This is a new project called Blue Orbit. The idea is to create a dual loop for CPU (NB,SB,Mosfets) and CrossFire HD4870x2. The PC case hosting the HW and one more case made of plexiglass where the pumps, radiators and fans will work to provide the cooling.
Blue Orbit is the name for this case. And Yes there will be few blue mods to it.
System specs:
[Asus MaXiMus Formula SE]
[QX6700@3600]
[PowerColor HD4870X2 2GB GDDR5][EK-FC4870 X2 - Acetal CF]
[D-TEK FuZion CPU with Quad Nozzle]
[ThermoChill PA120.3]
[Laing DDC-1T-PLUS with Alphacool Laing DDC Pro/Ultra top]
[XSPC Dual 5.25" Bay Reservoir for Dual Laing DDC]
[MIPS MCH034 Northbridge MCH003 Southbridge MCH150 Mosfet ]
[Stacker 832] + lots of plexi
The design is based on 3 levels. 2 levels for the watercooling, 1 level for tubing and the pumps, reservoir.
Connecting the two cases together will be done using Bulkhead Quick Release Compression Couplers.
Here is a picture of how the design looks like
By neo_rtr at 2010-01-24
Note about the PA 120.3
I have the new one with 15mm spacing as well the old one with 24.5 spacing
This is why you will see there is a difference with the holes.
Working the acrylic was lots of fun and had to learn along the way
Several mistakes later i come up with this
By neo_rtr, shot with iPhone 3GS at 2010-01-24
Iam waiting for parts to arrive so it will take a week or two before i can update the page. But this is a start.
