Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Thread: New Swiftech Full-cover waterblock for GTX285 released
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Introducing the Komodo full-cover waterblock for nVidia® GeForce® GTX285 graphics cards (P891 reference design)
    The Komodo water-block offers superior thermal performance at the GPU level thanks to an embedded thin-pin matrix located directly above the GPU area. Flow restriction is moderate by design in order to take into account multiple water-blocks in the same loop, and is similar to that of the classic MCW60 (See pressure drop vs. flow rate curve below).
    The base is made of chrome plated electrolytic copper, and the top is machined in black Delrin. High thermal conductivity grease pads are pre-applied in the memory and mosfet areas for user convenience. Short barb fittings are included with the block for 3/8" or 1/2" tubing and compatible with dual or triple SLI setups.
    MSRP is $134.95 - shipping immediately
    CEO Swiftech
    Engineering The Xtreme
    Feb 2007
    MA, USA
    Thats one sleek looking block, I bet it performs wonderfully as well
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by SNiiPE_DoGG View Post
    In all modesty? it's a champ! I really got some terrific overclocks with this block.
    CEO Swiftech
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    That's a nice block but what's up with the name...it reminds me of commode ?
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by dengyong View Post
    It's named after the Komodo Dragon. A Mean Beast!
    CEO Swiftech
    Aug 2007
    Looks awesome. Any chance for an acrylic top?
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by HotGore View Post
    Working on it. We've always been reluctant to machine acrylic due to cracking problems. Were'looking into polycarbonate.
    CEO Swiftech
    Xtreme Mentor
    Jun 2007
    Chicago
    Quote Originally Posted by gabe View Post
    I really think that would look amazing in acrylic.
    It's the only thing that keeps me going to Ek blocks, but if other manufacturers push stuff out in acrylic, I'd certainly buy other blocks.
    That being said, thats a very nice block.
    Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
    Mar 2008
    Oslo, Norway
    What kind of compression fittings compability? Looks to me maybe even 3/4" could fit?
    I Are DuneCat
    I Controls The Spice
    I Controls The Universe
    Cooler Master ATCS 840 | Corsair HX 520W | Asus P5Q Pro | Q9550 | HD4870 | Corsair Dominator 4GB PC8500 |
    D-Tek FuZion v2 - EK RES 150 - Swiftech MCR-220/320 - Swiftech MCW-60 - DDC 3.2 + Petra's Top
    Mar 2008
    New Zealand
    Great job Gabe. I love the way the top forces water down across the pin matrix, cpu style cooling for gpu's very cool - literally. I would love to see it with a clear top to, the black top looks to industrial for me and its a crime to cover up that pin matrix.
    Asus Maximus II Formula, E8500@4GHz, 4Gb Crucial Ballistix Tracers, Enermax Infiniti 720 Watt, GTX 460, Creative Audigy, 1Tb HDD, 500Gb External HDD, Asus DVD Burner, HP w1907 Monitor, Custom Acrylic Case.
    Water cooled by Swiftech Apogee GT, EK Full Cover, Thermochill PA120.3 & PA160, D5@3, Custom Bronze Res, 7/16 Tubing.
    [SIGPIC][/SIGPIC]
    Mar 2008
    Connecticut
    I wish more companies did this. Especially for my 4870x2, cutting all the pads for the Vregs and memory chips was a royal PITA.
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by Zehnsucht View Post
    I have a distance of 30mm (1.18") center to center between inlet and outlet ports.
    CEO Swiftech
    Aug 2008
    pics of the backside? is it compatible with sli?
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by veedubfreak View Post
    For dual or triple SLI, this type of setup is recommended in single cooling loop configurations (CPU and GPU in the same cooling loop with one pump). Use of the included 1/2" barbs is recommended for connecting the water-blocks in SLI, even if the rest of the system is plumbed in 3/8".
