in process of plating...
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands in times challenge and controversy."
Dr. Martin Luther King Jr.
DIY: Self Clinching Nuts
Canon EOS 7D | Tokina 12-24mm f/4 | Canon EF 24-105 f/4 L | Canon EF 70-200 f/2.8 L IS Mk II | Canon EF 35mm f/1.4 L | Canon EF 400mm f/5.6 L | Canon EF 100-400mm f/4-5.6 L
Core
Core i7 920
eVGA X58 LE SLi
2x3GB Mushkin DDR3-1600
BFG 8800GT OC
Seagate 7200.12 1TB + Maxtor 320GB
LianLi A05B
Cooling (all internal)
2x BI GTS 360
2x DDC3.2 + Ek top
EK Supreme LT
WAITING FOR SOMETHING... FULL LIQUID BY YBRIS Ybris A.C.S. FULL CHROME Limited Edition N°058 | Ybris A.C.S.-G FULL CHROME Limited Edition N°058 | SANSO PDH-054 12V A.F. | Feser Xchanger Q.R. 480 with Feser Xtender blue\Scythe Ultra Kaze 3000rpm | Tecnofront Bay Trap | Tygon R-3606 3\8" 1\2"![]()
last i checked, they hang the components on a rack and dip it into a bath of some chemicals and whatnot...
also seen this on OCC as well...
it's kinda tough for them to plate only the top areas... it's not a brush on technique...
Core
Core i7 920
eVGA X58 LE SLi
BFG 8800GT OC
LianLi A05B
2x BI GTS 360
2x DDC3.2 + Ek top
EK Supreme LT
ha ha ha... i'm having a brain fart...
i'm thinking that OP wants to plate the cooper bottom base, but not the bottom surface that comes in contact with the IHS...
scusi while i go bang my head a bit...
It is true that thermal conductivity of nickel is smaller than copper (about 25%). But the thickness that one plates nickel is on the order of microns. The thermal resistance will be negligible. The two major thermal resistances occurs in transfering the heat from the IHS to the waterblock (thermal paste, small amounts of trapped air, and oxides) and transfering heat from the waterblock to the water (boundary layer). So you will not notice any performance losses by plating the block with nickel, because the other resistances are much greater.
They told me that they cant nickel plate the aluminium parts is that true or should i find another workshop?
Bth as i see the block i think i can take off the upper part so i can i leave the bottom as it is
Edit: I forgot to mension that youve done excelent job! extremely nice![]()
Circles SucQ!
"The housing is CNC machined out of billet aluminum and receives two plating's for a lifetime protection against corrosion: electroless nickel plating (MIL-C-26074E grade B) and Zinc Cobalt plating (ASTM B 840-99 grade 6)."
Maybe it was the Zinc Cobalt first then the nickel
Core
Core i7 920
eVGA X58 LE SLi
BFG 8800GT OC
LianLi A05B
2x BI GTS 360
2x DDC3.2 + Ek top
EK Supreme LT
Circles SucQ!
Yes, Copper plating first is usually involved in nickel plating. I don't know of any commonly plated base metal that doesn't get the copper treatment then nickel.
Copper and nickel are also pre steps to chrome plating.
http://en.wikipedia.org/wiki/Chrome_plating
Circles SucQ!
You can nickel plate aluminum with an electroless process. You just have to spray it with something first. (starts with a z) Check with caswell.. It's also in the manual somewhere. If it were a pure aesthetic part, then thats fine, but I wouldn't necessarily start coating blocks with multiple sprays, etc.
Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
