Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Does 64 bit OS like W7 stress the system more?
    Apr 2008
    I can't seem to keep my rig stable at the same settings now that I switched to Windows 7 RC1 64 bit. Do you guys think the OS puts more stress on the components being 64 bit, or that it is just not stable?
    I was running 191x21@1.35 vcore, but now the voltage has to go up a few notches (along with the temps)
    now I've got peak temps of 82 deg C, so I backed off the clocks for now.
    Jul 2008
    Quote Originally Posted by mikesrex View Post
    well... from my experience when hardware starts to come of age then it can be a big factor thats what it sounds like.
    Mar 2008
    川崎市
    There are various threads in the AMD section where people reported lower max oc's with 64bit os vs. 32 bit, but I have not seen anyone reporting the same yet for Intel cpu's. However, considering how similar AMD and Intel Cpus are it is certainly possible that it is a issue on Intel cpus as well.
    Banned
    Oct 2006
    Haslett, MI
    Most definitely.
    Apr 2008
    so basically I need to try out a D0-stepping i7 or perhaps find a better cooler than the TRUE120 lol
    Love will tear us apart
    Mar 2006
    wrigleyville.chi.il.us
    Threads like this come up every once in awhile (tho usually not in a 32 vs 64-bit context) and the general consensus has always seemed to be that hardware stability due to overclocking is totally independent of the OS being run. According to the first few posts in this thread perhaps that is not the case as I've always somewhat suspected (though it's hardly illogical to think OS should not matter).
    Further thoughts?
    Dark Star IV
    i5 3570K | Asrock Z77 Extreme4 | 8GB Samsung 30nm | GTX 670 FTW 4GB + XSPC Razer 680 | 128GB Samsung 830
    Apogee HD White | 140MM UT60/120MM UT45/120MM ST30 | XSPC D5 V2
    Apr 2008
    Quote Originally Posted by WrigleyVillain View Post
    Further thoughts?
    I'm still a noob at this whole thing, but it was pretty apparent that XP32bit would crunch for days on end with no problems whatsoever at 191x21 with 1.35 vcore. With W7 RC1 64 bit, though, I had to make changes. Maybe it is just bugs in the actual OS as opposed to a difference in inherent stability?
    version 2.0
    Feb 2005
    Flanders
    64 bit is more demanding from the hardware.
    If you are on the edge of stability with your CPU (on 32 bit OS) , it's expected to have a slightly lower maximum clock with 64 bit OS.
    I have experienced the same thing
    Apr 2008
    Quote Originally Posted by Jaco View Post
    ah this makes sense. I don't have time to tune this thing right now, so I feel kind of disappointed for letting it crunch at stock clocks. I have to make a haircut appointment and then go to work. I do have the whole weekend off work (for the first time this year) but I am graduating from college tomorrow.
    Jul 2008
    better cooler than the TRUE 120 LMFAO you cant get better other than watercooling .......
    Apr 2008
    Quote Originally Posted by dan7777 View Post
    i was hoping to get a laugh out of that one.
    i noticed someone tested the prolimatech megalems against the TRUE Copper and found it to outcool the TRUE Copper. I wonder if I should give it a try. I need a new cooler for one of my rigs, so I may try it out.
    Banned
    Oct 2006
    Haslett, MI
    That'd definitely be a waste of money IF you even get 4c lower temps, which you won't.
    version 2.0
    Feb 2005
    Flanders
    yeah , you even need good watercooling to beat the TRUE.
    Won't happen without a triple rad.
    Xtreme Cruncher
    Feb 2008
    Lincoln, Ne
    Further thoughts?
    This totally reminded me of Spock in the new Star Trek. have you seen it lately?
    This is Xtreme, we use car radiators now
    Crunching
    3.65ghz q6600 @ 1.33v
    2.4ghz 4600+
    Xtreme Cruncher
    Sep 2007
    PA, USA
    i've always had lower clocks in 64bit than 32bit at the same voltage, this is on 2 amd x2's and 1 intel quad (x3330)
    XS WCG Rules: #1: don't pull fart_plume's finger #2: Dave aka Movieman, don't give him your phone number if you like your hearing
    XS WCG Note: There are 2 sets of points, WCG and Boinc. WCG = 7x Boinc
    Project: Dark Matter (<- link) - Asus Maximus II Formula, Intel X3330 3.4ghz @1.32v under load, corsair ddr2 1066 8gigs, evga gtx260 core 216, pc p&c 750W, EK Supreme HF Nickel, iandh 175 res, Swiftech MCP355, Black Ice GTX G2 240, Lian Li v1200b
    silverstone tj07 build log
    Back from the Dead
    Oct 2007
    Stuttgart, Germany
    Well, depends on how you define stability. If you checked your OC using prime95 on XP (the standard 32bit 25.6 prime), and it was stable, then it should and will be stable on any x64 OS as well.
