Results 1 to 25 of 132
Thread: High-Res! Update April 22nd, Rad fitting.
Threaded View
    Mar 2009
    High-Res! Update May 1st Koolance P0rn.
    Sponsor
    <----Clicky!
    I would like to thank Tom @ Chilled PC for the help with everything to come over the next few months. I wouldn't go anywhere else for anything water related!!
    Hi all this is a intro to a build that iv been planning for a few months and with the first part just arrived then i thought i should start. Im into my watercooling so that will be a big part of the build.
    Heres a few pics of my past builds(Clicky):
    Anyway lets get on with it, first.
    The hardware:
    E5400.
    Gigabyte P45.
    2x2GB DDR3 or DDR2 depending on mobo choice.
    EVGA GTX285.
    Silverstone DA850.
    Samsung F1 750Gb.
    Cooled by:
    Thermochill PA120.3.
    DDC 18w with top.
    Custom roof res.
    Koolance Full cover GPU block.
    GTZ
    All housed in a custom Lian-li P60 armoursuit.
    The build is taking alittle design from the Focus ST which should be apparant over the coming months so to start heres a few of the design stage ideas.
    I want to take the case away from the Chavtec 900 looks to a more slick case as Lian's should look.
    Sorry for all the finger prints and dust but as any of you know who have owned a black lian-li there a total pain to keep clean.
    Thanks Brad.