    For dual or triple SLI, this type of setup is preferred in dual cooling loop configurations (separate CPU and GPU cooling with individual pumps for each loop). Use of the included 1/2" barbs is recommended for connecting the water-blocks in SLI, even if the rest of the system is plumbed in 3/8".
    CEO Swiftech
    Xtreme Mentor
    Sep 2007
    Dallas
    Nice looking and very thoughtful to include the thermal paste pre-installed. I like the look of the parallel configuration. It looks like this is a single slot design, is that correct?
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by Utnorris View Post
    "The Komodo water-block is a single slot, liquid cooling solution for nVidia® reference design GeForce™ GTX285 graphics cards. This "full cover" waterblock cools the GPU, Voltage Regulators, I/O chip, and memory modules."
    CEO Swiftech
    Feb 2005
    USA
    very nice....what kind of underload temp one can expect from this block? assuming running one card in a single loop.
    Core i7 920 D0 3844A717 4.40Ghz HT on @1.36v (LinX/Prime/3D stable), Corsair 850W, 12GB OCZ Platinum 1600, P6T Deluxe V2, EVGA GTX 285 SS, OCZ Vortex SSD 30GB x3 RAID0, HAF 932.
    Water Cooling Setup: XSPC RX360, MCP355 + XSPC Res Top, Swiftech GTZ, 1/2" Tygon, Scythe S-Flex SFF21F push, 20mm yateloon D12SL-12C pull.
    Opteron 148 CABNE 0528 GPMW 3.1Ghz @1.6v Prime Stable. Westy 37" LVM-37W3, DFI Venus 975, 2GB TeamX Cronus Micron, GSkill HZ, Sapphire X1900XTX, Zippy 700W, X-Fi Xtrememusic, 36GB Raptors x2 @Raid-0.
    WC Setup: PA120.3 +Shroud, MCP655, STORM, MCW60, 1/2" Tygon, mini res, Yate Loon.
  18. #18
    Jan 2008
    Puerto Rico
    could be a noob question but why parallel is better for single loop solution (CPU + GPU)? isn't that a flow killer? also how exactly this parallel works compared to the heat killer gpu parallel bridge setup?
  19. #19
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Wicked cool looking block. The internals on the GPU look very nice from the diagram. Will chrome be the only option or will the standard copper look be available as well?
    Formerly XIP, now just P.
  20. #20
    Sep 2006
    Oahu Hawaii
    Your shipping links for Hawaii zip codes (at least mine 96706 doesn't work) are still broke. Almost impulsed ordered one and just like the last time (year ago?) I tried to order straight from the factory, all I get is:
    Shipping Method:
    use the dropdown menu to select your desired shipping method Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
    [Microsoft][ODBC SQL Server Driver][SQL Server]Incorrect syntax near the keyword 'AS'.
    /store/cart.asp, line 220
    Works fine with other zips. Unfortunately, that does not help me place an order to get it shipped to me.
    On a side note, are you guys planning on making NB/SB/chipset block/s for motherboards...such as the eVGA Classified?
  21. #21
    Dec 2008
    Jersey
    Nice block Gabe. Keep up the great work.
  22. #22
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    definitely a pretty block
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
  23. #23
    Apr 2008
    Ottawa, Canada
    Very nice Gabe. Like the pin matrix as well. People who use dye will have to watch this though as it will be another area to clean up once the fluid goes clear in the tubes.
  24. #24
    May 2008
    Quote Originally Posted by Blacky View Post
    It's a flow killer for the GPU blocks, but it increases the flow rate for everything else, most importantly the CPU block.
  25. #25
    Banned
    Apr 2008
    Perth, Western Australia.... mate
    sweet looking block and pressure drop figures are nice too.
    Cant wait to see how it performs
    instead of acrylic tops you could look at using some of this
    http://www.usplastic.com/catalog/pro...ookie%5Ftest=1
    heres an EK block I modded with some of this fluro acrylic