    However, if you only tried crunching on XP 32 vs. a 64bit OS, you might experience instabilities because your setting wasnt really any good in the first place, it just didn't show because the CPU wasn't loaded that hard with 32bit BOINC.
    World Community Grid - come join a great team and help us fight for a better tomorrow![size=1]
    Feb 2008
    enteon@jabber.ccc.de
    Quote Originally Posted by jcool View Post
    ouch.
    there are a lot of boinc projects that are more demanding than prime95 and therfore 'produce' 'more' errors. fight aids at home is the most demanding i know, but it changed recently.
    on the other hand i agree that a cpu that does no errors @ 32bit but does @ 64bit wasn't ever stable after all. but it just happened that the 32bit software did its job slightly different, putting load on a different - more stable - part of the cpu.
    but from the standpoint of the user this would seem as if 64bit software was more fault provoking, magically reducing the oc-ability.
  18. #18
    all outta gum
    Dec 2006
    Poland
    64 bit OS and apps require more stability and more power.
    In 32-bit mode parts of CPU are not used, and though power and clocks are distributed to them, they do not use as much power as in 64-bit mode. For example, all general purpose registers are used only in half, all ALUs work at half width etc.
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
  19. #19
    Back from the Dead
    Oct 2007
    Stuttgart, Germany
    Quote Originally Posted by enteon View Post
    ouch.
    Ouch.
    Do you even have an i7?
    Prime blend is more demanding than ever on the i7 arch.. only to be surpassed by LinX which is beyond any and all realistic load anyways.
    There is definitely not a single WCG project harder on an i7 than prime, sorry.
    Maybe QMC (another boinc project), but not WCG.
  20. #20
    Apr 2008
    well well well, so I let my computer crunch all day at stock clock and default settings.....
    ......and upon coming home, my computer has crashed. I think there is something wrong with my windows 7 64 bit OS that causes the computer to crash, not the overclock.
    yes, I still consider myself a n00b, but I am not an idiot. I can use my critical thinking and troubleshooting skills to figure things out, even if I don't consider myself an "expert" in a particular field.
  21. #21
    Xtreme Cruncher
    Mar 2008
    China/Australia
    So your rig is on stock clock and it still crashes when on load. Have you tried it in a different OS (also in stock clock)? This will verify whether the OS has any fault in this.
    Otherwise, seems like a hardware issue considering crunching is just like any other stress test.
    Note: There is a remote possibility that it could be unstable drivers.
    Apple MBP 15": Intel T9400 (2x2.53GHz) | 2x2Gb DDR3 1066 | 9400M + 9600M GT | 250Gb 7200rpm
    Wish List: Return to desktop for some crunch action.
    I am on... QuadCaine.
  22. #22
    Apr 2008
    Quote Originally Posted by fungry View Post
    I crunch 24/7 no problems at 4.0 GHz in XP 32 bit.
    I have a feeling this has something to do with the computer going to sleep or something. I'm gonna try to figure it out.
  23. #23
    Xtreme Cruncher
    Jun 2005
    Northern VA
    Ouch.
    id go with OCCT myself.
    but be careful, it has been known to destroy some hardware, namely PSU, CPU, and GPU, and a few mobos.
    ive had it increase my temps by over 8C, and thats with boinc 24/7, with gpugird, and rc5-72 in the background. with a DD480 with 8 denki fans on it sitting in my window, sucking cold air in the room.
    Its not overkill if it works.
  24. #24
    Back from the Dead
    Oct 2007
    Stuttgart, Germany
    Does OCCT stress all 8 threads on an i7 if you have HT enabled? Last time I checked it only ran 4 threads... which makes it unfit for i7 testing really.
    Like I said, if you wanna go extreme, try LinX...
  25. #25
    Apr 2008
    right now I disabled anything that windows 7 does to put the computer to sleep along with the screen saver and it seems to be working perfect. after a day of so of no problems I'm going to clock it back up to 4.0 GHz and see what happens. I have a feeling that was my problem.
