Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Thread: Quick Disconnects: Koolance VL3 Series
    I am Xtreme
    Aug 2008
    They just arrived fresh from their washington office.
    Without QDC
    With one set of QDC(male+female)
    With two sets of QDC(male+female)
    enjoy
    Feb 2008
    I love my CPC 1/2'' quick disconnects. have you got any of those laying around to test?
    I am Xtreme
    Aug 2008
    sadly nope...wish i had some...to test..and if they're really good.i'll keep em
    Xtreme Mentor
    Jun 2007
    Chicago
    I'm going to be solely using these as a drain-fillport.
    Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
    Apr 2008
    Ottawa, Canada
    Glad I kept those out of my loop. Was planning on using them at first but once I looked at it closely I put them in a box and kept them there. Could be useful as drain and fill ports but too much of a flow killer for anything else.
    Xtreme Batrachian
    Jan 2007
    Eastbourne, UK
    Please excuse my ignorance but... What's the unit of measure?
    Quote Originally Posted by fart_plume View Post
    First loops are like first sex, all hands and thumbs till you figure out what goes where, then it's what ever works best for you.
    Admin
    Feb 2005
    Ann Arbor, MI
    GPM on the left, l/min on the right.
    Nice quick test there Mirrors my findings too, which makes me feel good
    Sep 2007
    Germany
    Should be GPM.
    I have the Koolance VL3, the CPC for 3/8" ID (APC series?) and the 1/2" CPC NS6 series lying here. The Koolance are noticeably better than the 3/8" CPCs, but the 1/2" CPCs have a completely different construction, and I haven't tested those yet.
    I'm gonna publish results flow for all of them once I get my proper rotameter, I currently have a Digmesa FHKUC but I noticed that the absolute value is not correct, and I'm not sure whether the relative values are correct either.
    I am Xtreme
    Aug 2008
    Quote Originally Posted by Vapor View Post
    gooood to know...it works ok with two pumps
    Jul 2008
    Winterthur, Switzerland
    Thanks for testing!
    I hope you get a chance to compare them to some CPC QDs, I'd love to see a comparison.
    Let's see how's first, you or Nickel020.
    Xtreme Batrachian
    Jan 2007
    Eastbourne, UK
    Got my wires crossed and though it was pressure, not flow LOL. No wonder I couldn't make sense of it...
    0.25 GPM per pair it's a hell of a drop though... blimey!
    I am Xtreme
    Aug 2008
    Quote Originally Posted by HESmelaugh View Post
    Thanks for testing!
    i don't drive fast nor race, i cruise
    Jul 2007
    If anyone is going to do a full comparison they should toss the VL4's into the running too
    Sep 2007
    Germany
    Quote Originally Posted by Hondacity View Post
    So do I, and I won't be rushed
    I can tell you tha using the FHKUC I measured 250 l/h for the Koolance and and 200 l/h for the CPC 3/8". I use the Koolance with a female-to-female G1/4 adapter so I can use any barb.
    I don't trust the FHKUC fully though, I did some manual testing with a stopwatch and I found that while it showed a flowrate of about 178l/h I actually was getting more than 200 l/h (different pump and loop setup for this test). That's why I ordered a rotameter (swiss made ) and when I get that and find some time I'll do a 1/2" tubing comparison with thebig NS6 CPCs.
    Feb 2008
    Ca
    Those are the 3/8" ID right?
    Haswell, Maxwell, MLC
    My HeatWare 77-0-0
    Sep 2007
    Germany
    Yes, they're a little more restrictive than 3/8" tubing though of course due to the shutoff mechanism.
    Also, nothing beats the CPC NS6 1/2" shutoff mechanism, no water coming out at all when you open them
    Jun 2008
    Los Angeles, CA
    I have a ton and you could borrow whatever you needed for testing.
  18. #18
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    Quote Originally Posted by Nickel020 View Post
    CPC's also come in 3/4
    There big and ugly tho.
    I have 6 unused right here.
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
  19. #19
    Oct 2008
    Seattle, Wa
    Also keep in mind... if you'rel ooking for ultimate flowrate then these are the "mid-range"
    Here's a list of all our shut-off valves and their flow-through ID
  20. #20
    Chasing After Diety
    Jan 2007
    Dean i really wish you guys would make the VL4 with G1/4 threads so i can retire my VL3's.
  21. #21
    Aug 2005
    Washington
    Quote Originally Posted by NaeKuh View Post
    QFT . I think I remember hearing that they were being made, but I guess you would know better than I do.
  22. #22
    Sep 2007
    Germany
    I don't understand that either. Why make them with different compression fittings and barbs attached to them, but not with a female G1/4 thread. That's the single biggest complain about the CPCs (not being able to use any barb you want) and it would be so easy to fix it for Koolance
  23. #23
    /dev/zero
    Nov 2002
    Germany, Berlin
    I vote for G1/4 female-threaded QDs (VL4) as well.
    Xtremesystems.org
    i7-4820K * ryba 2-stager + 1-stager * EVGA X79 Dark * 32G Team Xtreem 2666C11 * EVGA GTX 680 SC Sig. * Intel G2 80G * Corsair HX1000 * Lian Li PC-70B * Watercool Heatkiller, EK Fullcover/Backplate for GTX, MCP355 Dual Setup@Koolance RP-402X2, PA120.3+Alphacool 360, Tubing 16/10.
  24. #24
    I am Xtreme
    Feb 2007
    VL4s in 3/8 ID 5/8 OD would be nice as well
    "Thing is, I no longer consider you a member but, rather a parasite...one that should be expunged."
  25. #25
    Dec 2006
    Quote Originally Posted by DarthBeavis View Post
